Ensuring a TLC5947 device is disabled on power up.
16 posts / 0 new
Hi Guys,
I have a string of TLC5947's attached to an ATmega328p.  There is a pin(Blank Pin) on the TLC5947 that disables output if it is high.  Currently the first bit of code sets PD7 high in addition 10 a 10K resistor.
I want to have the TLC5947 blank pin high as the 328p is starting as the current draw with outputs on could stall the 328P before it executes the code.
Obviously the solution would be to have the TLC5947 Blank pin feed 5v from the board power, but I'm unsure as to the best way of configuring the Pin on the 328P such I can then bring the TLC5947 blank pin low.
I'm sure there's an obvious solution but it's escaping me at the moment.
Any help would be appreciated.
regards
Please provide:
Schematic
Link to what ever a TLC5947 is.
Or did you intend for us to look it all up?
Generally, if a pin needs to be high while an AVR is in reset, an external pull-up resister is used.
Ok, I pulled a DS, you need a 10k pull-up on that line so the AVR can init the device before the outputs
Are enabled by putting “blank” line low!
sorry, my bad, data sheet is here
Thanks, but yes I understand that.  My question is, how do I pull it down on command?
regards
regards
Connect it to a port pin, once the chip is initiated, make your port pin an output and set it low.
Ahh,
Just to get this straight that's all I need to do with the setup below?
regards
5v -> 10k resistor ----- > Blank pin on TLC
                             v
                           PB7 on 328P (as output)
So setting PB7 low will sink voltage?
nikm wrote:
Ahh,
regards
                             v
Yes!
Sweet, thank you.
That said I'm having a hard time understanding why setting an output pin to low would sink the line to 0v unless the effect is to ground it.
regards
Why is that hard to understand?
"Setting a pin low" means, literally, "pulling it to 0V".
"Set pin low" and "set pin to 0V" and "ground the pin" are pretty much synonymous.
to put it another way: "low" = 0V = ground (conventionally).
Now I understand.  Thanks for the explanation
regards
The issue isn't so easy to resolve I fear.  As I understand from reading the data-sheet, on startup all ports are inputs.
The problem I'm trying to solve is those ms from when power is connected before any code can change pin state.  The TLC5947 Blank connection needs to stay high so as to disable output as the uncontrolled output could be enough to drop the voltage to the atmega so as to cause a brown out.
Why they didn't default to a low to disable output I don't know but that's the way it is.  I'm starting to think I need a transistor to manage this. one where the 'switch' is normally closed
regards
Why are you making your life difficult?
Just put a pull up resistor on the BLANK pin and you are all set.
What is the effect of the associated input pin during startup, won't it sink the voltage thereby bringing the blank pin low and therefore making the TLC active?
regards
No.
When powering up all of the micro's I/O pins are in INPUT mode.
That is a high impedance, input mode.
The micro will not make the pin High or Low until it is powered up, and the software sets the pin for output mode, and makes it high or low.
The pull-up resistor will hold the device's pin high while the micro is powering up, (and the micro's I/O pins are still in input mode).
Once the software makes the I/O pin an output, and low, then the pin will go low.
It will then draw current through the resistor as it holds the lower end at ground level.
The device's pin will be low when the micro pulls its I/O pin low.
Excellent,  many thanks
regards
You may want to  pull it up using the high voltage supply (you using 12 or 24v??).  The reason is you want you blank pin to go high as soon as the led chip has power.  If your 5V supply is coming up later on or slower (say your 5V has a huuuge filter cap), tying it to 5V may be a few milliseconds of delay (so leds/chip has 12V power before 5v/blank pin). You could use an NPN transistor to pull the pin low via the micro (the NPN prevents back-driving the AVR body diodes while AVR supply is rising). In 95% of the the cases this is not a factor.
