ATMega32u4 JTAG AVR Dragon not working
5 posts / 0 new
AS7, AVR Dragon, ATmega32u4.   ISP is working, but without debugwire I need JTAG to do on chip debugging.  JTAGEN and OCDEN fuses are checked (via ISP) and all lock buts are unlocked (see screen shots for sanity check).  I have tried with and without a 68Ohm inline resistor on TCK (saw it suggested on other threads)  Voltage is reading fine, but cannot get ID.
JTAG is giving the error:
"JTAGID not valid. Debugger command enterProgMode failed.
Unable to enter programming mode. Verify device selection, interface settings, target power, security bit, and connections to the target device."
 Details:
"Timestamp:    2019-09-24 11:04:42.168
Severity:        ERROR
ComponentId:    20100
StatusCode:    1
ModuleName:    TCF (TCF command: Device:startSession failed.)
JTAGID not valid. Debugger command enterProgMode failed."
If anyone has any suggestions on how I have screwed this up, please let me know.
Do you maybe have the JTAG connected backwards?
Are you using ALL the JTAG pins?
PORTF(I think ) is the JTAG port....do you have anything connected to that port that could interfere with the JTAG?
This is on a Pro Micro.  It appears that A0-A3 are just direct to pins 36-39.
I am making an assumption that the Dragon has pins correctly labeled (1 and 9 labeled on silkscreen) and pins 1-TCK, 2-GND, 3-TDO, etc.  Pins 7 and 8 of not connected.  I only have one of Gnds connected, but they seem connected on the Dragon side... I can break it our and connect both JIC.   I would expect that the voltage reading would not be working if it were mirrored, but I will quintuple check all the lines.
OK, re-ran all lines and connected both GNDs...  appears to be working...  maybe I had something flipped....  maybe it was the GND lines...  I hate not knowing for sure, but happy it is working.
I also disconnect ISP, though I doubt that was it...  for future troubleshooters...
