Programming the ATMEL328 (DIP version) using the UNO w/ surface-mount IC...?
4 posts / 0 new
Hello, I have a nice sketch on my UNO and I want to program it on a bare ATMEL328 (the DIP version) and run it independent of the board, with my own circuitry.
I see there are ways to program the separate 328 using an existing board - you can make connections from the UNO to the 328 on a breadboard. https://pnrstatus.vip/
However, it's my understanding that you need to remove the existing ATMEL from the board to do this - true? And since I have the surface mount IC, I cannot use this technique?
... So if I want to program the ATMEL itself, I need to buy the pocket AVR programmer? There's no other way? Yes it's not that expensive but if I could use existing equipment I'd be happier :) mobdro
Thanks! https://sarkariresult.onl/
 No.  You leave the AVR in the existing board for the "programming" step.
There's a hack where you can take out the AVR and use an Uno board as a USB/Serial converter, but that's usually unnecessary (and in most cases can be accomplished by tying the Uno RESET signal to GND, rather than removing the chip.  (the only thing that doesn't allow is the automatic reset during the Arduino serial bootloader "upload."  But you don't really need that if you have the programmer connections made.))
One of the better tutorials is here: http://www.gammon.com.au/breadboard
VoltarGomes wrote:
a bare ATMEL328
would need the bootloader installing?
EDIT: this is covered in the tutorial westfw linked.
Note that the name of the chip is "ATmega328"
https://www.microchip.com/wwwproducts/en/ATmega328
although it does show using a 3.3V FTDI cable when running the AVR at 5V !
surprise
