Disabling and Enabling Global Interrupts
3 posts / 0 new
Will the following two assembly commands work to disable and enable global Interrupts on the SAMA5D44?
asm("cpsie if");
asm("cpsid if");
I know they work for the SAM 7
If not what are the instructions to achieve this?
Thanks lads.
have you read the compiler info? Usually these are __disable_irq() or something like that.
right lads.  I have the following code:
//         Startup routine
	.align      4
	.arm
 * DISABLE INTERRUPTS
	cpsid if
/* Exception vectors
	.section    .vectors, "a", %progbits
resetVector:
/* Reset */
	ldr     pc, =resetHandler
/* Undefined Instruction */
	ldr     pc, =undefined_instruction_irq_handler
/* Software Interrupt */
	ldr     pc, =software_interrupt_irq_handler
/* Prefetch Abort */
	ldr     pc, =prefetch_abort_irq_handler
/* Data Abort */
	ldr     pc, =data_abort_irq_handler
/* Reserved for future use */
	.word   0
/* Interrupt */
	ldr     pc, =irqHandler
/* Fast interrupt */
	ldr     pc, =fiqHandler
	.section    .text
/// Handles a fast interrupt request by branching to the address defined in the
/// AIC.
fiqHandler:
	/* Inform RTOS that Interrupt has been entered */
	stmfd   sp!, {r0-r12, lr}
	bl		enter_irq
	ldmia   sp!, {r0-r12, lr}
