Measure time consumption of programme
13 posts / 0 new
Hello
I'd like to check the "time consumption / time measurement" of the different parts/functions of my programme - how long it takes:
- to process one complete run through the programme (the "infinite" loop)
- function for sending/receicing data from/to USART
- write data to a LCD display
- and so on
and right now I do it the "simple" way - there's 1ms timer (time base) and I use different counters to monitor how long it takes to process a function etc.
Is there a FOC programme (I'm neither Mr. B. Gates nor Mr. M. Zuckerberg wink) which could be used to do this "time consumption monitoring" in a more professional manner?
I use the AVR Studio 4.18 Build 716, avr-gcc 4.3.3, programming language is C for my ATMega8
Thanks in advance
best regards
Hero_123
I don't know what kind of tools there are but I would look i the generated code, and run it with the simulator (it's clk accurate ) and set break points different places.
That way you should get a good picture of that's happening and how long it takes especially it you wrote the code.
Other ways is simply in the real program have some variables that read a free running timer (probably slow to avoid overflow) , and then log the values (probably only once with a start trigger ) and then dump them on the UART later on.
Have in mind that for some things you want to know worst case, and not AVG speed (like a function that 1% of the times take 10 times longer than normal can destroy the hole thing),
but I assume that you know that since you asked the question :)
Hello sparrow2
Thanks a lot for your reply yes
I've never used the simulator and so I'm not at all familiar with that kind of tool...
That's exactly what I do in the moment. I store the longest value of each interesting function etc and dump them on the USART=> worst case consideration.
best regards
Hero_123
Simulator works fine for lots of things, but when you have complex external hardware, such as a microSD card, it does not help much. In some such cases, the external hardware can drag things out for a LONG time and it would never show in simulation.
Been there, done that!
What kind of timing res do you want--seconds?  (it takes about 5 seconds for the light to come on), milliseconds, or down to the microsecond?
You can often use a scope (or logic analyzer)...set a pin in the different sections you want to measure (clear upon exiting the section/function)and measure the pulse width.  Easy & effective.
I also opened recently a topic on the same subject, maybe they could be joined?
You can use a very fast timer to measure the exec time and cpu load and then send it or save it.
But also the pin toggling method is very nice, as you can eliminate some possible SW factor from the calculation.
I don't know what is the pin commuting time for ATMELs, but it should be fast enough to guarantee a good precision.
At least for me for a very short routine, I measured multiple times with the oscilloscope the same code and the result was 125us+-10us at 16MHz clock.
I never used the simulator, this would look like a nice method for designing and checking the executing time for routines that are really time critical, like some ISRs,
so that you don't have ugly surprises after writing the code.
Hello  ka7ehk, hello avrcandies, hello bbogdanmircea
Thanks a lot for your replies yes
Yeah, I'll do it the "old fashioned way" (use  a timer and counter, read continously, dumb the max value to the USART).
I haven't got an oszilloscope (sad, I know) and that method with using a pin - well, unfortunately I've used all the pins on my ATMega8 already (use right now Port expanders to increase the number of available ports).
In the end I was on the right track (timer/counter/ USART for indication), I only thought there'd be a better solution wink
best regards
Hero_123
Maybe there are better ways ... but I can recommend the osci method for sure, it gives such a good insight on how the "tasks" are running into the code.
I am using one of the pins used by the app which I can easily scope, after I am sure all the tasks are running ok I will decide it to its original purpose.
But if you have only a few pins then that could be a problem.
Total votes: 2
That's ridiculous to be involved in micros and not have one....at least get a $15 USB logic analyzer.
Be careful of using the system to measure its own time...since the time measurement will be affected by the system clock.
Banggood Electronics has this "Toy" O'scope for $12 USD, (ARM Cortex M3 and a 2.4" color TFT display, Single Channel, 1 MSamples / Sec, 0 - 200 kHz BW...).
This is a cheap toy O'socpe, low bandwidth, single channel, etc.
But it is so incredibly inexpensive and useful.
You can also use it as an Arm development board, if one was so inclined.
As mentioned above, I routinely use a pin and set it high when entering a routine, low when exiting, to see the ISR or routine's timing.
One can easily set a pin high within the ISR's and see what % of time is spent within the ISRs vs is available for the Main Loop processing.
Out of pins...  Bummer.
There are several ways to free up a pin, (but not once your board is made!).
For your current board do you have any I/O pins driving an LED, or a Piezo, or a rarely used / needed switch, etc.
If so, simply temporarily use that pin for your timing, and change the code to skip using that item.
Recall that most compilers will have a number of Register saving and restoring (Push and Pop) instructions at the start and end of ISRs, so the "Pin High" duration of an ISR is actually a little bit shorter that the real ISR.
ISR:
Save registers
Set pin high
ISR code
Set pin low
Restore registers
But that is only a few clock cycles, and unless one needs the EXACT timing, it is immaterial.
other than by patches though do need sufficient I/O; sometimes a pin can be shared by current division.
A proof-of-concept may begin with your preferred PCBA that's shy a function or few.
I create defects (design, implementation, layout, test); therefore, I patch (software patches, firmware patches, hardware patches)
0.8mm thick copper clad FR4 can be cut with scissors (1.6mm by metal shears)
What’s All This Pease Prototype Stuff, Anyhow? | Electronic Design
Digging through boxes of the prototype circuits that Bob Pease had amassed over the years proved to be a fun time for all involved.
Paul Rako | Aug 16, 2019
[after photo 7]
On the top was another prototyping technique I had not seen. Pease cut copper-clad board material into long narrow strips. He then soldered three of those strips to other boards, spaced out so he could solder components in between. I could see the strips carrying positive and negative power, as well as a ground strip in the middle. You could use the other sides of the copper-clad to interconnect intermediate circuit nodes. Pease was clever in everything he did.
The back of the board showed how Pease hacked in a few discrete components (Fig. 17).
17. The backside of one of the prototype Philbrick cards, showing some cuts, jumps, and added components.
add diodes, transistors, op amps, comparators, glue digital logic (small parts) (add functions or enhance reduce EOS)
SchmartPatch - Schmartboard, Inc.
edit : strikethru
Are these SPI or I2C?
If SPI, you can wiggle the data line all you like as long as the clock line is not wiggled!
Same for I2C, you can wiggle the data line as long as the clock line is held high.
Button inputs can be used for temporary outputs, just don't use the button while debugging.
Lots of ways to find a temp spare debug pin.
May I ask what the trouble is to use the 1ms timer ?
Just to be sure : Have a timer interrupt that fires 1x per second and counts the ticks since startup (uint32), just as the Arduino has millis();
Before the testroutine, use t1=millis();
After the testroutine, use t2=millis();
Later duration=t2-t1;
