Writing to multiple GPIO's at the same time
2 posts / 0 new
Does AVR32 uC allows you to write to multiple GPIO's in parallel, instead of using set/clr to each port individually?
Thanks in advance!
Isn't it just like AVR/Xmega chips?
that seems to suggest that while you can write to OVRS/OVRC to set/clear bits (or OVRT to toggle) you can simply write to "OVR" to set/clear whatever 32 bit pin combination you want?
There is also ODER to set in/out direction and PVR reads the state of inputs.
In Xmega terms:
PORT_DIR = ODER (DDR in original tiny/mega)
PORT_OUT = OVR (PORT in tiny/mega)
PORT_IN = PVR (PIN in tiny/mega)
