[help!!] unable to read device signature with my atmel ICE basic
26 posts / 0 new
hello everyone,
i have a problem with my atmel ICE basic i recently bought from online shop. From what i have checked, the wirings are good and i got a good voltage reading and  it could read device signature for the first time successfully....but when i tried to read it for the second time (right after my first try), it failed to read, but voltage reading is still ok, and from the first time i tried the device the LED glows red and green color . Do you know what the problem actually is for my case? Is it my device that gets bricked or something?? thx before....
You have to help us to help you. No idea what programming interface or chip you are using.
i am sorry i forgot to mention that....i use ATMEGA16A as the chip to be programmed by my atmel ICE...do you know what wrong is with my case?
i use ATMEGA16A
And pulling another tooth... what programming interface? JTAG or ISP?
Maybe you may also want to post a diagram of you board.
i dont have the diagram of my board but the my board uses the same diagram as minimum system for ATMEGA16A in order to work...and i am using SPI for my connection...do you know what the problem is?
sorry for the late post
And where did you get this information from? You MUST have the diagram you copied from.
ie do you have ALL VCC, GND and AVCC connected correctly? Are you using supply bypass caps on those pins?
System LEDS meaning
I ran into this problem with my atmega328P yesterday was i had connected the 10k pull up resistor( the minimum circuit for atmega 328p) to ground, instead of Vcc. So as a result the first time i would connect the atmel ice and read device signature perfectly fine. the second time it would fail. changing the resistor back to +vcc solved my problem. I am using a atmel ice basic programmer as well.
after looking inside my HD for some time, here is my board :
could you point out which is the problem on my schematics??
btw ignore the oscillator, i am using 11MHz to make it work..
could you show me how you connect it on your board?
If AVCC is not connected to power, then Port A will have no power.
I hope you have just omitted bypass capacitors for the mega16a in your schematic (as well as a cap for AREF).
How is JP12 implemented? And how are you connecting the atmel-ICE to it?
Edit the cap on Pin2 of the MAX232 should go to GND not VCC.
David (aka frog_jr)
That's a crazy circuit! C2 should be going to ground like C1. Is C9 and D1 supposed to go to the reset pin?
Depending on the regulator type you MUST have bypass caps (usually 2 x 100nF) near the regulator , and see frog's comments above.
i am using the JP12 to program my chip directly, and there is no caps at AREF and i don't connect anything to AVCC, i just leave it as is...so do i have to connect AVCC to power source??
btw the programming works well when i use my old STK500-based programmer but after changing my programmer to atmel ICE this problem occurs..
btw what bypass capacitor do i have to omit from my circuit? that 10nF?
So you are not using the normal 6way ISP header but using jumper cables? Are you using the squid cable that comes with the Atmel Ice?
You MUST, it powers up part of your chip. Without connecting it to VCC the power will find some internal paths and eventually destroy your chip.
that 10nF?
Do you understand what I said about the diagram? Is the reset circuit really wired that way?
What regulator are you using? If it's a 7805 you MUST put 100nf caps at it's input and output pins or it will go crazy and oscillate.
Are you powering up the board via JP2? While the STK500 can provide power to the board the ICE does not.
i am sorry i am still newbie about this... yes the circuit is wired that way...btw i have removed 10nF capacitor and its connection to reset pin and no i don't power my device from JP2 but from 2 pin separated from JP2, VCC and GND on JP2 is only used as voltage detector....but still i am unable to detect my chip signature...maybe it is the order of my pin which is wrong?? since i am using jumper to connect my atmel ICE to the target device...do you know the right order of the 6 pin cable that comes with my atmel ICE?
ok finally i almost solve my problem...now i can read my chip signature...but the problem now is i have to turn off and turn on the target again if i want to program or at least read the signature...do you know how to solve this issue?
Is your reset circuit still looking like in the schematic you posted above?
not anymore...i have removed the resistor and 10nF caps and short that caps to to connect the 2 22pf caps near XTAL..what should i do next?
Uncomprehensible. Draw a new schematic and show it here.
i have a same problem i think.First time read device signature correctly and program it.But second time it would fault.Can you explain it how to solve it?
Normally i use pull up resistor from RESET pin to VCC(10K) and connect 18pf capacitor from RESET pin to GND.
That is usually a symptom of incorrectly programmed fuses. The 18pf reset cap is probably so small as to be insignificant. But, if you programmed fuses for a crystal and do not have a crystal, or if you programmed it for an external oscillator but have a crystal connected, what you described will happen.
There are tutorials, here, on fixing this "issue".
Hi Jim,
my fuses and lock bits;
extended 0xFD
high 0xD9
low 0xFF
Lock bit 0xFC
CKSEL 8.0mhz 16k+65ms
i programmed fuses for a crystal and i have an 16mhz crystal with 18pfx2 capacitor
P.s: my crystal is 16 mhz and ground capacitors are 18 pf.And everything is correctly connection.Anyway i can program it for 1 time otherwise i think i would never programm it if i have a connection fail.
What device are you working with? M328P or something else?
my chip is atmega2560 .Programmer atmel-ice.
Do you have plenty of caps on your AVR power pins?  Where is your schematic?...no schematic=not much help.
Before you changed to use the crystal, did it program ok several times with no problem?  Did the problem start happening only after you selected the crystal mode?
here is schematic
