Solved: Problem using 16 bit counter on Atmega 328P
7 posts / 0 new
For now I am basically trying to capture a random count off the 16 bit timer and send it to a 16x2 lcd display. Before this part of the code is entered the display has been initialized and the cpu waits for an input pulse at the sbis instruction. When I trigger the pulse the cpu exits this part of the code and goes through a hex to ascii conversion routine and then outputs the captured number to the display.
The problem is the counter does not seem to be running and all I get at the display output is all zeros. I have been working on this for quite a while with no success.
I have done this before on an Attiny 2313 and have been successful and I am using the same basic algorithm here on the Atmega 328. However it is a much a more complex chip and I am probably missing something simple.
There are many experienced programmers on this board and could one of them spot what is wrong?
---------enters this code and waits for a trigger pulse on portb 0--------------------------------------------
               cbi          ddrb,0            ;sets ddrb port 0 as input
               lds          rmp,$01         ;sets cs10 to 1 for system clock drive of 16 bit counter.
               sts          tccr1b,rmp
wait1:      sbis       pinb,0             ;input capture timer count on signal pulse
               rjmp       wait1              ;wait for trigger pulse signal
               lds         YL,tcnt1L        ;load low byte of counter
               lds         YH,tcnt1H       ;load high byte of counter
------------exits this code to a hex to ascii converter and displays on the lcd.-----------
Wait for ICF1 bit in TIFR1 to be set. That tells you when an actual capture has occurred.
Then, don't forget to clear ICF1 by writing a logic  1 to that bit.
Note that for this example, you could just inc a register, loop around, & finally read the value when the pin says its time to read the random value.  This would be counting a a pretty fast pace & wrapping around many 1000's of times a second (8 bits).  for 16 bit it would wrap 100's of times a sec, maybe not as good for "random"
Wouldn't "ldi" be more appropriate there?  S.
You are right. With that correction the code worked. Sometimes I cannot see the forest for the trees.
Thank you for your help.
Roger
Isn't it hard to tell if the display of a RANDOM value 'works'?
This was just a small step in getting to where I wanted to be. I don't have any sophisticated debugging tools to help me get something to work. So I just build programs in small segments and stitch them together. My overall project goal was to get a time measurement between two pulses. I have done that now and have verified that is is working correctly by verifying measurements between my scope and my project.
Roger
