ADC Attiny44
12 posts / 0 new
Hi, how to work with 2 analog sensors in a microcontroller. For example, a carbon monoxide sensor and a temperature sensor?
Have you been to the tutorial section of this site?   https://www.avrfreaks.net/forum/...
Bottom line is that most AVR have ADMUX which is a multiplexer. You can usually connect any one of up to 8 (depending on pin count) analog inputs to the single ADC and read that channel. This does of course mean you cannot make two reading in parallel but as a reading can typically be done in 65us then doing one after the other looks almost instantaneous anyway and it won't matter with slow changing inputs like CO and temp levels.
I read the data from one channel, they are saved, then I install the second channel, and where is this data stored from the second channel?
There are App Notes with code that may also be of help, ADC specifically AVR126 here: https://www.microchip.com/wwwApp...
Yes, most people have an ADC_Read(n) style function where you pass the number of the channel to be read as an input (and it in turn is used to set ADMUX before making the reading that is returned). So you might have CO on channel 2 (ADC2) and temp on ADC5 so you ADC_Read(2) to read the CO and ADC_Read(5) to read the temp.
The following sketch will demo how to read two analog inputs, save to two variables and output them to the serial port, should get you started.
  Analog input from two channels serial output
  Reads two analog input pins, prints the results to the Serial Monitor.
  The circuit:
  - temp sensor connected to analog pin 0.
  - CO sensor connected to analog pin 1
// These constants won't change. They're used to give names to the pins used:
const int TempSensor = A0;  // Analog input pin that the Temperature sensor is attached to
const int COSensor = A1;    // Analog input pin that the CO sensor is connected to
int TempSensorValue = 0;        // value read from the temp sensor
int COSensorValue = 0;          // value read from the CO sensor
void setup() {
  // initialize serial communications at 9600 bps:
  Serial.begin(9600);
void loop() {
  // read the analog in value:
  TempSensorValue = analogRead(TempSensor);
  delay(10);
  COSensorValue = analogRead(COSensor);
  // print the results to the Serial Monitor:
  Serial.print("Temp sensor = ");
  Serial.println(TempSensorValue);
  Serial.print("CO sensor = ");
  Serial.println(COSensorValue);
  // wait 2 milliseconds before the next loop for the analog-to-digital
  // converter to settle after the last reading:
  delay(2);
What are you talking about?  Once you read the sensor ADC, YOU determine where you want to save the values.  Do you want to save one reading or 500 readings?
thanks for the help
Which sensor should i use for human speech recognition in my project "voice control home appliances using pic16f877" like sensor detects human commands "fan on", "light on" etc
Why is your question here? It has nothing to do with the tiny44.
Forget about all that, use this:
https://aiyprojects.withgoogle.com/voice/
My teacher assign me a project on "voice control home appliances using micro-controller and sensor"  and now i don't know which sensor should i used that detect human commands like light and controlling fan speed through human commands in Proteus and coding in mikroc.
