SAMD51 stdio redirect : Framing error
6 posts / 0 new
Created a new project from Atmel start by just having a Target_IO USART and STDIO REDIRECT.
main() initializes uart and redirect as below.
void stdio_redirect_init(void)
    usart_sync_enable(&TARGET_IO);
    stdio_io_init(&TARGET_IO.io);
But if i print something using printf() from main function , my serial port terminal app disconnects showing "Framing Error : 104"
Could some one help with this query ?
Maybe a clock problem. You could attach the start project.
/Lars
Thanks. I tried to recreate the project from studio with just an stdio_redirection module.
This time does not seem to print anything nor there is an error.
Both SERCOM usart config and Serial terminal on PC have identical configuration - 115200 baud/8 bit char/ 1 stop bit.
Attached my start project. Pls have a look.
You surely do not want usart_SYNC_enable() (which START foolishly defaults to...)
You mean remove usart_SYNC_enable()  or do it later. It seems to enable the SERCOM.
Recreating the project in Another version of Atmel studio seems to have fixed the problem. Ready to move on though i don't understand how or why it was fixed.
Thanks for your help.
