using 3-15v buckboost but requires 5volt to enable?
6 posts / 0 new
Not really AVR related but using this with an AVR project.
I bought a DC-DC 3V-15V to 5V Fixed Output Automatic Buck Boost Step Up Step Down Power modal.
Is it just me or the author nutty? In order to use it I must pull up on the EN pin. Strangely the enable pin requires more then 3.4 volts? In my application I only have 3.4 volts available.How can I satisfy the TTL ? use a voltage multiplier maybe 2 caps, 2 diodes?
using two caps and two 1n4148 diodes (in a v doubler paradigm) I can make it work but I must touch the vout. So clearly my capacitance is wrong. I tried two 1uf's and played with this calculator.
https://www.extremeelectronics.c...
but I'm not sure what the frequency would be in the design I used.
Voltage doublers (using diodes and capacitors) only work with an A.C. input voltage.  A D.C. input voltage is put into the DC-DC module.  When you touch Vout you are causing 'something' to oscillate.  And those oscillations are creating the output voltage from the doubler.
  Personally, I would never touch with my actual fingertip anything that is connected to a circuit designed to increase voltage.  But I am one of those electronic technicians that love data but hate electricity.  Anything over +9V and I want hazardous-duty extra pay.  I'm glad that I don't have to deal the +300 volt levels that used to be needed for vacuum tubes that worked with milliVolt input signal levels.
How do you know what the connections are on the DC-DC module that you have bought?   I can find no schematic on the web for the red board shown in the image.  I found several photos of the the board shown in the message, but no documentation.   Do you have a schematic?   What is the six-pin IC that is doing the switching?  Do you have a data sheet for it?
So I'd need to create an oscillation, not sure I want that.
The module is marked on back.
vin-
vin+
vout-
vout+
en
example 1 that I tried.
vin-  -> gnd
vin+ -> 7v
vout- -> gnd
vout+ -> 5v
en -> 7v
example 2 that I tried.
vin-  -> gnd
vin+ -> 3.4v
vout- -> gnd
vout+ -> 2.1v
en -> 3.4v
example 3 that I tried.
vin-  -> gnd
vin+ -> 5v
vout- -> gnd
vout+ -> 5v
en -> 5v
and also this one works
vin-  -> gnd
vin+ -> 3.4v
vout- -> gnd
vout+ -> 5v
en -> 5v
but I do not have any 5v input.
" What is the six-pin IC that is doing the switching? "  I was guessing a buckboost but no I do not know. it reads
b6289u
My guess is this one
https://translate.google.com/tra...
Try tying your EN to Vin......assuming EN can tolerate 15V.   At low voltages, the trip voltage may move down (cmos is often spec's as % of the supply, perhaps with some other constraints) .
Quit trying to calibrate the unit by trimming off part of the inductor angel
Looks the same as this 'S09 buck boost' module on aliexpress: https://www.aliexpress.com/item/...
The questions & answers on that link say that the EN input turns the module off if connected to gnd and turns the module on if left open or connected to the +vin
There is a specification pdf for the 12v output version of the module here (under Related Information): https://handsontec.com/index.php...
