Effect of empty while() loop
11 posts / 0 new
Hello, after i checked that empty while() loops have a undesired effect to my program, i decided to write the simple below program:
//just before main():
    stop = 0;
    while(stop ==0){
//external interrupt: (when i activate it, the var stop changes)
ISR(INT0_vect){
        stop =1;
The above program, will never leave while(stop == 0), no matter how many times i activate the interrupt. The solution was to add a _delay_ms() inside while():
    stop = 0;
    while(stop ==0){
     _delay_ms(10);
ISR(INT0_vect){
        stop =1;
Now, it worked fine, and passed the while() loop. I have come across this 'issue' many times before, and i always solved it using delay(). But not i think its the moment of truth. What is going on? Why do i need the delay(), or a -kind of- big code inside while() to make it work?
My guess is, the compiler optimizes the code... If that is the case, how can i avoid code optimization, or, what is a way around?
thanks
That's the most important part of the code and you haven't shown that??
Anyway is "stop" set to be volatile? - it MUST be for all the usual reasons.
I did not bother to show that part, since i know it works (because the whole code works using _delay_ms() )
And thanks! it worked. I set the stop to volatile and it works. I now can see... https://stackoverflow.com/questions/4437527/why-do-we-use-volatile-keyword
Now i need to know when should i make a variable volatile, since i dont know which of my variables the optimizer might mess with, which seems to answered here: https://stackoverflow.com/questions/17708835/is-it-bad-if-all-variables-are-defined-as-volatile-on-avr-programming
It's also the top entry in the FAQ in the user manual:
https://www.nongnu.org/avr-libc/user-manual/FAQ.html#faq_volatile
Variables should be "volatile" when they are accessed in more than one thread of execution. In an AVR program that usually means a variable that is accessed in both main() and an ISR().
Del
Dessine-moi un mouton
AndreyT wrote:
Del
...Taco.  Like Marco...Polo?
Del Shannon?
Lana Del Rey, obviously
digitalDan wrote:
Del Shannon?
I'm going to Runaway from that one.
And her little daughter Marina.
(I suppose her son is a Playa)
No es bueno!
Dude.  You're getting a Del.  S.
