Problem compiling for ATTINY1604
12 posts / 0 new
I am unable to compile code for the ATTINY804. When attempting to compile, I get the message "device-specs/specs-attiny1604: No such file or directory"
I started with a fresh install of Atmelstudio,downloaded from the microchip website today and verified that the most current device pack for the attiny was installed. Then, I created a new c++ project, selecting the attiny1604 as the device and attempted to compile the autofilled code:
 * GccApplication1.cpp
 * Created: 10/3/2019 1:36:14 PM
 * Author : whcollins
    while (1)
Bill
Include Paths ?
awneil wrote:
Include Paths ?
It seems wrong that atmel studio would not know the path to files that are part of its own device pack, but I searched the C drive for specs-attiny1604 and found it at two locations:
C:\Program Files (x86)\Atmel\Studio\7.0\packs\atmel\ATtiny_DFP\1.3.229\gcc\dev\attiny1604\device-specs\specs-attiny1604
C:\Program Files (x86)\Atmel\Studio\7.0\packs\atmel\ATtiny_DFP\1.3.169\gcc\dev\attiny1604\device-specs\specs-attiny1604
I tried to add one of these to the include path and could drill down to the device-specs directory, but it appeared empty. I have verified that the specs-attiny1604 file does actually exist.
I tried compiling for the atmega32 and attiny10 and did not have any problems.
Bill
Ok, the problem adding the path was a stupid mistake on my part. The path to the file has been added and I still get the error.
Bill
I copied the specs-attiny804 and 1604 files to C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\lib\gcc\avr\5.4.0\device-specs and got past that error. I figured out where it should go by looking for the similar file for the attiny10. Now, it can't find crtattiny804.o
Bill
a WAG
Installation and Updates | Atmel Studio 7
[mid-page]
Downloading and Installing
  • Make sure your user has local administrator privileges
I do have admin privileges.
I copied the .o file it was looking for into the directory with the object files for my project and moved onto the next error: Cannot find -lattiny1604
I'm not even sure what to make of this one, since the - looks like a linker directive. Searching for attiny1604 or lattiny1604 turns up no files to potentially copy
(I tried both 804 and 1604 before posting. I just noticed that I'm mixing up the two projects when posting error messages. The results are the same for either, except for the device name.)
I'm beginning to think carbon black (our extremely aggressive antivirus) is interfering with the update process for Atmel Studio. I'm going to try this on a PC that is not secured by corporate IT.
Bill
I installed Atmel Studio on a virtual machine that is free from some of IT's restrictions (and is 32 bit win7 instead of 64 bit) and it works fine. Time to go talk to IT.
Bill
indecision
Frequently Asked Questions | Atmel Studio 7
[near bottom]
How to improve studio performance for any supported version of Windows?
Exclude the following directories and files from your antivirus scanner:
  • The Atmel Studio installation directory, and all files and folders inside it
  • %AppData%\Roaming\Atmel directory, and all files and folders inside it
  • %AppData%\Local\Atmel directory, and all files and folders inside it
  • Your project directories
and more on anti-virus in that page (USB port, etc)
64 bit is working fine here ...
And here. BTW, just finished installing 6 months of win 7 updates. Phew. 3 more months left to get to current.
Could you post the whole compile log?
