TinyAvr 1 series: 0.71uA with RTC running ? But how ?
48 posts / 0 new
Hello AVR experts,
The datasheet of the attiny1614 claims a low power consumption of 0.71uA in standby mode with RTC running at 1.024kHz from internal ULP oscillator.
attiny1614 Power consumption Datasheet extract
But I have difficulties to get those 0.71uA. my best result are (for 5V from USB socket) :
  • 5uA with RTC running.
  • 120nA in full power down (wake on external interrupt / reset).
Even if I run it at 5V, I was expecting something closer to 1uA.
Update: I have similar results for 3V (3.3V from a linear voltage regulator) with 100nF decoupling caps:
  • 3.46uA  with RTC running, measured with a 100kOhm (99.1k) shunt resistor (346mV voltage drop)
  • 3.9uA measured with the uA functionality of my DDM.
  • Measuring tool: Multimetrix DMM 120 (Input resistance for DC voltage measurement > 10MOhm, datasheet www.multimetrix.fr/docs/NF/694310A01_DMM121_FR_Ed_02.pdf)
  • I also tried with several digital multimeters, measurements are the same.
This is my setup:
  • The bare 1614 SFR chip is directly hooked with test clips to 5V from USB.
  • I measure current with a 100kOhm shunt resistor (I short it when the chip resets to have enough power to start it).
  • The chip is configured using the atmel start configuration stated in assignment 2 from this application note: http://ww1.microchip.com/downloa... (ADC and Power Optimization with tinyAVR® 0- and 1-series, and megaAVR® 0-series) i.e:
    • Sleep controller enabled and set in standby mode,
    • RTC enabled and configured at 1.024kHz (prescale 32 + ULP 32kHz internal oscillator),
    • Global Interruption enabled + RTC interruption + flag cleared inside ISR.
    • In main, loop on sleep_cpu() : while(1){sleep_cpu();}
    • No extra user code.
    • BOD disabled (I checked the corresponding fuse, all zero).
    • Input buffer disabled on all I/Os.
Maybe I miss something really obvious, I am not an expert with these new avr chips.
If you have a similar chip (817 /1616/ 1617 etc..)  laying around, could you check if you can achieve the 0.71uA or close? (My solar project design needs such a low power consumption to run indoor, 5uA is way more consumption than the 1-2uA produced).
Thanks in advance for your help.
UPDATE: If made no mistake, I think I have the correct power consumption with this bare code example compiled with Atmel Studio:
  • 0.68uA ( 68mV voltage drop), what a perfect match for the claimed 0.71uA @ 3V, 25°C.
  • I am investigating the difference with the previous tests.
Test code with RTC running, MCU in eternal sleep (no interrupt, wake on reset only)
 * LowPowerRTC.c
 * Created: 07/11/2018 19:31:59
 * Author : Cedric
#include <avr/sleep.h>
#define F_CPU 3333333UL
#include <util/delay.h>
	//Configure pins: ////////////////////////////////////////
	// Set all pins to low power mode:
	for (uint8_t i = 0; i < 8; i++) {
		*((uint8_t *)&PORTA + 0x10 + i) |= 1 << PORT_PULLUPEN_bp;
		*((uint8_t *)&PORTB + 0x10 + i) |= 1 << PORT_PULLUPEN_bp;
	//RTC INIT: //////////////////////////////////////////////
	while (RTC.STATUS > 0) {} // Wait for all register to be synchronized
	RTC.CTRLA = RTC_PRESCALER_DIV1_gc	//NO Prescaler
	| 1 << RTC_RTCEN_bp       	//Enable RTC
	| 1 << RTC_RUNSTDBY_bp;   	//Run in standby
	RTC.CLKSEL = RTC_CLKSEL_INT1K_gc; // 32KHz divided by 32, i.e run at 1.024kHz
	_delay_ms(6000); //Consumes high power for 6secs before going into eternal sleep (to see a change in measurement on the DMM).
	//Main loop: /////////////////////////////////////////////
	while (1) {
		set_sleep_mode(SLEEP_MODE_STANDBY);
		sleep_enable();
		sleep_cpu(); //Go into eternal sleep
		//Dead code:
		_delay_ms(2000); //If MCU is awoken from any mysterous interrupt, stay still for power measurement with DMM.
UPDATE: Test code with periodic wake every 10 sec using RTC:
  • Less than 0.7uA when in sleep mode
  • More than 1mA when awoken (stay still for few seconds for slow current measuring with DMM).
 * LowPowerRTC.c
 * Author : Cedric
#include <avr/interrupt.h>
//RTC ISR //////////////////////////////////////////////////////
ISR(RTC_CNT_vect)
	RTC.INTFLAGS = RTC_OVF_bm;
	RTC.PER = 1024*10; //10 secs between wakes.
	RTC.INTCTRL = 0 << RTC_CMP_bp
	| 1 << RTC_OVF_bp; //Overflow interrupt.
	//Enable interrupts //////////////////////////////////////
	sei();
	while (1) {
		sleep_enable();
		sleep_cpu(); //Go into sleep
		//On awakening
		_delay_ms(2000); //Stay still for power measurement with DMM.
Can you confirm directly that all peripherals are disabled?
i.e. show your code.
Do you have debugging active,serial interface on your prototyping board or anything connected, for example a programmer? This may affect your measurements.
extronic.pl
Thanks for answering so fast.
I have attached the archive of the project. As I said, it is the untouched code generated from atmel start. I only have added the sleep_cpu() in the main loop to force the CPU to go into sleep mode.
The bare chip (fresh new from the reel) is only connected on pins VDD and GND using two tests hooks. No PCB, no prototype board, no debugger hooked, no programmer, no LED, etc..
To compile, I use the makefile in the gcc folder given by atmel start. By default, the debug flags are enabled (-DDEBUG -g3). Should I try without these flags ? I can't really see how it could reduce the power consumption.
I also tried powerdown mode with the PIT enabled but power consumption is still 5uA. Also, I am pretty sure that the MCU goes into sleep mode (In one test, I blinked a LED on wake up in the main.c . If the chip wasn't in sleep mode, the LEDs would have been blinking continuously).
Ah yes, START. That rabbit hole.
You might want to look at the datasheet on page 75 (11.3.2.1) and what it says about disabling individual peripherals.
As for START, I have no idea if it does that for you.
On tinyAVR 1 series, it seems that peripherals are not enabled by default and consume power only if the enable bit in the corresponding register is set.
I have checked the code generated, enable bits are not set by atmel Start. (There is not too much hidden code, only the mcu_init() function that disable all peripherals and enable pullups on I/Os for reducing power consumption).
Does this make any difference, if all the pins have pull-ups enabled, anyway?
Proper bypass caps are mandatory!  Your test setup is not valid.
The spec says 3v vcc, and your assumption that 5v would produce similar results is also invalid, to get the results listed in the data sheet takes careful attention to details and proper test conditions.
Also measuring such low currents can be difficult as just adding a test probe may change the results.  Again careful attention to detail is required.
Keys to wealth:
Hmmm--is that product line different from all other AVR8, where a not-enabled fuse has a value of 1/erased, and a programmed fuse has a value of 0?
Sparkies:  Could the lack of a bypass cap cause power draw fluctuations?
When measuring current down in those low areas, it isn't that easy.  How have you verified that the AVR is really drawing those measured amounts?  Could the measurement be off?  Could the measurement be causing a draw?
You are right, I have improved my setup and updated my results in the first post:
  • 3.46uA  with RTC running, measured with a 100kOhm (99.1k) shunt resistor (346mV voltage drop).
  • 3.9uA measured with the uA functionality of my DMM (no voltage drop).
  • I also tried with several different digital multimeters, measurements are all the same.
I am pretty confident that my current measurements are Ok: Input impedance of all my tools are of at least 10MOhm, so at 3V the measurement error should be at maximum of 300nA. Also, to remove any doubts, I will triple check tomorrow with the DSO in the lab.
I have read several fuse values with avrdude, the values correspond with the default values stated in the datasheet of the attiny1614.
To remove any doubts about the BOD fuse, I have explicitly disabled the BOD in software. Also, I will try to explicitly clear the enable bit of all peripherals, but I don't expect any improvement: the datasheet clearly state for each peripheral that the enable bit is 0 upon reset or loaded from fuses (bits in most of them are 0).
It certainly looks like something odd is going on. A glance at a random xmega datasheet shows that you ought to be seeing figures at least 3 times smaller than you are.
I see you have interrupts enabled and a while loop for periodic wake ups, your DSO may show you achieving your sleep current, but when running the average usage is higher as shown on your DMM.
try disabling the interrupts so the cpu stays asleep.
Keys to wealth:
I have just tried: I have disabled the global interrupt and also commented the RTC interrupt, no change in power consumption.
Also the periodic wake up is configured for one wake every second and the ISR does nothing (it just clear the interrupt flag).
With sleep mode disabled, I measure a  consumption of 9uA (900mV drop from 3.3V)
Time to post your findings and ask for help from MC support, ask how the results were measured and the program to verify.
Keys to wealth:
I have posted the issue at the microchip support. I will update here when I have news.
Then why did you say
Anyway, perhaps you, or someone here, can put together a very minimal test program without the mysteries of Start.
I mean that the single fuse corresponding to BOD is 0b00000000 (all bits are zero). Other fuses (oscillator configuration for instance) contains bits that are ones.
Ok I will try to do a minimal main.c that does the same thing.
Here is the minimal program (I think it should do pretty much the same thing that the code generated from atmel start):
	//SLPCTRL INIT: /////////////////////////////////////////
	SLPCTRL.CTRLA = 1 << SLPCTRL_SEN_bp       // Sleep enabled
	                | SLPCTRL_SMODE_STDBY_gc; // Standby Mode
	//Main loop:
	while (1) {
To compile, I usually use the makefile from atmel start, but maybe commands like that are correct:
avr-gcc -g -Os -mmcu=attiny1614 -B dev/attiny1614 -I include/ -c demo.c
avr-gcc -g -Os -mmcu=attiny1614 -B dev/attiny1614 -I include/ -o demo.elf demo.o
avr-objcopy -j .text -j .data -O ihex demo.elf demo.hex
I will try to upload it.
Edit: I have uploaded it, I am not sure of what is going on (wrong measurements, hundreds of uA). (not sure if the code is compiled correctly or if I have initialized everything properly). I will debug it tomorrow.
Indeed, Start does stuff.  What I was wondering is whether they missed a disabling bit somewhere.
I'm not a Tiny1 person.  But, anyway, from past experience I'd suggest the first sanity check program to not worry about that clock.  Use the simplest clock source for the AVR.  Start up and stay awake for e.g. 10 seconds to allow a reading of active current draw.  Then go to deepest sleep, with no wakeup sources enabled.  The AVR will sleep with the fishes until reset.  If you can't match active and deep sleep draws to datasheet values, it is no use going any further until that is resolved.
typical to 2uA max (estimated) at room temperature once the tiny1614 has been characterized enough; datasheet's TBDs will be replaced with data and some of the maximums will appear after enough wafers have been evaluated for long enough (probability by sampling)
The ones at Microchip need enough margin to allow for process variability in wafer fab and margin per the business unit's goals (supply to meet demand, revenue)
tinyAVR 1-series is what would of been the 5 volt version of XMEGA D series (no DMA, non-pipelined ADC) in a small package.
XMEGA16D4, ICC, power-save, RTC 1KHz from 32KHz crystal, 3V, 25C, 0.7uA typ to 2uA max
Worst case current consumption for leakage and such is square by each 10C increase.
Very hot day in south France could reach 8uA max; more likely is 4uA max.
For your application, might need to either bin tiny1614 or sample tiny1614 from each reel or tray.
Recommend a hot plate or oven test for the bench test unit and all prototype units; sample, test, measure, and evaluate production PCBA.
Alternate instruments :
  • Super-capacitor and high-Z DMM (C = Q/V leads to i = C * dv/dt, evaluate C's tolerance and leakage or self-discharge)
  • RTCM and DSO
  • SMU (Source Measure Unit)
  • Power Debugger and Atmel Studio 7 - an enhanced Atmel-ICE, SDRAM onto UC3A3, ADC by XMEGA128A1U, CSA, 1 ohm sense that's switched, 12V for RESET
SMU - Keithley 2450, 1uA range, 100uV max Burden, 0.025%+300pA
RTCM - ee-quipment, 10uA range, 70mV max Burden, 1uA error
SMU can be rented or leased.
RTCM is approximately an order of magnitude less expensive than a SMU.
Power Debugger's bandwidth is an order of magnitude greater than RTCM.
143nA for one arm Cortex-M but it's single-sourced (Ambiq Micro)
Likewise for one RTC though, IIRC, Phillips also has sub-threshold RTC.
Can switch VCC from some RTC though there's charge consumption due to power cycling VCC (Q = CV)
Most FETs are leaky especially at a hot temperature; there are a relative few FETs that have reasonable leakage.
Texas Instruments has very low current timers and low-leakage power switches to time and switch TI MSP430TM.
Some IPS from multiple manufacturers are low leakage.
Microchip has very low-Iq LDO some with very low shutdown current.
Capacitors leak, read with care a MLCC's datasheet, may one be able to acquire MLCC cheeky
ATTINY1614 - AVR Microcontrollers - Microcontrollers and Processors
ATxmega16D4 - 8-bit AVR Microcontrollers - Microcontrollers and Processors
The Embedded Muse 354, Tools and Tips
(last half)
Neal Somos is using supercapacitors to measure current of a circuit:
[university paper, ammeter tool review]
Real-Time Current Monitor with USB – ee-quipment.com (RTCM)
http://cdn.shopify.com/s/files/1/0362/5057/files/ee-203_product_overview.pdf?299 (RTCM datasheet)
Development Tools and Debuggers - Tag Connect (RTCM for non-US customers)
https://www.mouser.com/datasheet/2/403/2450-Datasheet_1KW-60904-0-257452.pdf (Keithley 2450 SMU)
Power Debugger, Analog Hardware
Apollo MCUs – Ambiq Micro
https://www.digikey.com/en/supplier-centers/a/ambiq-micro
Real-Time Clocks – Ambiq Micro
Abracon Products - Standalone Real Time Clocks (RTC) (22nA RTC tab)
Nanotimers | Products | Clock and Timing | TI.com
MCP1811 - Linear Regulators - Power Management (150mA, 250nA typ Iq, shutdown : 10nA typ and 250nA max at 85C)
via Extend Battery Life in Portable Devices with New Ultra-low Iq LDO | Microchip Technology
via https://plus.google.com/+MicrochipTech/posts/jghQTdpMMgX
Hardware and Firmware Issues in Using Ultra-Low Power MCUs
You may need to revisit your total design, as the worse case numbers are what you should target, not typicals.
Do you want only most of what you make to work, most of the time ?
(Ambiq Micro)
Texas Instruments did compete the sub-threshold theater with a, IIRC, 1KB program space MSP430TM.
The developer's version was RAM with a ROM bootloader; production in OTP.
IIRC, VCC was 0.5V (typ? ... amazing)
I've forgotten its part number.
TI's primary push is low leakage and FRAM due to high temperature electronics (geophysical, avionics; MSP430F2619S-HT is operating ambient -55C .. +150C)
http://www.ti.com/lit/ds/symlink/msp430fr5858.pdf
(page 21)
VCC current
LPM3.5, 12pF 32KHz crystal, 3V, 1.2uA max at 85C [less with 4pF crystal]
MSP430 is a major competitor to AVR, PIC, PIC24, and dsPIC though MSP430 doesn't have EBI.
MSP430 was selected by FSF steering for GCC.
MSP430 has an open source interface to its proprietary debuggers (MSPDS)
Texas Instruments Announces Ultra-Low Power MSP430 "Wolverine" MCU Series
...  or a solar panel the size of a microcontroller that enables environmental intelligence in any building or a smoke detector with carbon monoxide sensing, ...
via https://www.cnx-software.com/tag/power-harvesting/
MSPDS MSP Debug Stack | TI.com
Edits: elaborate CNX article, MSPDS
... or a smoke detector with carbon monoxide sensing, ...
That's oh so good.
2 men overcome by carbon monoxide at Texas NASCAR speedway | Fort Worth Star-Telegram
forward one day as one of the two did pass on.
... no prototype board ...
tiny1614 are in SOIC 150mil (3.81mm) body; 1.27mm pitch is no problem.
There's 1.27mm pitch SMT proto board.
A shop likely has in its stock 2.54mm pitch through-hole proto board; glue and Kapton tape the tiny1614 then manually pitch convert it.
A ground plane is good for most digital due to its di/dt.
tiny1614 I/O pin : tFALL = 1.3ns typ (5V and 20pF load, excellent drive and excellent for EMI generation)
Pease "air ball" is excellent for high impedance circuits' bench tests (proof-of-concept)
... no LED ...
A logic analyzer's typical input impedance is 100K ohms and approx 10pF; a pin can be default low.
Surface Mount Prototyping PCBs | BusBoard Prototype Systems
https://atmelcorporation.files.wordpress.com/2014/12/bob-pease-air-ball-prototype.jpg
ELM by ChaN's an artist ... 0.4mm pitch!
http://elm-chan.org/docs/wire/rc/wcs.jpeg
via ELM - Wiring Techniques (bottom, "How to mount SMD")
Yes
USB has up to a 5m cable between a hub and a device (significant inductance)
USB VBUS of 5 volts will briefly double (10V) at the device if there's no power termination during hot plug or unplug.
Capacitance limits dv/dt
Capacitance ESR limits di/dt
Polarized capacitors will significantly leak; for USB, about 1uA though could be an order of magnitude greater.
USB devices typically have USB VBUS TVS for over-voltage and PPTC to save the hub (notebook PC) from a device short (both are combined in a USB PolyZen)
USB in a NutShell - Chapter 2 - Hardware, Power (VBUS)
(next to last paragraph)
Other VBUS considerations are the Inrush current which must be limited. This is outlined in the USB specification paragraph 7.2.4.1 and is commonly overlooked. Inrush current is contributed to the amount of capacitance on your device between VBUS and ground. The spec therefore specifies that the maximum decoupling capacitance you can have on your device is 10uF. When you disconnect the device after current is flowing through the inductive USB cable, a large flyback voltage can occur on the open end of the cable. To prevent this, a 1uF minimum VBUS decoupling capacitance is specified.
PolyZen Devices for Overvoltage-Overcurrent Protection - Littelfuse
 Neither me and what makes me wonder is whether Tinies are that much different from eg 324? I mean, for 324 peripherals are on at reset and you must explicitly disable them by setting correspondent bits in PRR. Is it opposite in Tiny1?
 Another thing to consider is DMM mentioned in the first message. Correct me if I'm wrong, but it seems like Multimetrix DMM 120 shows an average over quite a long period of time, like at the order of seconds. This is normal for handheld DMMs but not enough to see what really happens. I'd suggest something like 34465A or Otii or anything else that is fast enough and shows the process in time. It may be that MCU still reaches the desired low level but something wakes it up often enough for a DMM average to be that high.
Qoitech AB, The Home of Otii Arc, an SMU for every developer
Check out Otii solution at www.qoitech.com
indeed as it's about an order of magnitude less expensive than a bench SMU, it's portable, and its accuracy and bandwidth are a match for typical systems.
It gives RTCM a go though RTCM would fit in one's tool pouch and one would likely feel OK about having a customer borrow a RTCM to evaluate a prototype.
OTII_TechSpec_Overview_AUGUST_21
via Qoitech Distributor | DigiKey Electronics
  • tiny3217 Xplained Pro - tiny3217, UC3A4, SAMD20, CSA, 100 ohm sense that's switched
ATtiny3217 Xplained Pro
The ATtiny3217 Xplained Pro is recommended for evaluation of the following products: ATtiny3217, ATtiny3216, ATtiny1617, ATtiny1616, ATtiny1614, ATtiny1607, ATtiny1606 and ATtiny1604.
You can also buy a Silabs dev board, quite a few of which have on board power monitoring, and hack it to monitor external circuits.
... attiny1614 ...
fyi, 16KB errata were mostly corrected in 32KB tinyAVR 1-series.
tiny3216 errata for rev C die :
  • ADC - 2 minor
  • TCB - 1 major (missing one form of restart)
tiny3216 may be sampling; it's in wide SOIC.
ATTINY3216 - AVR Microcontrollers - Microcontrollers and Processors
https://www.mouser.com/Search/Refine.aspx?Keyword=ATtiny3216 (ETA is 14-Jan'19, lead time is 26 weeks)
First post updated. It seems I have good results on my last test:
I am investigating the difference with the previous tests. Maybe it is because I compiled without the debug flags (how it could be possible to reduce consumption ?)
Edit: I have tested: no, it is not the fault of debug flags nor the fault of the makefile provided by atmel start.
How frustrating: I have created a new project with atmel start, and now it is working perfectly fine ! Around 0.6uA @ 3.3V measured with my DMM in series.
I have attached the bare project.
For now I can't figure out what was my mistake in the previous tests.
Were some pins floating ?  Anything else connected ?  it takes very little to add a few uA
While you have a good result, you may like to try lowering Vcc, to see how that affects current. If you hope to work from uA power sources, come creativity will be needed.
How do you plan to manage the high reset-time current ? - AVRs need a lot, during reset, and until you can switch them into lowest power modes.
I have tracked the error down to the clock controller init: The power consumption goes down when I disable those lines from my old project:
ccp_write_io((void *)&(CLKCTRL.MCLKCTRLB),
             CLKCTRL_PDIV_6X_gc /* 6 */
                 | 0 << CLKCTRL_PEN_bp /* Prescaler enable: disabled */);
ccp_write_io((void *)&(CLKCTRL.MCLKCTRLA),
             CLKCTRL_CLKSEL_OSCULP32K_gc /* 32KHz Internal Ultra Low Power Oscillator (OSCULP32K) */
                 | 0 << CLKCTRL_CLKOUT_bp /* System clock out: disabled */);
/* wait for system oscillator changing to finish */
while (CLKCTRL.MCLKSTATUS & CLKCTRL_SOSC_bm) {
Edit: Actually this line is the culprit:
ccp_write_io((void *)&(CLKCTRL.MCLKCTRLA), CLKCTRL_CLKSEL_OSCULP32K_gc | 0 << CLKCTRL_CLKOUT_bp);
But why ? That is really weird !! OSCULP32K is running anyway because used by the RTC.
Edit 2: Maybe it is the way clocks are internally multiplexed: maybe an active clock will consume more if it is selected as main clock source, even if nothing use the main clock source.
On my prototype PCB, I have a 80mF seiko super capacitor (XH414HG-IV01E) with very low leakage and low enough ESR (Capacitor designed for backup RAM retention during several days / weeks). Furthermore, there is a 10uF MLCC for decoupling, and 14 BPW34 photodiodes used as a big photovoltaic cells (easier to find than proper amorphous dim light PV cells),  plus a low leakage barrier Schottky diode. The goal is to collect enough energy during the day to pass the night. If the voltage goes bellow the 1.8V, game is over: the POR will try to enable the 20MHz oscillator and then discharge even more quickly the super cap.
A low leakage Schottky... I'll believe it when I see it. Don't trust the datasheet leakage measured at 25ºC... even a modest temperature increase will make the leakage increase exponentially.
What about the one I chose : BAS40-04W,115
Around 1uA reverse current @ 3V, 85°C
Around 10nA reverse current @ 3V, 25°C
Well, these are good specs indeed. Of course that diode can't support a lot of forward current, but I guess that's not important in your application.
I can believe that, as any clock tree represents capacitance.
If that is driven, even if the CORE/Peripherals do not use it, that can easily add a few uA - you can work out what capacitance the difference maps onto, using Power Dissipation Capacitance modeling.
A new arrival at Mouser probably tomorrow :
DEV-15170 Development Board - SparkFun | Mouser
due to Apollo Ultra-Low Power MCU
edit : Apollo3 in an 81-pin BGA though at 0.5mm pitch; likely difficult to find a relatively inexpensive PCB fab.
SparkFun Edge Development Board - Apollo3 Blue - DEV-15170 - SparkFun Electronics
new arrivals at Mouser :
Artemis Module - Engineering Version - SparkFun | Mouser
The module measures 10x15mm and has the support circuitry needed to use the [Ambiq Micro] Apollo3 [Blue] processor.
The SparkFun Artemis Module - Engineering Version is the first open source hardware module with the design files freely and easily available. The module can be easily implemented into designs with low-cost 2-layer PCBs and an 8mil trace/space. Three open-source-hardware example products are available that act as a starting point for products.
The engineering version comes without an RF shield or FCC approvals. Tape and reel quantities on a fully certified module are coming soon.
  • 6uA/MHz (operates less than 5mW at full operation)
  • Built in BLE [5.0] radio and antenna
SparkFun Artemis Module - Engineering Version - WRL-15376 - SparkFun Electronics
Artemis Nano - SparkFun | Mouser
BlackBoard Artemis - SparkFun | Mouser
BlackBoard Artemis ATP - SparkFun | Mouser
The ones at SparkFun achieved FCC (USA) and IC (Industry Canada) certifications for Artemis.
SparkFun Artemis Module - Low Power Machine Learning BLE Cortex-M4F - WRL-15484 - SparkFun Electronics
gchapman wrote:
for Artemis.
The Artemis Module from SparkFun is a Cortex-M4F
Is it just my age showing?  Is the Tiny1 series really a Cortex?  Or is this thread about running off the fumes from a urine sample?
Cedric's choice?
Am glad that Cedric has resolution.
Intention : the visibility of other paths
Do the ones at Microchip have interests in sub-microamp applications?  Maybe no though a definite interest in applications on small coin cells.
P.S.
Ambiq Micro have competition :
The Next Wave of IoT Bluetooth Devices Might Not Have Batteries | EE Times
by Maurizio Di Paolo Emilio, 08.22.19
Atmosic Technologies is is focusing on low-power Bluetooth 5 wireless platforms to enable networks of IoT devices that are, as the company says, "Forever Connected, Anywhere."
[1 micro-watt]
Figure 1: improvement in battery life with Bluetooth 5 [Source: Atmosic]
Atmosic has developed three innovative technologies: Lowest Power Radio, On-demand Wake-up, and Controlled Energy Harvesting.
By using their energy harvesting solution, the system can generate several tens of milliwatts with an efficiency of 30 to 40 percent, excluding the loss of the RF path.
Various parameters must be evaluated, which can decide the performance of an RF energy harvesting project.
 Can you explain the reason why you have the multiplication factor of 1024?
Jaivvignesh | Associate Firmware Developer
I know nothing about this chip / RTC but do you mean:
in #1? Surely that is saying that the RTC "tick" is 1/1024th of a second?
EDIT: In fact reading on one sees:
which mentions 1.024kHz or 1024 times per second.
Page 273 of datasheet. He choose INT1K source.
Do you mean that RTC  ticks 1024 times for 1 second?
What do you think "1.024 kHz" means if not that?
(I'm not a fan of "1.024 kHz", I think it would be clearer to the reader written as "1024 Hz" that clearly says "1024 times per second")
