Help with using two interrupt pins in ATmega328p
5 posts / 0 new
Hello everyone, I wrote a program that works with a single interrupt. I want use two interrupt ports in the same time. The following is my code. Please tell me what I am doing wrong since this does only work for I2.
.ORG 0
    JMP MAIN
.ORG 0x02
    JMP I1
.ORG 0x04
    JMP I2
MAIN:
//INT0
        LDI R20,HIGH(RAMEND)
        OUT SPH,R20
        LDI R20,LOW(RAMEND)
        OUT SPL,R20
        LDI R20,0x2
        STS EICRA,R20
        SBI PORTD,2
        LDI R20,1<<INT0
        OUT EIMSK,R20
//INT1
        LDI R22,HIGH(RAMEND)
        OUT SPH,R22
        LDI R22,LOW(RAMEND)
        OUT SPL,R22
        LDI R20,0x4
        STS EICRA,R22
        SBI PORTD,3
        LDI R22,1<<INT1
        OUT EIMSK,R20
        SEI
HERE:    JMP HERE
I1:
        //Do routine 1
        RETI
I2:  //Do routine 2
        RETI
Thank you very much for your time and attention.
What I am trying to accomplish here is, when PD2(int0) goes low - perform I1
                                                          when PD3(int1) goes low - perform I2
.ORG 0
    JMP MAIN
.ORG 0x02
    JMP I1
.ORG 0x04
    JMP I2
MAIN:
//INT0
        OUT SPH,R20
        LDI R20,LOW(RAMEND)
        OUT SPL,R20
        LDI R20,0x6
        STS EICRA,R20
        SBI PORTD,2
        SBI PORTD,3
        LDI R20,(1<<INT0) | (1<<INT1)
        OUT EIMSK,R20
        SEI
HERE:    JMP HERE
I1:
        //Do routine 1
        RETI
I2:  //Do routine 2
        RETI
No use setting up the stack pointer twice and you were overwriting the EICRA and EIMSK registers so that only the last setting actually worked.
Thank you very much kind sir. I wrote the code I posted with no sleep :(. Your solution is actually working. Another problem I am facing is is switch bouncing. I was going to use a capacitor. Would you mind helping with adding a delay inside the main program?
Thank you very much again for the help kind sir:)
I think you're stretching the friendship here. It's your homework - it's for your benefit. Why would you use external interrupts for switch inputs? Set up a timer to read the switches at a regular interval - say 10ms. No delays needed - just count highs or lows.
Sorry If I overstepped my boundaries. I am a student aye. But no I don't get this for homework. I am 16 and doing this as a hobby. I am trying to build circuits using interrupts.  I am following this slide series I found from the internet. I haven't studied timers yet. I see you have given a hint. Which is very helpful to me. Thank you sir, I'll stop this here.
