Embedded Code generator
11 posts / 0 new
I have develop a QPSK transmitter in simulink. After thoroughly testing in simulink, its output I generated a C code for it using embedded coder(AVR 32 bit).
The C code I compiled in atmel studio 7.0 and it build without errors.
My question is that how can I simulate the code files after building them?(Rather I want to compare simulink output with c code output).
I tried break points at the required variable output but can not(confused) observed any output.
Code is generated for the given block as in .png extension.
Kindly give a look to the files attached.
Best Regards
Rizwan
Best Regards
Rizwan
Use the simulator in AS7  Easy.
Did you create a watch window with the variables you want to observe?  Keep in mind the watch window will not display local variables.
I will not open an .rar file.  ZIP files though I will.
Jim Thanks for your prompt reply.
I have attached .zip files too.
Its a build project in AS7.
i just want QPSK RRC Shaped variable to be observed as an output in AS&.
If you want simulink model than let me know I will add that too
Rizwan
Best Regards
Rizwan
Studio spits back the following in teh watch window:
QPSKRRCShaped..........Unknown identifier
 In your code you have this:
  rtY.QPSKRRCShaped = rtDW.PipelineRegister3_DSTATE[0];
So in your watch window I changed what you have to:
  rtY.QPSKRRCShaped
and I now have this in the Value cell:
{cint16_T@0x05e4}
Which should  let you see what you are looking for
JIm
EDIT:
I'm a little confused.(not the first time I have typed that)
What exactly is "rtY.QPSKRRCShaped" anyway?  The code says its an output, but I don't see it called out anywhere other than the one line in HDLTx.c..
Hi Jim,
This Variable is an output in Simulink model which must show complex IQ data .Screen shot for the output and spectrum is also shown as an attachment.
Arrow shows the output RRC QPSK shaped.
Best Regards
Rizwan
Best Regards
Rizwan
Thats an analog signal you are spitting out of the XMEGA pin?  I still do not see it anywhere in the code other than that spot I pointed to.
Dd you try the suggestions I made in post #4 to see if you get what you are looking for?
Hopefully another Freak smarter than I can jump in here.
Hi Jim ,
thanks for the reply.Actually it is a digital signal which have I/Q data.
As I placed RRCQPSKshaped variable it showed real and imaginary part but all zero in watch window(as you specified).
RRCQPSKshaped should change its state after every 5uSec (rt_Onestep).
when I place breakpoint it never get hits on the specified variable.
Kindly guide me whats the issue in its execution.
Regards
Rizwan
Best Regards
Rizwan
how should I assign rt_onestep to clocking frequency
Best Regards
Rizwan
have a loop with a delay:
  _delay_us(3); //we'll assume the rest of the code takes 2us
 do_rt_onestep()
or use a timer
Is it possible for you so look into the zip attached?.
In code it says
" /* Attach rt_OneStep to a timer or interrupt service routine with
   * period 5.0E-6 seconds (the model's base sample time) here.  The
   * call syntax for rt_OneStep is
   *  rt_OneStep();
How can I do this in main file.
Actually I want to observe a variable output QPSKRRCSHaped,it should change values.
I set breakpoint but it never get hits.
Kindly see if you can point out the issue.
Best Regards
Rizwan
I love people who say 5E-06 when they mean 5 microseconds.
Anyway you could setup up a timer in CTC mode and calculate a COMP value so it enters the interrupt every 6us but what micro is this. The fastest AVR8s aare 16MHz, 20MHz or in the case of Xmega 32MHz. Let's take 20MHz. At that speed a CPU cycle is 0.05us so there are 100 cycles in 5us. That will give you time to get into a time interrupt, preserve the registers, call the rt_Onestep() function then unwind but the CU won't have a LOt of time for actually doing anything else.
Having said that I notice in #1
so which AVR is this in fact - a UC3? If so which one and what is the clock speed?
