AVRfreaks Design Notes
16 posts / 0 new
Total votes: 2
Way back when, in the mists of time, the old 'freaks site had a pile of useful Design Notes. Some of them a now a bit dated but there is a wealth of useful information in them. They are, in theory, still available on the old site ( as long as it is online). To bring them to a wider audience's attention I'm posting them all here.
With thanks to fellow 'freaks sbennett,  Bingo600, and Ntano for filling in some of the blanks.
DN001  Using STK500 to program external target STK300
DN002  Providing correct input voltage to the mega103L in STK300
DN003  AVR sleep modes
DN004  Common use of the AVR hardware UART
DN005  Using AVR Analog Voltage Reference (AREF)
DN006  AVR Memory Contents After Sleep and Reset
DN007  Little and Big Endian
DN008  Efficient I/O handling with bitfields
DN009  Using the ATtiny15 High-speed Timer
DN010  Manual AVRISP firmware upgrade
DN011  Manual JTAG ICE Firmware Update
DN012  Writing the Cal. Byte to the OSCCAL Reg in ImageCraft ICCtiny
DN013  Using ATmega8 Async. T/C Osc. with a 32 kHz X-tal on STK500
DN014  Flash Tables for AVRs without the LPM Instruction
DN015  Getting Started with the STK100 under Windows 95/98/NT/2000
DN016  How to distinguish ATmega128 from ATmega103
DN017  Calibrating the Internal RC Oscillator Using the STK500
DN018  Calibrating the Internal RC Oscillator
DN019  Upgrading the Firmware on STK500
DN020  Understanding AVR Fuses and Lock bits
DN021  Using the Built-in ADC in AVR
DN022  I/O Port Details
DN023  Programming Problems Using STK200/300 Programmer
DN024  Timer/Counter Basics
DN025  SPI Setup and Hold Times
DN026  Serial Port Connection
DN027  A Simple FSK modem Freq. Measuring and Generation
DN028  Using External SRAM with Small AVR Devices
DN029  FIFO Buffer - by Christoph Redecker
DN030  Frequency Synthesizer
DN031  Non-blocking Timers
DN032  AVR Boot Loader
DN033  DAC Utilizing ADC
DN034  IO Pin Config
DN035  Bidirectional SPI
DN036  Virtual Instrumentation
DN037  Custom Graphic LCD Characters
DN038  Fast Look-up Table Driven 16-bit CRC Routine
DN039  Sound Sample Play Back
DN040  Connecting an AVR Controller to CAN
DN041  Interfacing Parallel FRAM to AVR Microcontrollers
DN042  Efficient Handling of RS-485 Timing Issues
DN043  A String Display Routine
DN044  Using Trinary Encoding to Reduce Pin Wastage
DN045  Using Shift Registers to Increase the Number of I/O Pins
DN046  Timer Interrupt with a Maximum Accuracy
DN047  The Pin Adder
DN048  I2C Bus Sniffer
DN_015 still to find.
DN_021 to DN_030 complete.
DN_031 to DN_040 complete set with some software files.
DN_048 is the last one published.
Total votes: 2
Thanks a lot for this effort!
The whole smash as a single zip.
Minus the missing bits, of course.
EDIT:  Added DN_012 (found by sbennett here) to the .zip:
https://www.avrfreaks.net/comment/2632026#comment-2632026
EDIT2:  Added DN_013 (found by Bingo600) to the .zip:
EDIT3:  Added DN_023 (found by Ntano) to the .zip:
Apparently they don't stop at #48?:
https://www.avrfreaks.net/forum/design-notes-atmel
EDIT:  Although I see that perhaps this is actually referring to " DN024  Timer/Counter Basics" ... ?
Uploaded new .zip in #7 to include DN_012 found by sbennett here:
https://www.avrfreaks.net/comment/2631826#comment-2631826
Uploaded new .zip in #7 to include DN_013 found by Bingo600 here:
https://www.avrfreaks.net/comment/2631346#comment-2631346
The order of posts here is messed up, the seemingly newest post is #2.
Order of posts, time/date as not logged in.
Brian Fairchild  Posted : Fri. Feb 1, 2019 - 12:22 PM  #1
Brian Fairchild  Posted : Sun. Feb 3, 2019 - 07:16 PM  #2 ?
Brian Fairchild  Posted : Fri. Feb 1, 2019 - 12:36 PM  #3
Brian Fairchild  Posted : Fri. Feb 1, 2019 - 12:43 PM  #4
Brian Fairchild  Posted : Fri. Feb 1, 2019 - 12:48 PM  #5
Moe123           Posted : Fri. Feb 1, 2019 - 12:31 PM  #6
joeymorin        Posted : Sun. Feb 3, 2019 - 03:10 PM  #7 ?
joeymorin        Posted : Sat. Feb 2, 2019 - 06:25 PM  #8
joeymorin        Posted : Sun. Feb 3, 2019 - 05:26 AM  #9
joeymorin        Posted : Sun. Feb 3, 2019 - 03:11 PM  #10
A pdf archive of the thread attached.
Thanks Brian, and collaborators!  What a wonderful and nice thing to do for all of us.  Truly Useful.
Uploaded new .zip in #7 to include DN_023 found by Ntano here:
https://www.avrfreaks.net/comment/2637031#comment-2637031
We were able to dump the server, and I put the content here: https://community.atmel.com/wiki...
 Seems that we are also missing #015 :)
Let me know if you want more content there...
:: Morten
Thank you Morton!  It's a treat to have that all in one place.  Now all we need is to get the newbies to check out Wiki first.
It would help if the Wiki actually worked properly:
sad
Hasn't work properly for years:
https://www.avrfreaks.net/forum/cant-edit-wiki
