How to pass "char string" to function
9 posts / 0 new
How to pass a char string I changed to a function?
This code doesn't work:
char AT_Send [] = "AT$SF=1122\r"; // 11x
void Send_AT_CMD(char str[], int n_chars) {
    for (int n = 0; n_chars; n++) {
        USART_0_write(str[n]);
        while (!(USART0.STATUS & USART_TXCIF_bm)); //wait for USART TX complete
        USART0.STATUS = USART_TXCIF_bm; //Clear TXCIF flag
Send_AT_CMD(AT_Send, 11);
This is all standard C stuff.
Within a function parameter list, you can do either
or
void Send_AT_CMD(char *str, int n_chars) {
They mean the same thing (the first way is just an alternative syntax that is allowed within function parameter list).
So I don't see anything wrong with how you are passing in parameters.
Your for loop, however, looks highly suspect
  change this to:
MrKendo wrote:
for (int n = 0; n < n_chars; n++) {
Note however C strings, ie those enclosed with "", are null terminated, is your array large enough for this extra character?
Normally string functions test for the null to end, rather then count characters!
What do you mean, "doesn't work" ?
  • What did you expect it to do ?
  • What is it actually doing ?
  • What testing / investigation / debugging have you done to find the problem ?
So, yes - it is automatically the correct length.
Appreciate your help. I forgot to set a condition for n:
n < n_chars instead of n_chars
If your function isn't going to be modifying the string you really should declare it as const:
void Send_AT_CMD( char const str[], int n_chars );
void Send_AT_CMD( char const * str, int n_chars );
This has a variety of benefits including letting you pass string literals to the function without getting compilation errors/warnings, and letting users and the compiler know that strings passed to the function won't be modified.
As ki0bk pointed out, quoted strings are null-terminated and you can always null-terminate strings you create at runtime. If all strings are null-terminated, you can rewrite your function like so:
void Send_AT_CMD(char const * str ) {
    char c;
    while (( c = *str++ )) {
        USART_0_write( c );
Send_AT_CMD( "AT$SF=1122\r" );
Depending on the AVR variant you are using you probably want to write the function so that it can also handle strings that have been placed in ROM.
github.com/apcountryman/build-avr-gcc: a script for building avr-gcc
github.com/apcountryman/toolchain-avr-gcc: a CMake toolchain for cross compiling for the Atmel AVR family of microcontrollers
Thank you. I am changing the string before calling the function e.g. writing two bytes (uint16_t measured ADC voltage converted to ASCII e.g 11.22 Volts *100 = 1122 = 0x0244.  "AT$SF=1122\r" will be "AT$SF=4402\r".
That has nothing to do with making the input parameter to the function 'const' !
As  apcountryman  says, making the input parameter to the function 'const' tells you that the function does not modify it.
