Atmel ICE
3 posts / 0 new
I am trying to debug the code through the Atmel Studio ATSAML11E16A but I am getting error message "recipe for target 'Device_Startup/startup_sam11e16a.0' failed". Is anyone as idea how to fix this. Thanks
BHT
That just means that your build failed - therefore there is nothing to debug.
You need to look further back in the 'Output' window to see the error message(s) which tell you what went wrong.
Illustration of where to find the 'Output' window: https://www.avrfreaks.net/commen...
BHT-Eagle wrote:
ATSAML11E16A
So why are you posting under 'AVR-related' ?
