DHT11 temprature not showing
10 posts / 0 new
Hey.
Long story short, I have this idea of a self handling heating system.
So, I am trying to program an Arduino/DHT11 in C as a way to make it show the temprature and a "heating system" that is just a led lamp.
Yeah, it will be simple and easy, but it is a start.
Now, when I try to print the temprature from the DHT11, I only get 0. I've tried it on Arduino and I do get the temprature out from it.
I don't exactly know why this is happening, hench why I am asking you all.
Here is the code for the DHT11:
#include <stdio.h>
#include <stdlib.h>
#include <util/delay.h>
#include "dht.h"
// Trying to set up the DHT11 so it can be used in this project
void read() {
  // The bits are for to get the temprature values in.
  // reqCounter is for the request later on.
  uint8_t bits[5];
  int reqCounter = 0;
  // Setting up the DDRD as OUTPUT and PORTD as HIGH
  DDRD |= (1 << DDD5);
  PORTD |= (1 << PORTD5);
  _delay_ms(100);
   * Makes an request to get the data from the DHT11
   * Set the the PORTD5 as LOW
  PORTD &= ~(1 << PORTD5);
  _delay_ms(18);
  // Setting it back to high and DDRD as an input
  DDRD &= ~(1 << DDD5);
   * Checking to see if the ACK is happening
   * If it does, add +1 to the req_counter
  _delay_us(30);
  if ((PIND & (1 << PIND5))) {
    reqCounter++;
  _delay_us(80);
  if (!(PIND & (1 << PIND5))) {
    reqCounter++;
  _delay_us(80);
   * If the req_counter == 2, then I will run the request to get the data
  if (reqCounter == 2) {
    // Holds the temprature
    uint8_t temp = 0;
    // Used to check if the pin is alright
    uint8_t loop = 0;
    // Reading the data
    for (int i = 0; i < 5; i++) {
      temp = 0;
      // Create a for loop that looks in to every 8 bits
      for (int j = 0; j < 8; j++) {
        // While it isn`t high, loop this while loop
        while (!(PIND & (1 << PIND5)))
        _delay_us(30);
        // Looking if the input is still high after 30us
        if (PIND & (1 << PIND5)) {
          temp |= (1 << (7-i));
      // Put the temprature in the bit array
      bits[i] = temp;
    // set req_counter to 0 so it wont run all the time
    reqCounter = 0;
  // Resets the pins
  _delay_ms(100);
  uint8_t temprature;
  //checks the sum and gets the temprature
  if (bits[0] + bits[1] + bits[2] + bits[3] == bits[4]) {
    temprature = bits[2];
  printf("%d\n", temprature);
  _delay_ms(2000);
Thank you for anyone who helps me.
Best Regards
Ravoos
The code you've posted doesn't have a main() - so where's the rest of it?
So why not keep using the Arduino?
If you're not using an Arduino - what target hardware are you using ?
If you're not using the Arduino IDE - what IDE are you using ?
You realise that Atmel Studio 7 can import Arduino "sketches" ?
If you're not using an Arduino - why have you posted under 'Arduino' ?
Ravoos wrote:
#include <stdio.h>
#include <stdlib.h>
#include "dht.h"
I don't see where you have defined F_CPU, which is used by delay.h.
Hey, sorry for the late response.
To answer them in question.
1) I am only using it as a microcontroller because I want to keep using the C language because I want to work with programming in the future. So this is kind of a nice way to keep studying the language.
2) I am only using Atom on Linux to edit the code. I am then using some commands to compile it on the arduino microcontroller.
3) No. I did not know that.
4) I thought it would fit here as I am using the Arduino as a microcontroller but not the IDE or its language. Why am I not using another Microcontroller? It is the only one I have ATM.
// Patrik
Hello.
Hmmmmm. I don't need to define F_CPU, because it still works without it....or am I wrong?
// Ravoos
If you don't set it yourself, it gets a default value
If it works for you, then you were just "lucky" that the default happened to be OK for you - but you should not rely on that!
Okay. Then I am really bloody lucky.
How would you recommend to define F_CPU?
Also, I will do this later as I am at work ATM.
I would recommend that you do what the documentation tells you ...
https://www.nongnu.org/avr-libc/user-manual/group__util__delay.html#ga43bafb28b29491ec7f871319b5a3b2f8
https://www.microchip.com/webdoc/AVRLibcReferenceManual/group__util__delay.html
EDIT
It is also described in delay.h:
/** \defgroup util_delay <util/delay.h>: Convenience functions for busy-wait delay loops
    \code
    #define F_CPU 1000000UL  // 1 MHz
    //#define F_CPU 14.7456E6
    \endcode
    \note As an alternative method, it is possible to pass the
    F_CPU macro down to the compiler from the Makefile.
    Obviously, in that case, no \c \#define statement should be
    used.
    The functions in this header file are wrappers around the basic
    busy-wait functions from <util/delay_basic.h>.  They are meant as
    convenience functions where actual time values can be specified
    rather than a number of cycles to wait for.  The idea behind is
    that compile-time constant expressions will be eliminated by
    compiler optimization so floating-point expressions can be used
    to calculate the number of delay cycles needed based on the CPU
    frequency passed by the macro F_CPU.
    \note In order for these functions to work as intended, compiler
    optimizations <em>must</em> be enabled, and the delay time
    <em>must</em> be an expression that is a known constant at
    compile-time.  If these requirements are not met, the resulting
    delay will be much longer (and basically unpredictable), and
    applications that otherwise do not use floating-point calculations
    will experience severe code bloat by the floating-point library
    routines linked into the application.
    The functions available allow the specification of microsecond, and
    millisecond delays directly, using the application-supplied macro
    F_CPU as the CPU clock frequency (in Hertz).
In particular, note:
    used.
That would be the recommended way to do it!
You can see the default being applied here:
#ifndef F_CPU
/* prevent compiler error by supplying a default */
# warning "F_CPU not defined for <util/delay.h>"
/** \ingroup util_delay
    \def F_CPU
    \brief CPU frequency in Hz
    The macro F_CPU specifies the CPU frequency to be considered by
    the delay macros.  This macro is normally supplied by the
    environment (e.g. from within a project header, or the project's
    Makefile).  The value 1 MHz here is only provided as a "vanilla"
    fallback if no such user-provided definition could be found.
    In terms of the delay functions, the CPU frequency can be given as
    a floating-point constant (e.g. 3.6864E6 for 3.6864 MHz).
    However, the macros in <util/setbaud.h> require it to be an
    integer value.
# define F_CPU 1000000UL
#endif
So you should have got a warning - did you not?
Ravoos wrote:
Hello.
// Ravoos
I'm guessing the default value isn't working hence your code not working, DHT11 require pretty specific delays to get the data decoded. If your using an Arduino board chances are that's running at 16MHZ, and the default F_CPU is 1MHZ, meaning your delays will be running 16 times faster then They should be
Hmm ... but in that bit which you quoted, he said it works !
I guess it's a bit ambiguous about what he actually meant by "it still works" - since the whole point of the OP is that it does not work!!
All rather confusing, really ...
frown
