How to change a folder name in solution?
4 posts / 0 new
Dear community,
I would like to change a path name without destroying the project solution. Is that easy? Within the solution I want to deposit different versions of the Project. How can I change testEdip43Terminal to SolarmonV1 ??
friendly regards
Ellen
AS7, ATmega128A, Atmel ICE
I am very satisfied with this development Environment.
Senior electrical engineer
I usually find it best simply to remove the files in the project explorer and then re-add them form the new location.
(an alternative "internal" way is simply to edit the XML project file).
That seems to be the only meaningful way.
Create a new Project within the solution. Add existing items from the origin Project (without .cproj file)
And then remove the first one.
thanks
Ellen
Hi All,
I've found a second solution that works:
1. Solution Explorer (AS7) > right mouse button click on project > Contextmenue > Remove (project)
2. save Solution
3. Windows Explorer > Rename Path
4. Open Solution in AS7 (emty, no projects)
5. Solution Explorer > right mouse button click on Solution > Contextmenue > Add > Existing project
6. Search .cproj File under the folder to be added and click
7. ready
Ellen
