Missing ELF File
7 posts / 0 new
Hi everyone,
This is not a problem statement. Recently, ELF files were not generated and I have searched a lot. At the end, I figured out that the problem is that I have used non-english characters for the .c and .h files, therefore ELF Files were not generated.
I have used 'ı' character which is non-english for both .c and .h files
Therefore, the problem may be not as complicated as you think
Best regards,
Ramazan Yaman
Electronics Design Engineer
Ah - this old chestnut again:
monogoly wrote:
the problem
What problem?
awneil wrote:
What problem?
I think OP was posting this as informational - to let other users know that if their code builds with errors one possible thing to look at is the use of Unicode characters.
Of course "missing ELF" is a bit vague. If you did use a character that the compiler couldn't handle you'd kind of hope it might tell you in a bit more detail!
Actually if it is ELF files then it presumably means GCC and yet if I build this in avr-gcc:
char c = 'ı';
	while(1);
it happily builds an ELF file without error or warning ?!? (it sets 'c' to 63):
.global	c
	.section	.data.c,"aw",@progbits
	.type	c, @object
	.size	c, 1
c:
	.byte	63
(that is the ASCII code for '?' in fact)
As the linked thread shows, a common symptom is, "recipe for target <file>.o failed"
if I build this in avr-gcc ... it happily builds an ELF file without error or warning ?!?
I think OP was talking about having the weird characters in the file names ?
Hence the link
from what I read it is more specific as in using those characters in the actual file name and not inside a file.
he meant special characters in the file name i suppose. but, awneil, a little bit of patience would always help.
Yup, that's the bit I didn't understand. The issue he's talking about is clearly about having non ASCII characters in the filenames.
I *think* it's possible that quoting the names may fix things but I'm too lazy to test that theory ;-)
