Problem with the Example Light Sensor code of atxmega128a1 and FLIP
2 posts / 0 new
The example code of Light sensor in Atmel Studio of the board wont get uploaded on the board using FLIP. As soon as we select the file it will give an error that "Address is out of range" which is not because size of the file is too big as bigger codes are running fine. So I tried finding some alternative to FLIP but couldn't find one that supports atxmega128a1. Can someone help with this issue? At least the example code should run fine!
 * \file
 * \brief Common Sensor Service Light and Proximity Sensor Example
 * Copyright (c) 2012-2018 Microchip Technology Inc. and its subsidiaries.
 * \asf_license_start
 * \page License
 * Subject to your compliance with these terms, you may use Microchip
 * software and any derivatives exclusively with Microchip products.
 * It is your responsibility to comply with third party license terms applicable
 * to your use of third party software (including open source software) that
 * may accompany Microchip software.
 * THIS SOFTWARE IS SUPPLIED BY MICROCHIP "AS IS". NO WARRANTIES,
 * WHETHER EXPRESS, IMPLIED OR STATUTORY, APPLY TO THIS SOFTWARE,
 * INCLUDING ANY IMPLIED WARRANTIES OF NON-INFRINGEMENT, MERCHANTABILITY,
 * AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT WILL MICROCHIP BE
 * LIABLE FOR ANY INDIRECT, SPECIAL, PUNITIVE, INCIDENTAL OR CONSEQUENTIAL
 * LOSS, DAMAGE, COST OR EXPENSE OF ANY KIND WHATSOEVER RELATED TO THE
 * SOFTWARE, HOWEVER CAUSED, EVEN IF MICROCHIP HAS BEEN ADVISED OF THE
 * POSSIBILITY OR THE DAMAGES ARE FORESEEABLE.  TO THE FULLEST EXTENT
 * ALLOWED BY LAW, MICROCHIP'S TOTAL LIABILITY ON ALL CLAIMS IN ANY WAY
 * RELATED TO THIS SOFTWARE WILL NOT EXCEED THE AMOUNT OF FEES, IF ANY,
 * THAT YOU HAVE PAID DIRECTLY TO MICROCHIP FOR THIS SOFTWARE.
 * \asf_license_stop
 * \mainpage
 * \section intro Introduction
 * This application obtains sensor data from a light and proximity sensor
 * device installed on an Atmel development board.
 * \section contactinfo Contact Information
 * For further information, visit
 * <a href="http://www.atmel.com/avr">Atmel AVR</a>.\n
 * Support and FAQ: https://www.microchip.com/support/
 * Support and FAQ: visit <a href="https://www.microchip.com/support/">Microchip Support</a>
#include <stdio.h>
#include <asf.h>
#include <led.h>
/* Configuration constants */
#define LIGHT_SAMPLE_RATE   (10)   /* Light sensor sample rate (Hz) */
#define PROX_SAMPLE_RATE    (10)   /* Proximity sensor sample rate (Hz) */
#define SET_PROX_THRESHOLD  (true) /* If true, manually set proximity
	                            * threshold */
#define PROX_THRESHOLD      (100)  /* Manual prox sensor threshold for "near" */
#define SET_PROX_CURRENT    (true) /* If true, manually set proximity current */
#define PROX_CURRENT_mA     (50)   /* Current for proximity sensor LEDs (mA) */
#define PRINT_BANNER        (true) /* If true, print sensor config
	                            * information */
#define SCALED_DATA         (true) /* If true, convert sensor data to standard
	                            * units. */
/* Hardware environment constants */
#define ACTIVITY_LED        (LED1) /* Which LED to blink to show activity */
/** Strings to display based on proximity values */
static const char *const prox_labels[4] = {
	"none  ",               /* PROXIMITY_NONE */
	"FAR   ",               /* PROXIMITY_FAR */
	"MEDIUM",               /* PROXIMITY_MEDIUM */
	"NEAR  "                /* PROXIMITY_NEAR */
/** \brief Light & proximity sensor demo application entry
 * After initializing the Xplained platform and sensor boards, this application
 * attaches descriptors to the ambient light and proximity sensor devices on
 * an Xplained inertial sensor board.  The sensor data, which is formatted and
 * printed via printf() after being read, can be viewed with a serial terminal
 * application on a machine attached to the USB interface on the Xplained
 * board.
	sensor_t light_dev;     /* Light sensor device descriptor */
	sensor_t prox_dev;      /* Proximity sensor device descriptor */
	/* Initialize the board (Xplained UC3 or XMEGA & Xplained Sensor boards)
	 * I/O pin mappings and any other configurable resources selected in
	 * the build configuration.
	sensor_platform_init();
	/* Attach descriptors to the defined sensor devices. */
	sensor_attach(&light_dev, SENSOR_TYPE_LIGHT, 0, 0);
	sensor_attach(&prox_dev, SENSOR_TYPE_PROXIMITY, 0, 0);
	if (light_dev.err || prox_dev.err) {
		puts("\rSensor initialization error.");
		while (true) {
			/* Error occurred, loop forever */
	/* Print sensor information */
	if (PRINT_BANNER) {
		static const char *const banner_format
			= "%s\r\nID = 0x%02x ver. 0x%02x\r\n"
				"Bandwidth = %d Hz  Range = +/- %d\r\n\n";
		uint32_t id;
		uint8_t version;
		int16_t freq, range;
		sensor_device_id(&light_dev, &id, &version);
		sensor_get_bandwidth(&light_dev, &freq);
		sensor_get_range(&light_dev, &range);
		printf(banner_format, light_dev.drv->caps.name,
				(unsigned)id, (unsigned)version, freq, range);
		sensor_device_id(&prox_dev, &id, &version);
		sensor_get_bandwidth(&prox_dev, &freq);
		sensor_get_range(&prox_dev, &range);
		printf(banner_format, prox_dev.drv->caps.name,
		delay_ms(500);
	/* Set sample interval for the light sensor */
	if (sensor_set_sample_rate(&light_dev, LIGHT_SAMPLE_RATE) != true) {
		printf("Error setting light sensor sample rate.\r\n");
	/* Set sample interval for the proximity sensor */
	if (sensor_set_sample_rate(&prox_dev, PROX_SAMPLE_RATE) != true) {
		printf("Error setting proximity sensor sample rate.\r\n");
	/* Select all proximity sensor channels */
	sensor_set_channel(&prox_dev, SENSOR_CHANNEL_ALL);
#if (SET_PROX_THRESHOLD == true)
	/* Manually set proximity threshold values for each channel */
	/* Otherwise, sensor will use values previously stored in nvram. */
	sensor_set_threshold(&prox_dev, SENSOR_THRESHOLD_NEAR_PROXIMITY,
			PROX_THRESHOLD);
#endif
#if (SET_PROX_CURRENT == true)
	/* Manually set LED current value for each channel */
	/* Otherwise, sensor will use default values. */
	sensor_set_current(&prox_dev, PROX_CURRENT_mA);
#endif
	/* Initialize sensor data descriptors for scaled vs. raw data. */
	static sensor_data_t light_data = {.scaled = SCALED_DATA};
	static sensor_data_t prox_data  = {.scaled = SCALED_DATA};
	while (true) {
		LED_Toggle(ACTIVITY_LED);
		/* Read sensor values */
		sensor_get_light(&light_dev, &light_data);
		sensor_get_proximity(&prox_dev, &prox_data);
		/* Print sensor values */
		if (SCALED_DATA) {
			printf("light = [%5d]\r\n",
					(int16_t)light_data.light.value);
			printf("prox  = 1:%s 2:%s 3:%s\r\n",
					prox_labels[prox_data.proximity.value[0]],
					prox_labels[prox_data.proximity.value[1]],
					prox_labels[prox_data.proximity.value[2]]);
		} else {
			printf("prox = [%.5x, %.5x, %.5x]\r\n",
					(int16_t)prox_data.proximity.value[0],
					(int16_t)prox_data.proximity.value[1],
					(int16_t)prox_data.proximity.value[2]);
		delay_ms(500);
	return 0;
Topic locked
