4809 / 0-series TCA CMPnEN pin-select documentation does not make sense
4 posts / 0 new
Hi All,
I'm hacking on my Curiosity Nano with atmega4809.   I'm trying to set up TCA0 to toggle pin 5 on port F (the user LED).
The 0-series datasheet indicates I can direct TCA0 output to PORTF via PORTMUX.TCAROUTEA = PORTMUX_TCA0_PORTF_gc;
The include file thinks the three bits for CMP[2:0]EN are independent pin bits, which does not make sense.
The 0-series datasheet (in TCA CTRLB section) is ambiguous IMO (see below).
I think that I should be able to set CtRLB.CMP[2:0]EN to 5 to select pin 5.
EDIT: That is, it makes more sense to me to have 3 bits indicate which single pin of a port should be output rather than independent control of only 3/8 pins of a port.
What do you think?
#define TCA_SINGLE_CMP0EN_bm  0x10  /* Compare 0 Enable bit mask. */
#define TCA_SINGLE_CMP0EN_bp  4  /* Compare 0 Enable bit position. */
#define TCA_SINGLE_CMP1EN_bm  0x20  /* Compare 1 Enable bit mask. */
#define TCA_SINGLE_CMP1EN_bp  5  /* Compare 1 Enable bit position. */
#define TCA_SINGLE_CMP2EN_bm  0x40  /* Compare 2 Enable bit mask. */
#define TCA_SINGLE_CMP2EN_bp  6  /* Compare 2 Enable bit position. */
>What do you think?
The datasheet describes correctly- the CMPEN0 bit controls WO0, CMPEN1 - WO1, CMPEN2 - WO2.
In split mode, you also control WO3/4/5.
Portmux controls what those WOn pins will be.
PF5 is WO5 and only works in split mode, so you would then set HCMP2EN to 1 (and portmux set accordingly). If using normal mode, choose a pin that can do WO0/1/2.
Great!   Thanks for the help.
I remember that there was a bug within the PORTMUX...maybe you should take a look at the Errata:
http://ww1.microchip.com/downloa...
Moe
