Solved: Help on a simple exersise
18 posts / 0 new
Dear Community
I am working on an exersise to learn about timer0 with interrupt.
Everything worked fine so far, until I tried to do some modification to make the code "smarter" I got stopped by a problem and I just dont see the mistake I made.
The problem is within the delay funktion, it never exits out of the function.
How it should work.
I configured timer0 for interrupt and prescaler 1024 and compare it with the value stored in OCROA, if the value is equal I get an interrupt every 10ms.
The interrupt I want to use in a "for" loop to iterate 50 times to obtain 500ms as the final result and afterwards flash a LED. In the interrupt service routine I just set a flag: t010msFlag = 1;
The problem I found out is, in the little delay routine.
Maby one of your skilled eyes catch the problem.
Thanks for your help
regards
Juergen
#include <avr/interrupt.h>
#define LED_BLINK_TIME 50 /*number of 10ms delays */
uint8_t ledDelay = LED_BLINK_TIME; /*counts the number of 10ms delays */
volatile uint8_t t010msFlag;
ISR(TIMER0_COMPA_vect)
  t010msFlag = 1;
void delay()
	uint8_t i;
	for (i=0; i=LED_BLINK_TIME; i++) // iterate 50 times, 50 x 10ms = 500ms
				while (t010msFlag = 0)
				//do nothing, wait for interrupt,it should come every 10ms
			t010msFlag = 0; //reset t010msFlag to 0
/* Haupt */
  DDRD |= _BV(PORTD4); /* D4 set as output */
  /* Set up Timer 0:
     - prescaler / 1024
     - generate interrupt when OCR0A matches TCNT0
     - load OCR0A with the delay count to get 10ms delay
  TCCR0A = 0b00000010; /* TC0 mode 2, CTC - clear timer on match A */
  TCCR0B = 0b00000101; /* clock by F_CPU / 1024 */
  OCR0A = 155; /* = F_CPU / 1024 / 100 - 1 */
  TIMSK0 = 0b00000010; /* enable OCIE0, match A interrupt */
  sei();
	while (1)
		delay();
		PORTD ^= (1<<4); //LED on PortD pin 4 is blinking
}/* end main() */
Did you mean == in the 'for'?
Not =
Don't you mean:
for (i=0; i<LED_BLINK_TIME; i++) // iterate 50 times, 50 x 10ms = 500ms
Without adult supervision.
Thanks for your answer.
I changed i==LED_BLINK_TIME
And now something interessting happend.
1. When I switch in the debugger to pause the desasembler opens up,no idea why.
2. When I start single steping and I pas the delay function it started to run by its one but not with the correct time interval (ca 200ms instead of 500ms).
3. When I also write i==0;and i == LED_BLINK_TIME; I can again do a single step but can not enter into the function it steps over eventhough I used step into
Well, I think thats what I have to investigate
Thanks very much for the tip.
I will flash it in a real system and see what happens
rergards
juergen
I just tried
i<LED_BLINK_TIME;
same problem,I can single step also into the function, but it wont exit.
I will try a real system tomorow as I need a new NANO, for debuging I had to modify my NANO isolating the reset pin for the Atmel-ICE
regards and thanks
Juergen
this should be:   while(t010msFlag == 0)
Remember "=" equals assignment, while "==" is compare
PS: don't fret it, we have all done it!
Indeed.
That's why the compiler can give a warning about it!
If you weren't getting those warnings, then I strongly suggest that you enable them!
You aren't clearing the interrupt flag in the ISR. It's not going to work as you expect it to if you don't do that.
Thanks for your help,its working now.
The problem was indeed
1. the == in "while (t010msFlag == 0)"
2. i < LED_BLINK_TIME; = or == did not work
About clearing the interrupt flag, I think this is done by the timer automaticaly.
Thanks to all of you
regards
Juergen
You are right. Old school tiny/mega generally auto clear their interrupt flags on entry to an ISR() while the newer style (Xmega based) AVR-0/AVR-1 usually require manual clearing. So it kind of depends which model it is - but your's appears to be "old style" so should be OK.
PS do you want to tell us more about the intention of:
that creates an "ledDelay" but then it's never used. It's interesting because in C++ you tend to avoid pre-processor constants and instead this might have actually been done as:
static const uint8_t LED_BLINK_TIME = 50; /*counts the number of 10ms delays */
The fact that it is "static const" effectively tells the compiler "you don't need to actually create this - just use 50 whenever I mention this" but the upside of doing it as a "variable" is that it's not just 50 but 50 with the type uint8_t so it can later be type checked.
That's an area where C++ differs from C, isn't it?
A 'C' compiler will (may?) actually create an "object", and read from it.
At the moment I try to learn C and the above code is just exercises and has no use. In fact I have not quite understood what you where telling me, I am a beginner in C, but I will finde out.
Next exersises is a real project.
There is a lawn harvesting maschine and I have to messure the distance the machine travels and after every meter I have to activate a relay which again activates a cutting knive.
I get some impulses from a decoder which delivers ca.100.000 per revolution of the wheel. I guess I have to read ca.100.000 impulses/sec. Lets say after two revolutions I have to activate the relay.
So I will listen to the decoder by INT0, count the impulses and after ca. 200.000 counts activate the reay.
I think its a good exerciseand it also has some practical use.
Juergen
PS: sorry for my spelling
As frequently suggested by many, it would probably be better to do that on a "conventional" platform - eg, a PC - rather than also have to deal with the added complications of a small embedded microcontroller.
Most of the issues above have been standard 'C' stuff - nothing specific to AVR.
In fact I have not quite understood what you where telling me, I am a beginner in C, but I will find out.
Again, that "finding out" will be a lot easier on a "regular" computer.
Next exercise is a real project.
I think you have a little way to go before that.
I think its a good exercise and it also has some practical use.
I think it may be a bit much to start with - see Tip #6 for some Beginner's "Getting Started" suggestions
Also see Tip #5 for how to mark a thread as "solved".
PS
I'm sure it's far better than I could spell in German!
Yes I know and you are right, but it is just no fun for me, I like it to control hardware. I hope to learn with little projects and I am not in a hurry.
Juergen
Fair enough.
Again, see Tip #6 for some learning resources and some "little projects" which will start you off with good foundations, and build in a logical sequence.
And please see Tip #5 to mark the thread as solved.
Yes thanks for the tipsyes
C++11 introduced constexpr which is intended for this usage (and is much more capable).
constexpr uint8_t LED_BLINK_TIME { 50 }; // braced initialization checks for narrowing
// a function that is evaluated at compile time if all arguements are constant expressions
// otherwise usable at runtime
constexpr uint8_t foo( uint8_t bar ) noexcept
    // some interesting calculation
constexpr auto wibble = foo( LED_BLINK_TIME );
github.com/apcountryman/build-avr-gcc: a script for building avr-gcc
github.com/apcountryman/toolchain-avr-gcc: a CMake toolchain for cross compiling for the Atmel AVR family of microcontrollers
That is not necessary. You are thinking about a different range of AVR models.
