Atmega 328p dead after changing clock frequency to 128khz
13 posts / 0 new
From what I have learned about this is that the serial communications frequency needs to be reduced to 32khz to restore communications to chip. I am using a usbisp type of programmer. Typing in avrdude shows a list of command options but I don't know if I need the B option or the i option and what the syntax would look like and how to insert the frequency (or period) and where to insert it in the command line. I want to restore the lfuse back to 62 to recover the chip.
Can some show me a sample of the command syntax to do this?
Roger
You can use the -B option to specify the ISP speed. By default the value is 10 which means 100KHz clock, this is good for target clock speeds > 500KHz. If you want the high speed clockrate (400KHz) for target frequencies > 4MHz you can use "-B 1" to speed up programming. To calculate the SPI frequency from the delay value, use this formula:
SPI clock frequency in KHz = 1000/(1.5+B) where B is the delay value.
In general, the clock frequency should be at least 4 times larger than the target clock frequency. Try "-B 32" if you're having clocking issues, that should handle even 128khz clocks.
Here is last command I have tried. avrdude -p m328p -c usbasp -U -B 32 lfuse:w:0x62:m. With this command I am trying to restore the chip back to it's default clock setting.
Is there anything wrong with this command. I get an error rc1 unable to establish communication.
Roger
Looking at my programmer I notice it has two jumpers on it. It says usbasp v 2.0 on it but I think is an ebay clone. JP1 selects 3.3 or 5 volts. There is a jp2 but no jumper is soldered in. I this the one that reduces the clock frequency?
Roger
Think about it.   125kHZ with CLKDIV8 means 15kHz.   SCK freq must be < 4kHz.   e.g. -B250
Chinese USBASP firmware sets the SCK frequency automatically.
Chinese authors do not expect punters to select foolish clock fuses.   It will not attempt < 32kHz (from memory)
If  -B250 is accepted by avrdude you have probably got German firmware.
If you get a Warning,  you have probably got Chinese firmware.
Can you remember how you set the fuses?
Do you own a Uno?
This can rescue your chip i.e. it will do 4kHz SCK.
david.prentice wrote:
Do you own a Uno?
I do have an uno but I have never used it. My computer is a linux machine and I dont' have an arduino.
Is the uno usable with avrdude?
An Arduino Uno will run on Linux, MAC, Windoze, ...
It can program an ATmega328P with avrdude
But the first step is to paste the avrdude command and response.
OK, here is the last command I tried.
roger@AsusB350-A:~/avr/m328$ avrdude -p m328p -c usbasp -U -B 1000 lfuse:w:0x62:m
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: error: program enable: target doesn't answer. 1
         this check.
avrdude done.  Thank you.
I have two of the uno devices but they are chinese clones. Is this still a workable situation?
And also before I executed this last command I put a new chip in my programmer and verified it was working correctly by loading program code into it.
Roger
Whoa -- deja vu.  Same topic; same AVR8 family; same week.  Coincidence?
HI, a long shot, from a kind of de ja vue as well:  do you power the chip from the programmer only or is there power on ?
I had similar, the "SCK warning" from avrdude; I was supplying from programmer only (which was an exception, which usually dont), put on "normal power" and the programming went fine.
(was a cheap usbasp dongle, guess i should try to reprogram it)
Your syntax is wrong.  You should have:
avrdude -p m328p -c usbasp -B 1000 -U lfuse:w:0x62:m
But better to just write an empty command e.g.
Which will just check the connection and report the Signature.   If it is ok,  repeat with the LFUSE command
Edit.    Oops.  Your avrdude response indicates Chinese firmware that does not recognise -B1000
The auto-SCK might connect with a F_CPU=125kHz chip.   It has no chance if you had CLKDIV8 fuse i.e F_CPU=15.62kHz
Regular USBASP can power the target.   They usually have a 3x1 header J1.   Place jumper for 3V or 5V.  Remove jumper for unpowered.
The SCK warning implies Chinese auto-SCK firmware or (unlikely) 10-year old obsolete German firmware
There is little point in replacing good Chinese firmware with current (inferior) German firmware.   But it is your choice.
If you try the "shoot your foot" trick,   you learn not to do it again.    Recover chip with a Uno.
Unless it's really hard, replace the darn $2 chip and save yourself hours
