Moving from C to C++, weird issue
6 posts / 0 new
After the last 8 years of writing in plain C for my Xmega projects I took it upon myself to learn some C++ and make a C++ version of one of my telescope controllers.
Making the migration to objects went pretty easy, but one thing though was a "silent killer" that bit me and took me a few hours to find. I use the delay_ms and delay_us functions once in a while. For example, there is an i2c joystick I use, and you have to:
1) Do an I2C write, saying "I want to read the joystick".
2) ( wait for some time, let the joystick prepare the data )
3) Do an I2C read and get the results.
That delay at step #2 is using delay_us and it turns out in C++ it was running about 3 times faster than it had when compiled under "C". Even looking at the signals on the scope I didn't catch it right away -- as all the I2C operations I saw looked correct, it was the time duration *between* the I2c operations that got me.
Why would this delay change so dramatically?
Thanks!
Mike in Alaska
Could you put your code, at least for the step #2?
Because you are defining F_CPU as a -D under "Symbols" and (curiously) AS7 has two different Symbols settings, one for C and one for C++.
Look at the assembly.  I use "avr-objdump -d main.elf > main.asm" to generate asm from my binaries.  Another approach is to replace "-c" with "-S' on your avr-gcc or avr-g++ commands, if you use those.
Thanks for the tips. I actually had tried setting the F_CPU in both those symbols blocks. In fact I had to put weird values into those to make delay_us or delay_ms seem normal they were terribly wrong.
I used the scope to measure RS232 bit rates at 9600 baud and also the I2c bit rates and they looked correct. Just that delay_us and delay_ms seem whacked. I'll use the scope this time to see the relationship of F_CPU to the delay times it produces.
Perhaps you're just mis-using them, and the abuse manifests differently in the 2 cases?
As ever, you'll need to post a minimum complete project for each case which demonstrates the issue.
