global variable struggle
6 posts / 0 new
Hello all,
I have been struggling with my code, resp. understanding, what is going on.
My original task is to produce 40 kHz PWM signal on OC0A pin (Arduino Uno PIN6) for 1 second, than put the PIN6 off for 1 second and repeat this forever. I wrote code below BUT it does not work. In time, I was able to make it work by exchanging if(Count>80000){  for if(TCCR0B == 0x00){. Furthermore, I was able to find out, that problem is in the condition itself because variable Count in while loop keeps value 0 because condition if(Count==0){ works. I just do not understand WHY. Variable count is declared as global! Any explanation, link or hint is highly welcomed.
#define F_CPU 16000000
#include <util/delay.h>
#include <avr/interrupt.h>
unsigned long int Count = 0;
	DDRD = 0x40;	// set port D as all outputs
	PRR |= (0 << PRTIM0);	//enable timer T0
	TIMSK0 |= (1 << OCIE0A);    //Set the ISR COMPA vect
	sei();         //enable interrupts
	TCCR0A = 0x42;	// CTC, no prescaler, OCR0A = top
	TCCR0B = 0x01;	// no prescaler
	OCR0A = 200;	// 12.5 usec without prescaler
	while (1)
	if(Count>80000){
//	if(TCCR0B == 0x00){
		_delay_ms(1000);
		Count = 0;
		TCCR0B = 0x01;
ISR (TIMER0_COMPA_vect)  // timer1 OCR1A interrupt
	if(Count>80000){	// 1 second with 80 kHz counting
		TCCR0B = 0x00;	// stop the timer
		TCNT0 = 0x00;	// clear T0
	Count++;
Always learning (struggling)
You’ve selected CTC mode, so why do you stop the timer and zero it? That’s what CTC does for you!
Declare count volatile.
Count is shared between ISR() and main(). It *must* be "volatile". Also, as a variable that is wider than 1 byte it must be atomically protected.
PS what is the granularity of your time base. Running a ticker at 80kHz with a period of 12.5us seems very unwise unless you really do need a granularity so fine. Most embedded systems would be happy with a "tick" at 10ms or around there which suggests a prescale in the /1024 region.
Otherwise your program is going to spend a large percentage of the CPu time simply servicing the ticker interrupt.
What's more, if you change the timebase you can probably reduce the width of "count" to just 16 bits - but that still needs atomic protection.
volatile ..... what a magical word ..... it works!
Thanks a lot to you both for your help!
Kartman wrote:
You’ve selected CTC mode, so why do you stop the timer and zero it? That’s what CTC does for you! Declare count volatile.
I stop the timer so it does not toggle OCOA pin anymore. TCNT0 zeroing makes sure, that there is no residual value left. So once timer starts again I get 40 kHz signal at very first cycle.
The 40kHz signal is going to feed ultrasonic sensor. 80 000 ticks is just arbitrary number to make it last for 1 second. In real application there will be just a few cycles. 1 byte variable will surely be enough.
I am afraid I do not understand what does "atomically protected" mean. Can you explain or forward me to some source of information?
https://www.nongnu.org/avr-libc/user-manual/group__util__atomic.html
It's not magic - it's standard 'C' !
Nothing specific to AVR or microcontrollers - it applies anywhere you have multiple "threads" of execution, or data that can get modified outside the compiler's visibility.
