Studio sometimes ostensibly program
4 posts / 0 new
I have notice, that sometimes Studio leaves the old code inside the chip but claims there's the new one.
For ex. I fire up the studio, assemble and run the code, program the flash choosing: Use Current Simulator/Emulator FLASH Memory. Everything works so far. Code inside the AVR is what it should be. Then I make changes to program and again: assemble and run the code, program the flash. Studio verify that the code inside the chip is a same as in Studio... but it's not actually there?
This happens very rarely... or do I forget run the code before programming?
Regards
heguli
More likely you're forgetting to compile before loading your code onto the AVR. I've made this mistake a couple of times myself. Studio does not seem to check that the hex file is newer than all the associated source.
"Now, wait a minute, I changed that code!"
Stu (That's my story and I'm sticking to it! :wink: )
Next time Atmel make's the user survey have to mention this issue... if I remember? :)
Regards
heguli
Remember what? ;)
