Split from: FatFs AtMega328P
17 posts / 0 new
 i have same problem with you if i use f_open prgoram gives "id returned 1 exit status " error but i couldn't fix it. you said  you fixed this error but i don't understand.can you explain how to do it
emre
Look at the build output. The "LD returned 1" is only the final consequence of a link error. You need to look above to see what the actual link error was. I'm guessing "undefined reference". This all proves why the "Error List" in the IDE is worse than useless!
kayanemre wrote:
 i have same problem
No, you don't!
You have a build error - the rest of the thread is about code which built successfully, but didn't then work on the target work.
Because you have an entirely different problem, that fix will not help you at all!
Which is generally because you've included the header files, but not the 'C' source (or pre-built binary) files.
I have changed lots of thing header files but i couldn't find the where the error exactly and error list only says  "ld returned 1 exit status"
here is my project.
emre
and that is exactly why
So see https://www.avrfreaks.net/commen... for how to get to the 'Output' window ...
------ Build started: Project: SDREAD, Configuration: Debug AVR ------
collect2.exe(0,0): error: ld returned 1 exit status
========== Build: 0 succeeded or up-to-date, 1 failed, 0 skipped ==========
this is my output window ,it only shows this results unlike the link you posted(it is showing building process unlike mine).
emre
Do a "rebuild solution" and post the entire Output
i tried it also
------ Rebuild All started: Project: SDREAD, Configuration: Debug AVR ------
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
emre
I have change some building settings so now i can read real problem from error list . problem is as you said  undefined reference .the error is undefined reference to `get_fattime' .
emre
You are supposed to implement that. It's so that if you have a real time clock you can pass back the real date and time so files are stamped correctly. If you don't have an RTC implement a get_fattime that always returns a fixed date/time line 12:00 01/01/2019 or something.
The description - ie, what you need to implement -  is here:  http://elm-chan.org/fsw/ff/doc/fattime.html
Full documentation of FatFs: http://elm-chan.org/fsw/ff/00index_e.html
In particular, see:
Also look at the 'Resources' section at the bottom of the page:
Also, when you download ffsample.zip from the FatFs site the example given has a main.c that contains:
/* User Provided Timer Function for FatFs module                      */
/* This is a real time clock service to be called from FatFs module.  */
/* Any valid time must be returned even if the system does not        */
/* support a real time clock. This is not required when FatFs is      */
/* configured for FF_FS_READONLY or FF_FS_NORTC = 1.                  */
DWORD get_fattime (void)
	RTC rtc;
	if (!RtcOk) return 0;
	/* Get local time */
	rtc_gettime(&rtc);
	/* Pack date and time into a DWORD variable */
	return	  ((DWORD)(rtc.year - 1980) << 25)
			| ((DWORD)rtc.month << 21)
			| ((DWORD)rtc.mday << 16)
			| ((DWORD)rtc.hour << 11)
			| ((DWORD)rtc.min << 5)
			| ((DWORD)rtc.sec >> 1);
You can basically just copy that into your own code. Of course you may not have an rtc_gettime() function in which case make it something like:
	RTC rtc;
    rtc.year = 2019;
    rtc.month = 10;
    rtc.mday = 7;
    rtc.hour = 9;
    rtc.min = 53;
    rtc.sec = 41;
Which stamps the files as 7th October 2019 09:53:41.
thank you all ,now  i can read and write into sd card
FRESULT scan_files (
char* path        /* Start node to be scanned (***also used as work area***) */
	FRESULT res;
	DIR dir;
	UINT i;
	static FILINFO fno;
	res = f_opendir(&dir, path);                       /* Open the directory */
	if (res == FR_OK) {
		for (;;) {
			res = f_readdir(&dir, &fno);                   /* Read a directory item */
			if (res != FR_OK || fno.fname[0] == 0) break;  /* Break on error or end of dir */
			if (fno.fattrib & AM_DIR) {                    /* It is a directory */
				i = strlen(path);
				sprintf(&path[i], "%s", fno.fname);
				res = scan_files(path);                    /* Enter the directory */
				if (res != FR_OK) break;
				path[i] = 0;
				} else {
						Serial_print(path);
						Serial_print(" / ");
						Serial_print(fno.fname);
						Serial_print("\n");                               /* It is a file. */
				printf("%s/%s\n", path, fno.fname);
		f_closedir(&dir);
	return res;
int main (void)
	ioinit();
	Serial_begin(9600);
		FATFS fs; 		/* Filesystem object for each logical drive */
		FRESULT res;
		char buff[256];
		res = f_mount(&fs, "", 1);
		if (res == FR_OK) {
			strcpy(buff, "/");
			res = scan_files(buff);
		return res;
		Serial_println("\n done :)");
but  when i use scan_files()  function only shows three file from root although there are more than three files.it works fine any folder in root.
emre
Total votes: 2
Do you have a debugger? I'd simply watch it one file at a time and see what the termination condition is.
BTW be careful with recursion - these micros don't have masses of RAM !
hi clawson i have another problem about f_open i can open SFNs without problem but when i want to open files which has  specific Turkish characters (Ö,Ü,Ğ,Ş,İ,ö,ç,ü,ı) f_open gives me  FR_NO_FILE error
my ffconfig.h file is like that .What i am missing ? Thank you.
/  FatFs Functional Configurations
#define FFCONF_DEF	86604	/* Revision ID */
/ Function Configurations
#define FF_FS_READONLY	0
/* This option switches read-only configuration. (0:Read/Write or 1:Read-only)
/  Read-only configuration removes writing API functions, f_write(), f_sync(),
/  f_unlink(), f_mkdir(), f_chmod(), f_rename(), f_truncate(), f_getfree()
/  and optional writing functions as well. */
#define FF_FS_MINIMIZE	1
/* This option defines minimization level to remove some basic API functions.
/   0: Basic functions are fully enabled.
/   1: f_stat(), f_getfree(), f_unlink(), f_mkdir(), f_truncate() and f_rename()
/      are removed.
/   2: f_opendir(), f_readdir() and f_closedir() are removed in addition to 1.
/   3: f_lseek() function is removed in addition to 2. */
#define FF_USE_STRFUNC	1
/* This option switches string functions, f_gets(), f_putc(), f_puts() and f_printf().
/  0: Disable string functions.
/  1: Enable without LF-CRLF conversion.
/  2: Enable with LF-CRLF conversion. */
#define FF_USE_FIND		0
/* This option switches filtered directory read functions, f_findfirst() and
/  f_findnext(). (0:Disable, 1:Enable 2:Enable with matching altname[] too) */
#define FF_USE_MKFS		0
/* This option switches f_mkfs() function. (0:Disable or 1:Enable) */
#define FF_USE_FASTSEEK	0
/* This option switches fast seek function. (0:Disable or 1:Enable) */
#define FF_USE_EXPAND	0
/* This option switches f_expand function. (0:Disable or 1:Enable) */
#define FF_USE_CHMOD	0
/* This option switches attribute manipulation functions, f_chmod() and f_utime().
/  (0:Disable or 1:Enable) Also FF_FS_READONLY needs to be 0 to enable this option. */
#define FF_USE_LABEL	0
/* This option switches volume label functions, f_getlabel() and f_setlabel().
/  (0:Disable or 1:Enable) */
#define FF_USE_FORWARD	0
/* This option switches f_forward() function. (0:Disable or 1:Enable) */
/ Locale and Namespace Configurations
#define FF_CODE_PAGE	857
/* This option specifies the OEM code page to be used on the target system.
/  Incorrect code page setting can cause a file open failure.
/   437 - U.S.
/   720 - Arabic
/   737 - Greek
/   771 - KBL
/   775 - Baltic
/   850 - Latin 1
/   852 - Latin 2
/   855 - Cyrillic
/   857 - Turkish
/   860 - Portuguese
/   861 - Icelandic
/   862 - Hebrew
/   863 - Canadian French
/   864 - Arabic
/   865 - Nordic
/   866 - Russian
/   869 - Greek 2
/   932 - Japanese (DBCS)
/   936 - Simplified Chinese (DBCS)
/   949 - Korean (DBCS)
/   950 - Traditional Chinese (DBCS)
/     0 - Include all code pages above and configured by f_setcp()
#define FF_USE_LFN		2
#define FF_MAX_LFN		255
/* The FF_USE_LFN switches the support for LFN (long file name).
/   0: Disable LFN. FF_MAX_LFN has no effect.
/   1: Enable LFN with static  working buffer on the BSS. Always NOT thread-safe.
/   2: Enable LFN with dynamic working buffer on the STACK.
/   3: Enable LFN with dynamic working buffer on the HEAP.
/  To enable the LFN, ffunicode.c needs to be added to the project. The LFN function
/  requiers certain internal working buffer occupies (FF_MAX_LFN + 1) * 2 bytes and
/  additional (FF_MAX_LFN + 44) / 15 * 32 bytes when exFAT is enabled.
/  The FF_MAX_LFN defines size of the working buffer in UTF-16 code unit and it can
/  be in range of 12 to 255. It is recommended to be set it 255 to fully support LFN
/  specification.
/  When use stack for the working buffer, take care on stack overflow. When use heap
/  memory for the working buffer, memory management functions, ff_memalloc() and
/  ff_memfree() exemplified in ffsystem.c, need to be added to the project. */
#define FF_LFN_UNICODE	0
/* This option switches the character encoding on the API when LFN is enabled.
/   0: ANSI/OEM in current CP (TCHAR = char)
/   1: Unicode in UTF-16 (TCHAR = WCHAR)
/   2: Unicode in UTF-8 (TCHAR = char)
/   3: Unicode in UTF-32 (TCHAR = DWORD)
/  Also behavior of string I/O functions will be affected by this option.
/  When LFN is not enabled, this option has no effect. */
#define FF_LFN_BUF		255
#define FF_SFN_BUF		12
/* This set of options defines size of file name members in the FILINFO structure
/  which is used to read out directory items. These values should be suffcient for
/  the file names to read. The maximum possible length of the read file name depends
/  on character encoding. When LFN is not enabled, these options have no effect. */
#define FF_STRF_ENCODE	3
/* When FF_LFN_UNICODE >= 1 with LFN enabled, string I/O functions, f_gets(),
/  f_putc(), f_puts and f_printf() convert the character encoding in it.
/  This option selects assumption of character encoding ON THE FILE to be
/  read/written via those functions.
/   1: Unicode in UTF-16LE
/   2: Unicode in UTF-16BE
/   3: Unicode in UTF-8
#define FF_FS_RPATH		0
/* This option configures support for relative path.
/   0: Disable relative path and remove related functions.
/   1: Enable relative path. f_chdir() and f_chdrive() are available.
/   2: f_getcwd() function is available in addition to 1.
/ Drive/Volume Configurations
#define FF_VOLUMES		1
/* Number of volumes (logical drives) to be used. (1-10) */
#define FF_STR_VOLUME_ID	0
#define FF_VOLUME_STRS		"RAM","NAND","CF","SD","SD2","USB","USB2","USB3"
/* FF_STR_VOLUME_ID switches support for volume ID in arbitrary strings.
/  When FF_STR_VOLUME_ID is set to 1 or 2, arbitrary strings can be used as drive
/  number in the path name. FF_VOLUME_STRS defines the volume ID strings for each
/  logical drives. Number of items must not be less than FF_VOLUMES. Valid
/  characters for the volume ID strings are A-Z, a-z and 0-9, however, they are
/  compared in case-insensitive. If FF_STR_VOLUME_ID >= 1 and FF_VOLUME_STRS is
/  not defined, a user defined volume string table needs to be defined as:
/  const char* VolumeStr[FF_VOLUMES] = {"ram","flash","sd","usb",...
#define FF_MULTI_PARTITION	0
/* This option switches support for multiple volumes on the physical drive.
/  By default (0), each logical drive number is bound to the same physical drive
/  number and only an FAT volume found on the physical drive will be mounted.
/  When this function is enabled (1), each logical drive number can be bound to
/  arbitrary physical drive and partition listed in the VolToPart[]. Also f_fdisk()
/  funciton will be available. */
#define FF_MIN_SS		512
#define FF_MAX_SS		512
/* This set of options configures the range of sector size to be supported. (512,
/  1024, 2048 or 4096) Always set both 512 for most systems, generic memory card and
/  harddisk. But a larger value may be required for on-board flash memory and some
/  type of optical media. When FF_MAX_SS is larger than FF_MIN_SS, FatFs is configured
/  for variable sector size mode and disk_ioctl() function needs to implement
/  GET_SECTOR_SIZE command. */
#define FF_USE_TRIM		0
/* This option switches support for ATA-TRIM. (0:Disable or 1:Enable)
/  To enable Trim function, also CTRL_TRIM command should be implemented to the
/  disk_ioctl() function. */
#define FF_FS_NOFSINFO	0
/* If you need to know correct free space on the FAT32 volume, set bit 0 of this
/  option, and f_getfree() function at first time after volume mount will force
/  a full FAT scan. Bit 1 controls the use of last allocated cluster number.
/  bit0=0: Use free cluster count in the FSINFO if available.
/  bit0=1: Do not trust free cluster count in the FSINFO.
/  bit1=0: Use last allocated cluster number in the FSINFO if available.
/  bit1=1: Do not trust last allocated cluster number in the FSINFO.
/ System Configurations
#define FF_FS_TINY		1
/* This option switches tiny buffer configuration. (0:Normal or 1:Tiny)
/  At the tiny configuration, size of file object (FIL) is shrinked FF_MAX_SS bytes.
/  Instead of private sector buffer eliminated from the file object, common sector
/  buffer in the filesystem object (FATFS) is used for the file data transfer. */
#define FF_FS_EXFAT		0
/* This option switches support for exFAT filesystem. (0:Disable or 1:Enable)
/  To enable exFAT, also LFN needs to be enabled. (FF_USE_LFN >= 1)
/  Note that enabling exFAT discards ANSI C (C89) compatibility. */
#define FF_FS_NORTC		1
#define FF_NORTC_MON	1
#define FF_NORTC_MDAY	1
#define FF_NORTC_YEAR	2018
/* The option FF_FS_NORTC switches timestamp functiton. If the system does not have
/  any RTC function or valid timestamp is not needed, set FF_FS_NORTC = 1 to disable
/  the timestamp function. Every object modified by FatFs will have a fixed timestamp
/  defined by FF_NORTC_MON, FF_NORTC_MDAY and FF_NORTC_YEAR in local time.
/  To enable timestamp function (FF_FS_NORTC = 0), get_fattime() function need to be
/  added to the project to read current time form real-time clock. FF_NORTC_MON,
/  FF_NORTC_MDAY and FF_NORTC_YEAR have no effect.
/  These options have no effect at read-only configuration (FF_FS_READONLY = 1). */
#define FF_FS_LOCK		0
/* The option FF_FS_LOCK switches file lock function to control duplicated file open
/  and illegal operation to open objects. This option must be 0 when FF_FS_READONLY
/  is 1.
/  0:  Disable file lock function. To avoid volume corruption, application program
/      should avoid illegal open, remove and rename to the open objects.
/  >0: Enable file lock function. The value defines how many files/sub-directories
/      can be opened simultaneously under file lock control. Note that the file
/      lock control is independent of re-entrancy. */
/* #include <somertos.h>	// O/S definitions */
#define FF_FS_REENTRANT	0
#define FF_FS_TIMEOUT	1000
#define FF_SYNC_t		HANDLE
/* The option FF_FS_REENTRANT switches the re-entrancy (thread safe) of the FatFs
/  module itself. Note that regardless of this option, file access to different
/  volume is always re-entrant and volume control functions, f_mount(), f_mkfs()
/  and f_fdisk() function, are always not re-entrant. Only file/directory access
/  to the same volume is under control of this function.
/   0: Disable re-entrancy. FF_FS_TIMEOUT and FF_SYNC_t have no effect.
/   1: Enable re-entrancy. Also user provided synchronization handlers,
/      ff_req_grant(), ff_rel_grant(), ff_del_syncobj() and ff_cre_syncobj()
/      function, must be added to the project. Samples are available in
/      option/syscall.c.
/  The FF_FS_TIMEOUT defines timeout period in unit of time tick.
/  The FF_SYNC_t defines O/S dependent sync object type. e.g. HANDLE, ID, OS_EVENT*,
/  SemaphoreHandle_t and etc. A header file for O/S definitions needs to be
/  included somewhere in the scope of ff.h. */
/*--- End of configuration options ---*/
emre
Can't help - I would never use LFNs for FatFs because of Microsoft's patent and they actually pursue those who transgress (famous case against TomTom!)
While it's true that FatFs has code page support I bet the only ones that are really tested well are US and Japanese (because E L Chan is Japanese) so it's quite possible there are errors in Turkish support that Chan has not spotted.
I notice there's also:
I don't know enough about LFN support but I wonder if Unicode should be enabled?
I think no ,when i enabled the any of them i get some pointer errors like this
#define FF_LFN_UNICODE	2
C:\ATMELSTUDIO\SDREAD\SDREAD\ff.c(6274,17): warning: passing argument 1 of 'tchar2uni' from incompatible pointer type [-Wincompatible-pointer-types]
		  dc = tchar2uni(&tp); /* UTF-8 ==> UTF-16 */
emre
