Hey.
I created a program in which I would have a blinking led (500ms on / 500ms off) + a led controlled via pwm (brightness wise) + a 1Hz square wave output.
I built the code multiple times and I haven't spotted an error yet (I might be doing something wrong, though).
At the moment, I'm following a lot of tutorials on how to program my micro using AVRDude / USBAsp. I'm using multiple computers (with multiple OS's - Win7 and Win10) but none of them seem to work. My guess is: either the drivers are wrongly installed or everything's right exept the code. When I run the program on AVRDudes, my breadboard's leds stay off and nothing really seems to change.
Any help given that my work is due on Sunday?
#include <avr/interrupt.h> #include <stdio.h> #include <avr/io.h> #define LED 1 volatile unsigned char count = 2; // Counter volatile unsigned char led ; // Verifies if LED is turned ON or OFF void inic(void) { PORTD = 0b00001001; // Defined PD0 / PD3 as outputs. PD0: Blinking LED ; PD3: LED (pwm) [OC2B]. DDRD = 0b00001001; TCCR0A = (1<<WGM01); // COM0Ax: Normal port operation ; COM0Bx: Normal port operation ; Bits 3&2: Reserved and read as zero ; CTC mode (T = [Prescaler/Clock] * (OCR0 + 1) TCCR0B = (1<<CS02)|(1<<CS00); // FOC0x: Read as zero ; Bits 5&4: Reserved and read as zero ; Prescaler = 1024 & Clock = 1Mhz TIMSK0 = (1<<OCIE0A); // Timer/Counter0 Compare Match A interrupt enabled OCR0A = 243; // 0,245 = [1024/1MHz] * (OCR0 + 1) <=> OCR0 = 243 (0,249 ms) TCCR2A = (1<<COM2B1) | (1<<WGM21) | (1<<WGM20); // COM2Ax: Normal port operation ; COM2Bx: Clear OC2B on Compare Match & Set OC2B at Bottom ; Bits 3&2: Reserved and read as zero ; Fast PWM TCCR2B = (1<<CS21)|(1<<CS20); // FOC2x: Read as zero ; Bits 5&4; Reserved and read as zero ; Prescaler = 32 & Clock = 1Mhz OCR2B = 0; ADMUX = (1<<REFS0)|(1<<ADLAR)|(1<<MUX2)|(1<<MUX0); // External capacitor on AREF pin (potentiometer) ; ADLAR adjusted to the left: Bit = 1 ; Bit 4 ; Reserved and read as zero ; PC5 (ADC5) defined as input ADCSRA = (1<<ADEN)|(1<<ADIE)|(1<<ADPS1)|(1<<ADPS2); // ADEN enabled: Bit = 1 ; ADSC set when converting ; ADATE: Disabled auto triggering of the ADC ; ADIF: Set when conversion completes ; Prescaler = 8 sei(); // global int enable } ISR(ADC_vect) { // ADC interruption OCR2B = ADCH; // Transfers the value of the potentiometer to the led on PD3 ADCSRA |= (1<<ADSC); // Starts the conversion } ISR(TIMER0_COMPA_vect) { // Led blink interruption count--; // Counts 250ms led = (PORTD & LED); // Blinking LED if (count==0 && led==0) { // Count = 2 by default. 250ms * 2 = 500ms. Half a second on, Half a second off. Comes here if led is turned off PORTD |= LED; // LED ON count = 2; // Reset counter } if (count==0 && led==1) { // Comes here if led is turned on PORTD &= ~LED; // LED OFF count = 2; // Resets counter } } int main (void) { inic(); // Calls the inic function ADCSRA |= (1<<ADSC); // Starts the ADC conversion while(1){ } }
