Split from: code for AC current measurement
10 posts / 0 new
Please help me!!!
What's wrong this code??
    for(count=0;count<=(adc_get_sample-1);count++)
          value=adc_read(1);
          Sum_Ad=(value*5)/1024;
          Sum_Ad =Sum_Ad-5;
          buff[count]=Sum_Ad;
    Volt=buff[0];
   for(count=1;count<=(adc_get_sample-1);count++)
       if(Volt<buff[count])
             Volt = buff[count];
            Volt_prd=Volt*Volt;
            Volt_sum=Volt_sum+Volt_prd;
            values[count]=Volt_sum;
    Volt_avr=(values[adc_get_sample-1]/((double)adc_get_sample));
    Volt_sqrt=(double)(sqrt(Volt_avr));
    result=(double)Volt_sqrt;
    dtostrf(result,5,1,string);
    sprintf(buffer_Am,"%0.3famps",result);
    _delay_us(10);
    LCD_goto(1,4);
    lCD_puts(buffer_Am);
          value=adc_read(1);
          Sum_Ad =Sum_Ad-5;
          buff[count]=Sum_Ad;
    Volt=buff[0];
             Volt = buff[count];
            Volt_prd=Volt*Volt;
    _delay_us(10);
    LCD_goto(1,4);
What's wrong with the code? There's a lot missing.
Tell us what the observed problem is and what you've done to narrow down the issue.
Why have you hijacked an 8 year old thread
EDIT: was originally posted here:  https://www.avrfreaks.net/forum/code-ac-current-measurement
For a start, you didn't use the proper tool to post it - see Tip #1.
But tell us:
  1. Does it compile without errors or warnings ?
  2. What do you want it to do ?
  3. What is it actually doing ?
  4. What testing / investigation / debugging have you done to find the problem(s) ?
We would need to know what chip it's for, and what (if any) external stuff it relies upon.
And what toochain / IDE you're using.
I'm sorry my friend. I didn't log in properly.I want my code to read the Ac signal with the ADC and then sample it.As a result, I hope to find the RMS value. I use Atmega32 as the controller. I use AVR Studio as compiler
Node: The input signal is 220 volts 50 Hz and ı used CT,
Remember that 220 V is potentially lethal - this is not suitable as a beginner project!
You should only be doing this under competent supervision.
ı
ı did the simulation with proteus.I took samples looking at the internet. But even if I try to create the code layout, I cannot find the range I want.
What do you mean by that??
Did you actually build this circuit?  What, exactly, have you done & what are you doing?  What does proteus have to do with any of this?
(s)he said (s)he "did the simulation" with it.
Whatever that means?!
frown
Your U1a +ve input has no DC reference voltage. You could try tying the low side of the current transformer to GND.
