Atmel AVR Bootloader?
15 posts / 0 new
Is there a published Atmel bootloader for the ATmega chips.
I have created a working bootloader in assembly language from ATmega328 manual.
I have been looking to see if there is a pulished/downloadable bootloader from Atmel
Bob Macklin
Seattle, Wa
The Arduino bootloader?
 Maybe now they will have one!  Have you considered Optiboot, used by many...but not an "Atmel"  proper bootloader
Yes. Since 2004 there has been AVR109...
Try the project section here. Must be 10's of the things. But as above (at least for Arduino class chips) the defacto standard these days must be Optiboot.
But you know how it's said that every programmer has a design for a new programming language itching to get out? I think the same is true of bootloaders! Here's my contribution to the world...
https://spaces.microchip.com/gf/...
I know about the Arduino bootloader. I was wondering if Atmel had a published bootloader.
I started programming the ATmeaga chips about 2005. Ardiuno did not exest at that time.
I was using the AVR IDE ver 4 at that time. I read in the 328 user guide about the bootloader. So I created on that I have been using.
And it still works.
I was just wondering if there was an offical Atmel bootloader.
Bob Macklin
Seattle, Wa
cklinbob wrote:
 I was wondering if Atmel had a published ...
The way to answer that question is to go to the Product Page for the device in question; eg,
https://www.microchip.com/wwwproducts/en/ATmega328P
Then look at the 'Documents' tab
There you will find three "Bootloader" documents ...
AVR109 (which basically IS the Arduino bootloader in fact - same protocol anyway). Also look at AVR OSP.
Then you should recognise a CD like this:
By the wonders of the new-fangled interwebs, all that stuff is now available at the click of a browser via the Product Page
Yep - there it is:
awneil wrote:
look at the 'Documents' tab   There you will find three "Bootloader" documents ...
clawson wrote:
AVR109
Yep - that's one of them.
Alas, AVR109 and the STK500 (used by the Arduino Bootloader) are not even close to be the "same protocol."
For example, in STK500v1, the 'V' command is STK_UNIVERSAL (allows the host to send an arbitrary SPI command), but in AVR109 'V' (more sensibly?) returns the Software Verson.
AVR109 is an app note demonstrating how to write a bootloader.  And IIRC it was used on the "Butterfly" Eval board.
But my general impression is that it never quite reached the status of a supported "Atmel Provided Bootloader" in the same way that SAM-BA did.
If you need an AVR bootloader, you'd probably be better off with Optiboot - it has a bunch of developers that have been poking at it, and a stunning number of users (via Arduino.  Although most of them are running a much older-than-current version.)
Ah yes, failing brain cells - I was thinking Butterfly, not Arduino. It's the Butterfly bootloader that is AVR109 based.
Hello. Your link:  https://spaces.microchip.com/gf/project/sdbootloader/  doesnt work anymore.
Have a nice day
Well, that was over a year ago!
If you go to  https://spaces.microchip.com/  it suggests that you need to log in:
Get Started with Microchip Spaces
Login - Access Spaces using your Microchip credentials.
Did you try that URL when you were logged-in ?
Have a nice day
Yeah I know - I was actually a fan of spaces.atmel.com but it seems few others were so it died a lingering death. Thankfully Amtle/Microchip gave me some last minute access so I could retrieve my projects there and I moved them to:
https://github.com/wrightflyer/
So the SD booloader now resides (complete with existing SVN history!) at:
https://github.com/wrightflyer/sdbootloader
