Clap Clap Switch
7 posts / 0 new
Hi there;
Firstly sorry about my english. Im new to AVR microcontroller. Im using Arduino mega and im programming it with Atmet studio 7. I'm trying to understand how to use registers by examining the codes in several projects. I find a code about clap switch but I can't understand some thing about code. Let me share code which I found for u. What is the purpose of the variable I painted with yellow color. why did he give that variable a value of 1 in the external "ISR" interrupt. I'd appreciate it if you could enlighten me on this.
* Copyright (c) 2019, Łukasz Marcin Podkalicki <lpodkalicki@gmail.com>
  * ATtiny13/050
  * Clap-Clap Switch.
  #include <avr/io.h>
  #include <avr/interrupt.h>
  #include <util/delay.h>
  #define LED_PIN PB0
  #define MIC_PIN PB1
  static volatile uint8_t state = 0;
  int
  main(void)
  uint8_t reset = 0, claps = 0;
  /* setup */
  DDRB |= _BV(LED_PIN); // set LED pin as output
  MCUCR &= ~(_BV(ISC01)|_BV(ISC00)); // trigger INT0 interrupt when low level detected
  GIMSK |= _BV(INT0); // enable INT0 interrupt
  sei(); // enable global interrupts
  /* loop */
  while (1) {
  /* if single clap detected then start procedure */
  if (state) {
  claps++; // increment claps count
  if (claps == 1) { // if it's first clap,
  reset = 0// set reset counter to zero
  else if (claps == 2) { // if it's second clap,
  PORTB ^= _BV(LED_PIN); // toggle LED on/off
  claps = reset = 0// and set initial values
  state = 0// for each clap detection, reset state
  _delay_ms(200); // and wait 0.2s.
  /* if rest counter is max (1s) then set initial values */
  if (++reset >= 10) {
  claps = state = reset = 0;
  _delay_ms(100); // loop delay
  ISR(INT0_vect)
  state = 1;
It looks like "state" is a flag that is set when the micro "hears" a clap sound from the microphone connected to the INT0 pin of the micro.
Note it is a "volatile" variable because it is used in both the interrupt service routine() as well as main() and its value can change at any time.
Hope that helps.
Thank u for your comment. Can I ask one more question.  I couldn't understand exactly what I wanted to do with the line of code I shared in the appendix. Is the value of the state variable "1" in the ISR function because it is desired to be set each time an interrupt occurs?
Indeed.
Not a very helpful or informative name!
And this shows why you should comment your variable declarations with a description of what they do.
It's just a binary flag - it is either set, or it isn't.
Please see Tip #1 on how to properly post source code.
atahan wrote:
the appendix
What "appendix" ?
 * ATtiny13/050
 * Clap-Clap Switch.
#define LED_PIN PB0
#define MIC_PIN PB1
int
main(void)
    /* setup */
    /* loop */
    while (1) {
        if (state) {
                reset = 0; // set reset counter to zero
            } else if (claps == 2) { // if it's second clap,
                claps = reset = 0; // and set initial values
            state = 0; // for each clap detection, reset state
ISR(INT0_vect)
    state = 1;
I reshared the source code as you suggested.  The word "appendix" means additional.
Your use of the word 'appendix' doesn't quite mean what you wanted to english speakers. Nevertheless, what you intended to say is clear now.
With the code you posted, the ISR is superfluous - it adds no real value. The writer could have simply tested the interrupt flag rather than using 'state'. eg:
 * ATtiny13/050
 * Clap-Clap Switch.
#define LED_PIN PB0
#define MIC_PIN PB1
    /* setup */
    /* loop */
    while (1) {
        if (GIFR & (1<<INTF0))    //was there a change on the INT0 pin?
            GIFR = (1<<INTF0); reset the interrupt flag
            if (claps == 1)
        if (++reset >= 10)
