ATMega8 1 USART for 2 "Consumers"
20 posts / 0 new
Hello
My ATMega8 has got only 1 USART however I'd like to hook up 2 "consumers" - one XBEE Module (to communicate with a 2nd ATMega via XBEE) and a line to my computer to show the contents of the transferred data via hTerm.
Is it possible to have 2 "consumers" on one USART or poses this some kind of "overload" to the USART?
best regards
Hero_123
It's quite tricky to multiplex a UART. You have a couple of options:
1) implement one of the UARTs as a "soft UART" - that is a UART that is "faked" by simply switching pins on/off form time to time. It's very easy to do the transmission side of a UART this way but more complex to do the receive side so if one channel is only or mainly output only then do that one as soft UART
2) a much better idea is to use an AVR that has 2 or more UARTs. For example the 40 pin mega164P/mega324P/mega644P/mega1284P range have two.
You mean like this:
                   | UART 1 |                    | UART 2 |
                   |   Rx   |                    |   Rx   |
| UART Tx +------------+-----------------------------+
Yes, of course that's possible - but it means that both "consumer" UARTs will receive everything.
If that's OK in your application, then problem solved!
laugh
Otherwise, as clawson says, you could either multiplex the "consumers", or add a soft UART in your AVR.
But, by far the best solution is:
it's not like they are rare or difficult to obtain these days!
(edited)
An Atmega808 costs $0.76 (for one) and has three UARTs in a 32 pin package (so it has to be SMD)
Yes it is very easy to do with one sender and two receivers, just connect the TXD pin of the AVR to the RXD pin(s) of the two receivers and of course they also need a common GND.
This does ASSUME all three units are TTL level comms!
Indeed.
It was implied in my original diagram so, to be explicit:
                   | UART 1 |                    | UART 2 |
                   | Rx GND |                    | Rx GND |
| UART Tx +----------+-----------------------------+   |
=====+===================+=============================+== GND
or add appropriate level shifters as required
Andy, how do you make your ascii drawings?
That one was just by laborious use of the spacebar, '+', '-', etc, keys in the forum's code editor.
With a lot of copy & paste.
Otherwise, I use a text editor.
I find CodeWright is good for this, as it puts in all the leading spaces for you when you type a character "in mid air".
I guess another option would be to fill a page with spaces, and use overtype ...
That's how I have done it, lots of work.
Google is your friend folks....
            Cliff drew all this in about 1 minute....
+--------------------------------+        A pointy straight line
|        This is Box 1           |            |
|                                |            v
+---X----------------------------+                       |
 XXX                   |                                 |
XX                     |       This is box 2             |
XX              XXXX   |                                 |
 XXX          XX   XXXXX                                 |
   XXXXXXXXXXX         |                                 |
A wiggly wire
£5 buys you the URL devil
OK, I'm not that mean - this looks like a lot of fun...
Hopefully the tool bar items are obvious when you are done use the one that looks like:
(do you see what I did there? ;-)
That gives "Export" and the diagram appears in a box where you can copy it from and paste it here.
The XBEE modules use 3v3 logic levels so BE CAREFUL or you WILL blow the pins....
If yu are doing simple "Talk to the XBEE, then transfer the data to the PC then it is certainly very simple to use a multiplexer IC and some additional pins from the AVR to steer the data.  NO need for anything else.  BUT, you need to use buffers for storing the data from each consumer in the AVR while you set up the steering logic.
Just keep in mind the XBEE is 3v3 and its NOT forgiving.
LOL - the first suggestion as I type "asciiflow" into Google is, "asciiflow alternatives"
laugh
Hello clawson, hello awneil, hello ki0bk, hello jgmdesign
Thanks a lot for your fast answers yessmiley
My idea was to exchange data between those 2 ATMega8 via USART and XBEE (both transmit & receive data) and my PC is hooked up to one USART (in parallel to one XBEE) to "listen" to the transmitted data of that ATMega8; both ATMega share the same powersupply.
@clawson - yeah, best would be using two seperate usarts on each ATMega however I can only use either ATMega8 or ATMega168 or ATMega328 as both are sitting on hard wired boards with an 28-pin socket(need ATMega with 14 pins each side).
So one option were a "soft usart"; another possibility were that "multiplexing" solution.
A third option - I have already established a SPI communication between those 2 ATMega8 and I could switch one to "Receive" and the other to "Transmit" via SPI command and vice versa.
@awneil - your picture - great!! Did help me a great deal! So it's no problem to have my XBEE and my PC hooked up to the same USART.
@jgmdesign - yeah, thanks for that advice; my XBEEs are sitting on boards with a level converter 5V -> 3.3V.
"Steering logic" with multiplex IC - good idea! My send/receive data are stored in a buffer (small one, though).
best regards
Hero_123
Yes, there is no problem at all to do that (paying attention to voltage levels, of course) - it's a standard approach:
Of course, if you want to see "both sides" of the communication (what the AVR sends to the XBee, and what the XBee sends back to the AVR), you need two terminals:
https://www.avrfreaks.net/comment/2306116#comment-2306116
When you're actually wanting to watch the comms between the 2 devices, you would not use a separate UART.
The advantage of having a separate UART is that it can send debug information other than the comms between the 2 parts.
It was not clear from your OP what you were actually asking.
Hello awneil
Thanks a lot for your answer smiley
Sorry that I wasn't clear enough in my OP - my fault - it's a bit tricky to properly ask a technical question when not being a native speaker frown (it's sometimes also tricky even WHEN being a native speaker).
best regards
Hero_123
That's true.
Often a diagram helps ...
Hello awneil
That thought occured to me just a few minutes ago, too - next time I do know better wink
best regards
Hero_123
And you can have a go with that clever ASCII-art app that clawson found!
Hello awneil
yeswink
best regards
Hero_123
