Hello everyone:)
So now I have learned how to use external interrupts in assembly language. And I learned how to use timer interrupts as well (with CTC config). Now I think this is enough to build a line following car. We can use ir sensors with external interrupts and the motor speeds can be adjusted with timer interrupts. I created simple circuits with external interrupts and learned how to change the duty cycle with timer interrupts.
So code wise I have to combine these two things I have learned. If someone could supply me with a skeleton code, That would help so much.
Here's what I can think of.
Edit: I updated this post with the final working code. Hope someone will find this helpful :)
.ORG 0x0 ;location for reset JMP MAIN .ORG OC2Aaddr JMP timer2_compareMatch_A_Routine .ORG OC2Baddr JMP timer2_compareMatch_B_Routine .ORG OC0Aaddr JMP timer0_compareMatch_A_Routine .ORG OC0Baddr JMP timer0_compareMatch_B_Routine MAIN: LDI R20,HIGH(RAMEND) OUT SPH,R20 LDI R20,LOW(RAMEND) OUT SPL,R20 //Setting input ports for sensor input CBI DDRB,2 CBI DDRB,3 //Set //Right Motor Configuration with Timer2 SBI DDRB,1 SBI DDRD,5 SBI DDRD,4 SBI PORTD,5 CBI PORTD,4 LDI R20,239 STS OCR2A,R20 LDI R20,(1<<WGM21) STS TCCR2A,R20 LDI R20,0x01 STS TCCR2B,R20 LDI R20,(1<<OCIE2A) | (1<<OCIE2B) STS TIMSK2,R20 //Right motor configured //Left Motor Configuration with Timer0 SBI DDRB,0 SBI DDRD,7 SBI DDRD,6 SBI PORTD,7 CBI PORTD,6 LDI R20,239 OUT OCR0A,R20 LDI R20,(1<<WGM01) OUT TCCR0A,R20 LDI R20,0x01 OUT TCCR0B,R20 LDI R20,(1<<OCIE0A) | (1<<OCIE0B) STS TIMSK0,R20 //Left Motor Configured SEI HERE: SBIS PINB,2 //Right sensor LDI R20,100 OUT OCR0B,R20 SBIC PINB,2 LDI R20,30 OUT OCR0B,R20 SBIS PINB,3 //Left sensor LDI R21,100 STS OCR2B,R21 SBIC PINB,3 LDI R21,30 STS OCR2B,R21 JMP HERE timer2_compareMatch_A_Routine: ;Controls right motor CBI PORTB,1 RETI timer2_compareMatch_B_Routine: ;Controls right motor SBI PORTB,1 RETI timer0_compareMatch_A_Routine: ;Controls left motor CBI PORTB,0 RETI timer0_compareMatch_B_Routine: ;Controls left motor SBI PORTB,0 RETI
