RTC MONTH NAME DISPLAY
57 posts / 0 new
Pages
Serves me right for cutting and pasting!!
The clipboard sure knows how to generate errors. The keyboard takes care of the rest.
Thanks all. I am marking kartman's #50 as the answer and once again thanks for the help.smiley
anshumaan kumar
Kartman wrote:
 learn how to learn. learn how to solve problems. These are invaluable lessons.
and, sadly, rare skills.
sad
awneil wrote:
rare
Yes. indeed rare but one can induce these in him/her by practisesmiley.
anshumaan kumar
Total votes: 2
Don't forget about some of the 1-based numbers you are getting from the rtc. Converting the month from bcd-decimal also gets you 1-12 where your month string table needs 0-11.
You will figure that out soon enough I guess, unless you don't know what month it is. Then I guess you will discover a new month name in a month or so.
Pages
