How to convert a decimal number in a register into an ascii format?
17 posts / 0 new
Lets say you have the decimal number 44 stored in an 8 bit AVR register and need to display it on a  hd44780 lcd. I need to pull out each nibble (4bits) and convert it to 8bits and display them one digit at a time on the lcd. How would you do this?
Roger
Theres any number of ways to do this.
ITOA comes to mind.
Why?
'44' decimal is 00101100 in binary and 0x2C in hex.  ITOA would take the number in the register and do the work for you
Greetings -
(1) Is that "44" really decimal or is it hex? It likely does not exist in the register as one nibble of "4" and another nibble of "4"; because THAT would be BCD. It would only be BCD under unusual circumstances, such as you putting it there as BCD or from an external peripheral that outputs in BCD.
(2) If it is 0b01000100 (0x44) then use "itoa()" from avr-lbc to convert it to a string; you can specify whether the output string shows the decimal representation or the hex representation. If it is decimal 44, then the register will contain 0x2c = 0b00101100. You can use the same function, telling it to use base-10 as the output.
I do not have any of the C programming stuff available to me. I only have the avr assembler available and I like to see how it done with just the avr assembler.
Roger
Here's a routine found on the web (not tested) for binary to BCD in AVR assembly (Link).
I really don't think that Mopar_512 was looking for a BCD conversion. I think that he or she misunderstood how numbers are stored in an 8-bit register.
Here's a few good links
https://www.avrfreaks.net/forum/16bit-binary-ascii
http://www.avr-asm-tutorial.net/avr_en/calc/CONVERT.html#bin2asc
Note these tend to "save" all the ascii digits, until finished...if just sending to an lcd you can send them  one-by-one (assuming updating display left MSD to right LSD)
The one by Beeder assumes ZH:ZL (first of array of 5 digits)  is preset to where you want the results (ascii digits) stored
First thing to note is I only have the avrasm2 assembler available. I am using an ldi rmp, $44 just to get the number into the register so I can test code to see if I can get it to display on the lcd. To get it to display I have to extract out each nibble, convert it to ascii, and then display each one with a separate out operation.
I think I must probably use the lsl and lsr instructions to strip the bits out of the register as I need them.
The reason I asked this question is because I just thought some of the experienced programmers here might know a slick little trick to do this.
Roger
Lemme guess....you have the LCD running in 4 bit mode?
If so, then your LCD driver should handle the setting up of the data to send to the LCD for you.  Unless this is a home rolled driver.
JIm
What is the range of your register value?
Is it 0 to 99 or 0 to 255?
The "trick" in those links essentially subtracts 100's & counts 'em up (that's the 100's digit) then takes the leftovers & does the same with 10's (the ten's digit) , then 1's digit.  Also, you have to ass 0x30 to each to form the ASCII character value for the display digits.
Doing that conversion nibble-wise gives you hex, in this case. what happens if you put 0b11111111 into that register? What do you see, then, on your LCD? If you are actually displaying decimal, you OUGHT to see 255.
I think we need to hear what you actually want to appear on the display. Say your register contains 44{2C) then what should appear? How about 99(63) or 251(FB)?
conversions here.
After reading this post the solution came to me. This is a hex to decimal conversion algorithm that leaves the converted numbers in the correct ascii format to display in the lcd. Problem solved.
Roger
Well, I assume that you want the data 0x44($44) stored in some register to appear in some display(like 16x2 character lcd) as 44.
Using AVR Assembly it's fairly simple and basically a two step process -
1. Separate the nibbles. In your case 0x44 will make two registers holding 0x04 and 0x04 each.
2. Oring them with 0b00110000(0x30), this will make them ascii equivalent of 4 and send them to the display
I've used this trick several times while displaying RTC data to LCD display.....
Good Luck....
PS: I appreciate your approach to write programs in Assembly.....
Sounds like you wanted binary to bcd. Mentioning hex just confuses the issue. There’s two common algorithms - divide by descending powers of 10 or a modified division that corrects the value by adding 3 to the nibble. There’s been plenty of discussion in the past regarding this. The key term is ‘binary to bcd’
But if it's an HD44780 then it wants ASCII ? (so BCD digits + '0')
