Missing symbols in avr-libc
7 posts / 0 new
I'm using an ATtiny861a, and noticed iotn861a.h has several macros defined under "Device Pin Definitions", for example:
#define PB0_DDR   DDRDOSI
#define PB0_PORT  PORTMOSI
#define PB0_PIN   PINMOSI
#define PB0_BIT   MOSI
But I can't find the definitions for any of the symbols on the right.  Unfortunately, neither can my compiler.  e.g. When I try to use PB0_PORT I get a compiler error like "'PORTMOSI' undeclared (first use in this function)".
I suspect there's supposed to be lines somewhere (maybe in iotnx61.h) like:
#define DDRMOSI   DDRB
#define PORTMOSI  PORTB
#define PINMOSI   PINB
#define MOSI      0
Is this a bug in the library?  If so, where can I report it?  Note I'm using AtmelStudio 7 (and whatever avr-libc came with it).
The macros would be handy so I can use them to construct helpers like:
#define LED PB0
SETBIT(PORTNAME(LED), BITINDEX(LED))
I'd prefer to pull pin pinid-to-port-mappings from the stock headers rather than define them myself for each chip.
EDIT: I noticed some further issues.  e.g. PB4_PORT and PA4_PORT are defined as the same thing, which strikes me as obviously wrong.
It should be called garbage instead of bugs.
The macro you like will still be realizable.
// MACROS
#define SETBIT(PORT, BIT)   PORT |= BIT
#define CLRBIT(PORT, BIT)   PORT &= ~BIT
#define TGLBIT(PORT, BIT)   PORT ^= BIT
// DEFINES
#define LED_PORT    PORTB
#define LED_BIT     _BV(0)
    SETBIT(LED_PORT, LED_BIT);
    CLRBIT(LED_PORT, LED_BIT);
    TGLBIT(LED_PORT, LED_BIT);
    while (1){}
It will be necessary to devise more in order to obtain two information of port name and bit field from one word "PB0".
Thanks for the tip, but that's not quite what I'm after.
I started going through the header and making corrections - I see what you mean about the "garbage" comment.  The mistakes are so obvious - how come nobody's fixed it?  How do I submit my corrections back to the project?
I think it is appropriate for you to become a member here and make an effort to be hired. Please do your best.
https://www.nongnu.org/avr-libc/
Thanks.  I was hoping that wasn't the up-to-date home page.  Will try to figure out where their repository is and how to submit fixes...
(ps. I removed the example from my last post as I realized in retrospect it needs some work)
I remembered one thing.
In Arduino UNO, PORTB-BIT0 is indicated by only one word “D8”.
It may be helpful to see how the digitalWrite function gets the port name and bitfield.
I don't know how the implementation is done, but it's a function created by very clever people, so it might be made that way if it can be done with macros.
Note that there are two parallel developments of avr-gcc/AVR-LibC, one in the open by FSF GNU and one inside Microchip/Atmel. The latest device support is done first in Microchip then slowly makes it way to the open copy of AVR-LibC. If you look at
you are looking at the "open" one.
Note also that to try and remedy the situation the stuff that Microchip hold in advance of the core AVR-LibC is now made available in "Device Packs" and can be used with -b on the build tools.
