1:10 Transformer; to match between amplifier and a piezo-disc
21 posts / 0 new
I'm trying to connect a 4 ohm's amplifier to a 45 ohm's piezo-disc and I would like to use a 1:10 transformer in between the amplifier and the disc.
Does anybody have a suggestion of a good (low cost) 1:10 transformer to use?
All the Best,
Kim
You do understand that that Piezo is not for audio use, but ultrasound?
Yes, but going to use it in the range of 5-15 kHz and at a high voltage.
// Kim
I couldn't locate a datasheet for the piezo(did not look very hard for it either) but do you mind me asking what the application is?
Resonant frequency fr: 235 KHz±2%
How are you going to use it at 5-15 KHz, when it is not suited for that range?  You should get an audio piezo!
 the resonant frequency is the operating frequency at which the piezo material vibrates most readily and converts electrical energy into mechanical energy most efficientl
Yes, I do know that.
Does this application have to do with this:
JIm
JIm
No, it does not.
Does anybody might have an answer to the question I posted?
All the Best,
Kim
Relax, the other thread bears a lot of similarities, thats why I asked as I also do not want to start another thread on possibly the same topic.
Short answer is, you need to look for a transformer that suits your needs.  I suggest yu check out Mouser and Digikey to see if they already have a stock item.  IF not then the next course of action is to contact manufacturers to see if they make one, or wind your own.
JIm
EDIT:
Check here:
https://www.electronicplus.com/c...
If you google 4 ohm to 45 ohm audio transformer you will find there are several companies out there that make items close to what you are looking for.
Ok, I was never very good with PNP transistors, or with transformers...
That said, isn't a transformer's impedance ratio related to the square of the voltage ratio?
If you are estimating a 1:10, (instead of 1: 11), impedance matching ratio, then the voltage ratio, (and turns ratio), would be the square root of 1/10 ratio.
Others can correct this if I have it wrong.
Edit: Typo
No need for correction, you have it right.
A 45 ohm load connected through a 10:1 ratio transformer would present a 0.45 ohm load to the amplifier (assuming said transformer is suitable for the frequencies involved).
Big ALERT:
Your 45 ohm piezo at 235KHz WILL NOT be 45 ohms at 5-15KHz. It is probably WAY different, though nobody here can tell you what it will be. What ever it is,  it won't be the same at 5KHz as it is at 15KHz.
This piezoelectric driver application note from Accel Instruments has a paragraph on transformer boosting.
https://www.accelinstruments.com/Piezo/Piezo-Driver.html
Of course the application note is centered around their products: TS200 Modulated Power Supply and TS250 Waveform Amplifier
Prices start at $1K.
Like the others, I think you're using the wrong part for the wrong job. I'd suggest getting piezo tweeter.
Anyways, you could use a power transformer 120:12V gives a 10:1 turns ratio.
Kartman wrote:
I think you're using the wrong part for the wrong job. I'd suggest........
The OP has made it very clear:
The OP does not seem to be interested in anyones opinions regarding the functionality of the components.  Only a matching transformer.
I suggest we keep to the topics question of a 1:10 transformer supplier.... smiley
Thank you Jim! I think one of the links you provided will do "the job".
JIm
EDIT:
Check here:
JIm
That one was my own "home-test-project" which I did before what I'm doing now. It actually went well in the end. :D
I have told him about resonance frequency, etc. etc. BUT, he will not have it.
You need to have a conversation as to why he isn't listening to your concerns. That is a bad sign!  Remember the challenger disaster?
https://www.npr.org/sections/thetwo-way/2016/01/28/464744781/30-years-after-disaster-challenger-engineer-still-blames-himself
The night before the launch, Ebeling and four other engineers at NASA contractor Morton Thiokol had tried to stop the launch. Their managers and NASA overruled them.
That night, he told his wife, Darlene, "It's going to blow up."
When Challenger exploded 73 seconds after liftoff, Ebeling and his colleagues sat stunned in a conference room at Thiokol's headquarters outside Brigham City, Utah. They watched the spacecraft explode on a giant television screen and they knew exactly what had happened.
https://www.npr.org/sections/thetwo-way/2012/02/06/146490064/remembering-roger-boisjoly-he-tried-to-stop-shuttle-challenger-launch
I think the boss man is trying to get you to think and solve a problem. If you have some engineering background, then this might make sense. I was mentoring a graduate and i would always push him to fall back on the theory he’d learnt.
The conversation would go something like this:
S: hey boss, i’m not getting much output from this piezo
M: what is the impedance of the amp and the piezo?
S: four ohms and 45 ohms
M: sounds like you need a transformer!
S: where do i get one of these?
M: how about doing some calculations first?
S: how do i calculate it?
Then I’d put my grumpy old man hat on and say “in my day, i’d find my old textbook and give it a read - you have Google”
The moral of the story is the transformer you ‘think’ you want is not the one you ‘need’. I suggested a power transformer as there might be something in the junk box or cheaply and easily obtained. Say 120:12V 1A. Its not necessarily the solution, but it something you can try.
Having looked inside a cheapy piezo siren, the solution is usually an ‘auto transformer’ with a ferrite core.
