Hi all,
at my school I need to use AtmelStudio 7 with mandatory user profiles, i.e. no changes in the user profile will be saved after logout.
The Problem:
evertime you log in to a PC, you need to import the AS7 settings from a backup folder.
Changes to the config settings, project path and so on can be automatically saved (Tools/Options/Environment/Import and Export Settings...), but the next time AS7 won't automatically read this settings as the path settings are lost at logout.
So here's my questions:
- how do I name and where do I need to put the settings file (*.vssettings) so AS7 will detect and open it automatically?
This should be kind of the default location and name for the settings file.
- if not applicable, is there any registry information I can tweak?
Thanks in advance for any help!
Andreas
