Protecting RS-485 busses
This is the circuit that I use a lot for my product.
Please use as a topic in this thread.
In order to omit expensive high wattage resistors, low wattage resistors are used in parallel.
Ok, I'll byte. How is this cheaper? a 1 watt 120 ohm resistor is maybe $0.22usd?
https://www.digikey.com/product-...
5 1/4 watt resistors are $0.10 each:
PLUS then there is the PCB layout/fab costs.
so how is 5 resistors cheaper to use than one ?
JIm
The examples are just in line with my special environment.
In my case there is only a small amount of production, so I don't want to pay for the purchase, maintenance and management of the 120Ω that I use only.
OK - but that wasn't what you said in your first post!
Expensive I say is not determined only by the unit price.
Sorry at the lack of explanation.
Should we write high cost?
I think the subject other than the OP should be dropped before the fights start.
JMO
JIm
