I have been trying to get these transceivers working for about a week now. I have used every library i can find and still no luck. I recently found a tutorial with instructions to use these radios found here: http://gizmosnack.blogspot.com/2013/04/tutorial-nrf24l01-and-avr.html
I have not been able to receive or transmit anything. I am using 2 Atmega32 and 2 radios.
My code is mostly based off his. Any suggestions and or libraries would help. Thanks!
TX Code:
#include <avr/io.h> #include <stdio.h> #define F_CPU 8000000UL // 8 MHz #include <util/delay.h> #include <avr/interrupt.h> #include <CEC_UART.h> #include "nRF24L01.h" #define SET_BIT(Reg, Bit) (Reg |= (1 << (Bit))) #define CLEAR_BIT(Reg, Bit) (Reg &= ~(1 << (Bit))) #define FLIP_BIT(Reg, Bit) (Reg ^= (1 << (Bit))) #define TEST_BIT(Reg, Bit) ((Reg >> (Bit)) & 1) #define W 1 #define R 0 #define dataLen 3 //längd på datapacket som skickas/tas emot uint8_t *data; uint8_t *arr; /*****************SPI*****************************/ //Skickar data mellan chip och nrf'ens chip //initiering void InitSPI(void) { //Set SCK (PB5), MOSI (PB3) , CSN (SS & PB2) & C as outport //OBS!!! Måste sättas innan SPI-Enable neadn DDRB |= (1<<DDB7) | (1<<DDB5) | (1<<DDB4) |(1<<DDB2); /* Enable SPI, Master, set clock rate fck/16 .. kan ändra hastighet utan att det gör så mycket*/ SPCR |= (1<<SPE)|(1<<MSTR);// |(1<<SPR0) |(1<<SPR1); SET_BIT(PORTB, 4); //CSN IR_High to start with, vi ska inte skicka nåt till nrf'en ännu! CLEAR_BIT(PORTB, 2); //CE low to start with, nrf'en ska inte sända/ta emot nåt ännu! } //Skickar kommando till nrf'en å får då tillbaka en byte char WriteByteSPI(unsigned char cData) { //Load byte to Data register SPDR = cData; /* Wait for transmission complete */ while(!(SPSR & (1<<SPIF))); //Returnera det som sänts tillbaka av nrf'en (första gången efter csn-låg kommer Statusregistert) return SPDR; } //funktion för att hämta nåt av nrf's register uint8_t GetReg(uint8_t reg) { //andvändning: USART_Transmit(GetReg(STATUS)); //där status är registret du vill kolla _delay_us(10); CLEAR_BIT(PORTB, 4); //CSN low _delay_us(10); WriteByteSPI(R_REGISTER + reg); //Vilket register vill du läsa (nu med R_Register för att inget ska skrivas till registret) _delay_us(10); reg = WriteByteSPI(NOP); //Skicka NOP antalet byte som du vill hämta (oftast 1gång, men t.ex addr är 5 byte!) och spara isf inte i "reg" utan en array med en loop _delay_us(10); SET_BIT(PORTB, 4); //CSN IR_High return reg; // Returnerar registret förhoppningsvis med bit5=1 (tx_ds=lyckad sändning) } /*****************nrf-setup***************************/ //Ställer in nrf'en genoma att först skicka vilket register, sen värdet på registret. uint8_t *WriteToNrf(uint8_t ReadWrite, uint8_t reg, uint8_t *val, uint8_t antVal) //tar in "ReadWrite" (W el R), "reg" (ett register), "*val" (en array) & "antVal" (antal integer i variabeln) { cli(); //disable global interrupt if (ReadWrite == W) //W=vill skriva till nrf-en (R=läsa av den, R_REGISTER (0x00) ,så skiter i en else funktion) { reg = W_REGISTER + reg; //ex: reg = EN_AA: 0b0010 0000 + 0b0000 0001 = 0b0010 0001 } //Static uint8_t för att det ska gå att returnera en array (lägg märke till "*" uppe på funktionen!!!) static uint8_t ret[dataLen]; //antar att det längsta man vill läsa ut när man kallar på "R" är dataleng-långt, dvs använder man bara 1byte datalengd å vill läsa ut 5byte RF_Adress så skriv 5 här ist!!! _delay_us(10); //alla delay är så att nrfen ska hinna med! (microsekunder) CLEAR_BIT(PORTB, 4); //CSN low = nrf-chippet börjar lyssna _delay_us(10); WriteByteSPI(reg); //första SPI-kommandot efter CSN-låg berättar för nrf'en vilket av dess register som ska redigeras ex: 0b0010 0001 write to registry EN_AA _delay_us(10); int i; for(i=0; i<antVal; i++) { if (ReadWrite == R && reg != W_TX_PAYLOAD) { ret[i]=WriteByteSPI(NOP); //Andra och resten av SPI kommandot säger åt nrfen vilka värden som i det här fallet ska läsas _delay_us(10); } else { WriteByteSPI(val[i]); //Andra och resten av SPI kommandot säger åt nrfen vilka värden som i det här fallet ska skrivas till _delay_us(10); } } SET_BIT(PORTB, 4); //CSN IR_High = nrf-chippet slutar lyssna sei(); //enable global interrupt return ret; //returnerar en array } //initierar nrf'en (obs nrfen måste vala i vila när detta sker CE-låg) void nrf24L01_init(void) { _delay_ms(100); //allow radio to reach power down if shut down uint8_t val[5]; //en array av integers som skickar värden till WriteToNrf-funktionen //EN_AA - (auto-acknowledgements) - Transmittern får svar av recivern att packetet kommit fram, grymt!!! (behöver endast vara enablad på Transmittern!) //Kräver att Transmittern även har satt SAMMA RF_Adress på sin mottagarkanal nedan ex: RX_ADDR_P0 = TX_ADDR val[0]=0x01; //ger första integern i arrayen "val" ett värde: 0x01=EN_AA på pipe P0. WriteToNrf(W, EN_AA, val, 1); //W=ska skriva/ändra nåt i nrfen, EN_AA=vilket register ska ändras, val=en array med 1 till 32 värden som ska skrivas till registret, 1=antal värden som ska läsas ur "val" arrayen. //SETUP_RETR (the setup for "EN_AA") val[0]=0x2F; //0b0010 00011 "2" sets it up to 750uS delay between every retry (at least 500us at 250kbps and if payload >5bytes in 1Mbps, and if payload >15byte in 2Mbps) "F" is number of retries (1-15, now 15) WriteToNrf(W, SETUP_RETR, val, 1); //Väljer vilken/vilka datapipes (0-5) som ska vara igång. val[0]=0x01; WriteToNrf(W, EN_RXADDR, val, 1); //enable data pipe 0 //RF_Adress width setup (hur många byte ska RF_Adressen bestå av? 1-5 bytes) (5bytes säkrare då det finns störningar men långsammare dataöverföring) 5addr-32data-5addr-32data.... val[0]=0x03; WriteToNrf(W, SETUP_AW, val, 1); //0b0000 00011 motsvarar 5byte RF_Adress //RF channel setup - väljer frekvens 2,400-2,527GHz 1MHz/steg val[0]=0x01; WriteToNrf(W, RF_CH, val, 1); //RF channel registry 0b0000 0001 = 2,401GHz (samma på TX å RX) //RF setup - väljer effekt och överföringshastighet val[0]=0x07; WriteToNrf(W, RF_SETUP, val, 1); //00000111 bit 3="0" ger lägre överföringshastighet 1Mbps=Längre räckvidd, bit 2-1 ger effektläge hög (-0dB) ("11"=(-18dB) ger lägre effekt =strömsnålare men lägre range) //RX RF_Adress setup 5 byte - väljer RF_Adressen på Recivern (Måste ges samma RF_Adress om Transmittern har EN_AA påslaget!!!) int i; for(i=0; i<5; i++) { val[i]=0x12; //RF channel registry 0b10101011 x 5 - skriver samma RF_Adress 5ggr för att få en lätt och säker RF_Adress (samma på transmitterns chip!!!) } WriteToNrf(W, RX_ADDR_P0, val, 5); //0b0010 1010 write registry - eftersom vi valde pipe 0 i "EN_RXADDR" ovan, ger vi RF_Adressen till denna pipe. (kan ge olika RF_Adresser till olika pipes och därmed lyssna på olika transmittrar) //TX RF_Adress setup 5 byte - väljer RF_Adressen på Transmittern (kan kommenteras bort på en "ren" Reciver) //int i; //återanvänder föregående i... for(i=0; i<5; i++) { val[i]=0x12; //RF channel registry 0b10111100 x 5 - skriver samma RF_Adress 5ggr för att få en lätt och säker RF_Adress (samma på Reciverns chip och på RX-RF_Adressen ovan om EN_AA enablats!!!) } WriteToNrf(W, TX_ADDR, val, 5); // payload width setup - Hur många byte ska skickas per sändning? 1-32byte val[0]=3; //"0b0000 0001"=1 byte per 5byte RF_Adress (kan välja upp till "0b00100000"=32byte/5byte RF_Adress) (definierat högst uppe i global variabel!) WriteToNrf(W, RX_PW_P0, val, 1); //CONFIG reg setup - Nu är allt inställt, boota upp nrf'en och gör den antingen Transmitter lr Reciver val[0]=0x1E; //0b0000 1110 config registry bit "1":1=power up, bit "0":0=transmitter (bit "0":1=Reciver) (bit "4":1=>mask_Max_RT,dvs IRQ-vektorn reagerar inte om sändningen misslyckades. WriteToNrf(W, CONFIG, val, 1); //device need 1.5ms to reach standby mode _delay_ms(100); //sei(); } void reset(void) { _delay_us(10); CLEAR_BIT(PORTB, 4); //CSN low _delay_us(10); WriteByteSPI(W_REGISTER + STATUS); // _delay_us(10); WriteByteSPI(0b01110000); //radedrar alla irq i statusregistret (för att kunna lyssna igen) _delay_us(10); SET_BIT(PORTB, 4); //CSN IR_High } void receive_payload(void) { sei(); //Enable global interrupt SET_BIT(PORTB, 2); //CE IR_High = "Lyssnar" _delay_ms(1000); //lyssnar i 1s och om mottaget går int0-interruptvektor igång CLEAR_BIT(PORTB, 2); //ce låg igen -sluta lyssna cli(); //Disable global interrupt } //Sänd data void transmit_payload(uint8_t * W_buff) { WriteToNrf(R, FLUSH_TX, W_buff, 0); //skickar 0xE1 som flushar registret för att gammal data inte ska ligga å vänta på att bli skickad när man vill skicka ny data! R står för att W_REGISTER inte ska läggas till. skickar inget kommando efterråt eftersom det inte behövs! W_buff[]står bara där för att en array måste finnas där... WriteToNrf(R, W_TX_PAYLOAD, W_buff, dataLen); //skickar datan i W_buff till nrf-en (obs går ej att läsa w_tx_payload-registret!!!) sei(); //enable global interrupt- redan på! //USART_Transmit(GetReg(STATUS)); _delay_ms(10); //behöver det verkligen vara ms å inte us??? JAAAAAA! annars funkar det inte!!! SET_BIT(PORTB, 2); //CE hög=sänd data INT0 interruptet körs när sändningen lyckats och om EN_AA är på, också svaret från recivern är mottagen _delay_us(20); //minst 10us! CLEAR_BIT(PORTB, 2); //CE låg _delay_ms(10); //behöver det verkligen vara ms å inte us??? JAAAAAA! annars funkar det inte!!! //cli(); //Disable global interrupt... ajabaja, då stängs USART_RX-lyssningen av! } ///////////////////////////////////////////////////// int main(void) { uint8_t data[3]; data[0] = 1; data[1] = 2; data[2] = 3; UART_Init(9600); InitSPI(); nrf24L01_init(); while(1) { transmit_payload(data); UART_SEND_DECIMAL_INTEGER(data[2]); UART_CRLF(); } return 0; }
RX Code:
#include <avr/io.h> #include <stdio.h> #define F_CPU 8000000UL // 8 MHz #include <util/delay.h> #include <avr/interrupt.h> #include <CEC_UART.h> #include "nRF24L01.h" #define SET_BIT(Reg, Bit) (Reg |= (1 << (Bit))) #define CLEAR_BIT(Reg, Bit) (Reg &= ~(1 << (Bit))) #define FLIP_BIT(Reg, Bit) (Reg ^= (1 << (Bit))) #define TEST_BIT(Reg, Bit) ((Reg >> (Bit)) & 1) #define W 1 #define R 0 #define dataLen 3 //längd på datapacket som skickas/tas emot uint8_t *data; uint8_t *arr; /*****************SPI*****************************/ //Skickar data mellan chip och nrf'ens chip //initiering void InitSPI(void) { //Set SCK (PB5), MOSI (PB3) , CSN (SS & PB2) & C as outport //OBS!!! Måste sättas innan SPI-Enable neadn DDRB |= (1<<DDB7) | (1<<DDB5) | (1<<DDB4) |(1<<DDB2); /* Enable SPI, Master, set clock rate fck/16 .. kan ändra hastighet utan att det gör så mycket*/ SPCR |= (1<<SPE)|(1<<MSTR);// |(1<<SPR0) |(1<<SPR1); SET_BIT(PORTB, 4); //CSN IR_High to start with, vi ska inte skicka nåt till nrf'en ännu! CLEAR_BIT(PORTB, 2); //CE low to start with, nrf'en ska inte sända/ta emot nåt ännu! } //Skickar kommando till nrf'en å får då tillbaka en byte char WriteByteSPI(unsigned char cData) { //Load byte to Data register SPDR = cData; /* Wait for transmission complete */ while(!(SPSR & (1<<SPIF))); //Returnera det som sänts tillbaka av nrf'en (första gången efter csn-låg kommer Statusregistert) return SPDR; } //funktion för att hämta nåt av nrf's register uint8_t GetReg(uint8_t reg) { //andvändning: USART_Transmit(GetReg(STATUS)); //där status är registret du vill kolla _delay_us(10); CLEAR_BIT(PORTB, 4); //CSN low _delay_us(10); WriteByteSPI(R_REGISTER + reg); //Vilket register vill du läsa (nu med R_Register för att inget ska skrivas till registret) _delay_us(10); reg = WriteByteSPI(NOP); //Skicka NOP antalet byte som du vill hämta (oftast 1gång, men t.ex addr är 5 byte!) och spara isf inte i "reg" utan en array med en loop _delay_us(10); SET_BIT(PORTB, 4); //CSN IR_High return reg; // Returnerar registret förhoppningsvis med bit5=1 (tx_ds=lyckad sändning) } /*****************nrf-setup***************************/ //Ställer in nrf'en genoma att först skicka vilket register, sen värdet på registret. uint8_t *WriteToNrf(uint8_t ReadWrite, uint8_t reg, uint8_t *val, uint8_t antVal) //tar in "ReadWrite" (W el R), "reg" (ett register), "*val" (en array) & "antVal" (antal integer i variabeln) { cli(); //disable global interrupt if (ReadWrite == W) //W=vill skriva till nrf-en (R=läsa av den, R_REGISTER (0x00) ,så skiter i en else funktion) { reg = W_REGISTER + reg; //ex: reg = EN_AA: 0b0010 0000 + 0b0000 0001 = 0b0010 0001 } //Static uint8_t för att det ska gå att returnera en array (lägg märke till "*" uppe på funktionen!!!) static uint8_t ret[dataLen]; //antar att det längsta man vill läsa ut när man kallar på "R" är dataleng-långt, dvs använder man bara 1byte datalengd å vill läsa ut 5byte RF_Adress så skriv 5 här ist!!! _delay_us(10); //alla delay är så att nrfen ska hinna med! (microsekunder) CLEAR_BIT(PORTB, 4); //CSN low = nrf-chippet börjar lyssna _delay_us(10); WriteByteSPI(reg); //första SPI-kommandot efter CSN-låg berättar för nrf'en vilket av dess register som ska redigeras ex: 0b0010 0001 write to registry EN_AA _delay_us(10); int i; for(i=0; i<antVal; i++) { if (ReadWrite == R && reg != W_TX_PAYLOAD) { ret[i]=WriteByteSPI(NOP); //Andra och resten av SPI kommandot säger åt nrfen vilka värden som i det här fallet ska läsas _delay_us(10); } else { WriteByteSPI(val[i]); //Andra och resten av SPI kommandot säger åt nrfen vilka värden som i det här fallet ska skrivas till _delay_us(10); } } SET_BIT(PORTB, 4); //CSN IR_High = nrf-chippet slutar lyssna sei(); //enable global interrupt return ret; //returnerar en array } //initierar nrf'en (obs nrfen måste vala i vila när detta sker CE-låg) void nrf24L01_init(void) { _delay_ms(100); //allow radio to reach power down if shut down uint8_t val[5]; //en array av integers som skickar värden till WriteToNrf-funktionen //EN_AA - (auto-acknowledgements) - Transmittern får svar av recivern att packetet kommit fram, grymt!!! (behöver endast vara enablad på Transmittern!) //Kräver att Transmittern även har satt SAMMA RF_Adress på sin mottagarkanal nedan ex: RX_ADDR_P0 = TX_ADDR val[0]=0x01; //ger första integern i arrayen "val" ett värde: 0x01=EN_AA på pipe P0. WriteToNrf(W, EN_AA, val, 1); //W=ska skriva/ändra nåt i nrfen, EN_AA=vilket register ska ändras, val=en array med 1 till 32 värden som ska skrivas till registret, 1=antal värden som ska läsas ur "val" arrayen. //SETUP_RETR (the setup for "EN_AA") val[0]=0x2F; //0b0010 00011 "2" sets it up to 750uS delay between every retry (at least 500us at 250kbps and if payload >5bytes in 1Mbps, and if payload >15byte in 2Mbps) "F" is number of retries (1-15, now 15) WriteToNrf(W, SETUP_RETR, val, 1); //Väljer vilken/vilka datapipes (0-5) som ska vara igång. val[0]=0x01; WriteToNrf(W, EN_RXADDR, val, 1); //enable data pipe 0 //RF_Adress width setup (hur många byte ska RF_Adressen bestå av? 1-5 bytes) (5bytes säkrare då det finns störningar men långsammare dataöverföring) 5addr-32data-5addr-32data.... val[0]=0x03; WriteToNrf(W, SETUP_AW, val, 1); //0b0000 00011 motsvarar 5byte RF_Adress //RF channel setup - väljer frekvens 2,400-2,527GHz 1MHz/steg val[0]=0x01; WriteToNrf(W, RF_CH, val, 1); //RF channel registry 0b0000 0001 = 2,401GHz (samma på TX å RX) //RF setup - väljer effekt och överföringshastighet val[0]=0x07; WriteToNrf(W, RF_SETUP, val, 1); //00000111 bit 3="0" ger lägre överföringshastighet 1Mbps=Längre räckvidd, bit 2-1 ger effektläge hög (-0dB) ("11"=(-18dB) ger lägre effekt =strömsnålare men lägre range) //RX RF_Adress setup 5 byte - väljer RF_Adressen på Recivern (Måste ges samma RF_Adress om Transmittern har EN_AA påslaget!!!) int i; for(i=0; i<5; i++) { val[i]=0x12; //RF channel registry 0b10101011 x 5 - skriver samma RF_Adress 5ggr för att få en lätt och säker RF_Adress (samma på transmitterns chip!!!) } WriteToNrf(W, RX_ADDR_P0, val, 5); //0b0010 1010 write registry - eftersom vi valde pipe 0 i "EN_RXADDR" ovan, ger vi RF_Adressen till denna pipe. (kan ge olika RF_Adresser till olika pipes och därmed lyssna på olika transmittrar) //TX RF_Adress setup 5 byte - väljer RF_Adressen på Transmittern (kan kommenteras bort på en "ren" Reciver) //int i; //återanvänder föregående i... for(i=0; i<5; i++) { val[i]=0x12; //RF channel registry 0b10111100 x 5 - skriver samma RF_Adress 5ggr för att få en lätt och säker RF_Adress (samma på Reciverns chip och på RX-RF_Adressen ovan om EN_AA enablats!!!) } WriteToNrf(W, TX_ADDR, val, 5); // payload width setup - Hur många byte ska skickas per sändning? 1-32byte val[0]=3; //"0b0000 0001"=1 byte per 5byte RF_Adress (kan välja upp till "0b00100000"=32byte/5byte RF_Adress) (definierat högst uppe i global variabel!) WriteToNrf(W, RX_PW_P0, val, 1); //CONFIG reg setup - Nu är allt inställt, boota upp nrf'en och gör den antingen Transmitter lr Reciver val[0]=0x1F; //0b0000 1110 config registry bit "1":1=power up, bit "0":0=transmitter (bit "0":1=Reciver) (bit "4":1=>mask_Max_RT,dvs IRQ-vektorn reagerar inte om sändningen misslyckades. WriteToNrf(W, CONFIG, val, 1); //device need 1.5ms to reach standby mode _delay_ms(100); //sei(); } void reset(void) { _delay_us(10); CLEAR_BIT(PORTB, 4); //CSN low _delay_us(10); WriteByteSPI(W_REGISTER + STATUS); // _delay_us(10); WriteByteSPI(0b01110000); //radedrar alla irq i statusregistret (för att kunna lyssna igen) _delay_us(10); SET_BIT(PORTB, 4); //CSN IR_High } void receive_payload(void) { sei(); //Enable global interrupt SET_BIT(PORTB, 2); //CE IR_High = "Lyssnar" _delay_ms(1000); //lyssnar i 1s och om mottaget går int0-interruptvektor igång CLEAR_BIT(PORTB, 2); //ce låg igen -sluta lyssna cli(); //Disable global interrupt } //Sänd data void transmit_payload(uint8_t * W_buff) { WriteToNrf(R, FLUSH_TX, W_buff, 0); //skickar 0xE1 som flushar registret för att gammal data inte ska ligga å vänta på att bli skickad när man vill skicka ny data! R står för att W_REGISTER inte ska läggas till. skickar inget kommando efterråt eftersom det inte behövs! W_buff[]står bara där för att en array måste finnas där... WriteToNrf(R, W_TX_PAYLOAD, W_buff, dataLen); //skickar datan i W_buff till nrf-en (obs går ej att läsa w_tx_payload-registret!!!) sei(); //enable global interrupt- redan på! //USART_Transmit(GetReg(STATUS)); _delay_ms(10); //behöver det verkligen vara ms å inte us??? JAAAAAA! annars funkar det inte!!! SET_BIT(PORTB, 2); //CE hög=sänd data INT0 interruptet körs när sändningen lyckats och om EN_AA är på, också svaret från recivern är mottagen _delay_us(20); //minst 10us! CLEAR_BIT(PORTB, 2); //CE låg _delay_ms(10); //behöver det verkligen vara ms å inte us??? JAAAAAA! annars funkar det inte!!! //cli(); //Disable global interrupt... ajabaja, då stängs USART_RX-lyssningen av! } ///////////////////////////////////////////////////// int main(void) { UART_Init(9600); InitSPI(); nrf24L01_init(); while(1) { receive_payload(); if(((GetReg(STATUS) & (RX_DR)) != 0)){ data=WriteToNrf(R, R_RX_PAYLOAD, data, 3); UART_SEND_DECIMAL_INTEGER(data[1]); UART_CRLF(); } } }
