AVR GCC - AS7 - Basic Compiler Question
4 posts / 0 new
Hi -
I could use some guidance  understanding the output report generated following an AS7 (AVR-GCC) build regarding chip resources used.
If .text represents flash, does that quantity refer to both application code + strings, etc?  i.e. everything stored in flash
If Program Memory Usage = 3508 is this only application memory and .text - program memory = 291 (strings, etc?)
I also don't understand the discrepancy in 'Data Memory Usage' = 29 bytes, however .data+.bss = 39 bytes?
Any assistance in understanding this would be appreciated.
Below, I've pasted an image of the output report:
.text is only the code. .data are the non-0 initializers so total flash usage is text+data. Above that is 3799+14. Your preallocated RAM usage is data+bss so 14+25
The following numbers from Atmel's tool just look like so much bollocks.
Thanks -
I understand and that makes perfect sense.  However, the PROGRAM MEMORY USAGE and DATA MEMORY USAGE are meaningless?  Confusing.
Yeah total bollocks as far as I can see.
If you want the real numbers learn to read the .map file.
