How to interpret AVR part numbers ?
5 posts / 0 new
E.g.  ATtiny202-SSFR vs ATtiny202-SSNR
The datasheet tells all.
Usually toward the very back. You need to look at the device-specific data sheet, not the family data sheet.
https://www.microchip.com/wwwproducts/en/ATTINY202
Buy Now tab will show. Tape and Reel or Tube packaging, 2 temperature ranges. Packaging makes no difference until you know something specific is needed (automation in assembly), temperature also makes no difference until you know it does. Pick the cheapest or the one that is in stock from your supplier.
