Problems with 2 SPI Slaves
44 posts / 0 new
Hi Guys
Hope someone can help be out here, I'm going nowhere after a couple of days debugging.
I have an Atmega328p on a custom board with an external clock running at 20MHz
On the board there are two SPI devices, namely MAX7221 and an MCP4132 (rheostat).  The board is controlled via TWI
Each slave has their own SS pin on the 328p
All is working fine except the MCP4132.
If I write to the MCP first, it works as do subsequent writes to the MAX.  But after writing to the MAX, the MCP doesn't respond anymore.  Slowing down the commands doesn't help.
Below is my setup
// Ports for Atmega328P
#define PIN_SCK  PORTB5
#define PIN_MOSI PORTB3
#define PIN_SS   PORTB2
#define PIN_SSW  PORTC1 // Slave select for MCP
//Init SPI interface
// SCK MOSI CS/LOAD/SS as OUTPUT
DDRB |= (1 << PIN_SCK) | (1 << PIN_MOSI) | (1 << PIN_SS);
//Setup SS for MCP as output
    DDRC |=  (1 << PIN_SSW);
//Write out data for MCP
PORTC &= ~(1 << PIN_SSW); // Start transaction
spiSendByte(0x00); // function
spiSendByte(data); //Set position
PORTC |= (1 << PIN_SSW);     //End transaction
// Write out SPI data for MAX
PORTB &= ~(1 << PIN_SS)
PORTB |= (1 << PIN_SS)
void spiSendByte (char databyte)
// Copy data into the SPI data register
SPDR = databyte;
// Wait until transfer is complete
while (!(SPSR & (1 << SPIF)));
Any pointers as to where I'm going wrong would be appreciated.  It's almost as if the SS pin on the MCP isn't working as it should
regards
Your code leaves a lot a questions....
Not sure if you are using Studio or not but this:
Looks suspicious because PORTB is in BLACK as opposed to the PINK PORTC is.  Usually if Studio recognises definitions it highlights them in PINK.
Does the compiler spit up any warnings?
Do you have a scope or Logic analyser that you can put on the pins and see whats happening?
I'm using studio, the lack of colours is just my bad pasting.
It's a little difficult to attach any probes on the board as it's all SMD.  I guess I'll have to breadboard it.  I was hoping I'd missed the obvious.
regards
You really did not leave much to make it 'obvious'....theres not much there.
Another Freak may be able to come up with a better answer than I though, but you could try soldering some thin wires to the pins of the parts maybe and connect your probes to that?
JIm
Have you read the mcp4132 datasheet, mainly the section descripting CS pin function? Haven't used spi device which CS pin does have 3 states, but maybe that is the proplem you are observing here.
I did wonder about the CS state of that port.  Have to say I didn't fully understand that section of the data sheet.
regards
As a test you could try cycle the CS pin of mcp4132 once after issuing a command to the max device.(low, high, low, with atleast 100ns delay in between).
Edit: Thought, if the proplem is that the mcp switches between command and high voltage command modes I don't think cycling will work, could not find high voltage command mode threshold voltage with quick peak of the datasheet.
Crap!  I forgot I used the MCP 41xx series parts once
Just tie the CS pin to your I/O  pin and thats all you need for standard operation.
That's what I've done.  The data sheet speaks of a required delay after dropping the pin, and I'm allowing 1ms which should be plenty it's still unreliable.  The MCP4232 I'm using has a 0-50k resistance and it's in series with a 10k resister.  The wiper is then connected to the iset pin of the MAX7221 which is looking for around 12k-62k which allows me to programatically adjust the current draw.
I'm going to breadboard this tomorrow and hook up a logic analyser to see if that gives me clues.
When I run the two slaves fast, I notice overtime that the data intended for the MCP is being sent to the MAX.  It may be I have a race condition somewhere.  However running the data in 5 second bursts makes the MCP unresponsive almost immediately.  At first I thought it might me an SPI speed issue but the MCP will do 10MHz so that should be fine.  I could check for an error condition coming back from the MCP, but I still haven't figured out from the data sheet how to do that yet.
Somehow I'm just missing something simple here I think.
Question:  It looks like the MCP needs mode 0, is that the default mode?
regards
SPI has 4 modes of operation, have you verified your using the correct mode for each chip?
Wot - no test points ?!
surprise
Your init seems a bit light, as I don't see where you setup the SPI control reg with Enable, data order, master/slave or clock polarity/phase or speed???
Is this ALL of your code, if not, please post a complete small program that demos the problem.
Yes that's all I have for the init.  To be honest it's been working fine with the MAX7221's for some time.  It's just been the addition of another slave.  MCP runs at 10MHz.  Are there other options I should specify that aren't default?
I managed to hook up a logic probe today, just on the MCP side (triggering on the SS going low).  What I discovered was that only the first byte was going out on the wire, not the second.  I did get another byte some 2 seconds later that was garbage.  The code calls a function in the same class (spiSendByte) with the toggle of the SS pin before and after sending.  When I copied the code from that function, lo and behold the MCP started working as I could see two bytes being transferred.  Thought I'd cracked it.  That said, why would the code work inline, but not as a function?
It's still not working as it should though.  If I make a lot of calls to the MAX.  Pause 5 seconds and then call the MCP I'm back to square one.  1 byte and the bus seems to hang. why!!!!! grrrrr
Tomorrow I'm going the wire the SS for the MAX and add that to the logic probe and see if there are more clues.  Given that I'm waiting 5 seconds from the last send to the MAX, I don't think it's a timing issue.  However the AVR is locked at that point.  No SPI activity at all.  Perhaps both SS lines are low?  But I don't know how that could be.
regards
No,  thought the board was good to go after a month of testing the MAX.  wired some tiny cables on instead to get a look at the signals.  It's like fixing a computer I guess,  Never put the box on until you've tested it first.
regards
nikm wrote:
it's been working fine (sic?) with the MAX7221's for some time.
Does that mean, "rigorously validated that all parameters are well within spec under all conditions" - or just that it's been running, and you haven't noticed any problems?
Whenever that kind of thing happens, it suggests that something(s) was/were marginal before - and the "extra" has just pushed it over the edge ...
I'd suggest capturing what goes on with each sensor alone, then with the 2 together, then spot the difference ...
Its been running for about 6 weeks on and off at 50 x expected speeds using the 4 x MAX7221's without problem so I don't think it's marginal.  It's TWI driven so I'm looking towards a potential conflict with an interrupt being triggered.  In any event, I should hopefully be able to see them both on the analyser later today which might give some clues.
Running the MCP on its own hasn't caused any issues for many hours.  It is also perhaps the fact the CPU is running with debug wire on, might be an issue I guess.
regards
Wait
Originally you said 2 slaves...now there's 4x7221 and the MCP?
That's 5 total not 2
The MAX7221 are daisy chained so they appear as 1 logical SPI device
regards
Hum that can't be right as the SPI is not even enabled from the code???
Sorry too much seems to have changed from the OP, where one (or is it now 4) "worked" but the other (or is it now 5) device does not?  I'm lost.
Start from the beginning, tell us about all of your HW and show us a small complete program that your having problems with.
Then maybe someone here can follow along with you and help you trouble shoot your issue.
Apologies, cut and paste error.  Been staring at the code way to long, here's the init
// SPI Enable, Master mode
SPCR |= (1 << SPE) | (1 << MSTR) | (1 << SPR0);
The board consists of an Atmega328P, 1 MCP4132 and 4 x MAX7221 daisy chained
The 4 MAX7221's appear as one SPI Slave.  I am manipulating 2 slave select pins
The code is pretty complex because of the functionality which has nothing to do with the SPI.  In essence I'm receiving a command over TWI and depending on the data I'm selecting a slave and writing two bytes to it.
I'm about to hookup the logic analyser so see what's going on behind the scenes SPI wish.
regards
That's why
Think I may have found the issue, but not the solution.  It looks like the SS pin on the MAX is being held low most of the time and there's an overlap when both slaves have it low
Logic analyser
So connected like this:
so you send a multi-byte stream when the SS pin is low and "talk" to all devices at one time?
Instead of this:
Where you only "talk" to one chip at a time by enabling only one SS pin?
Sorry, I just want to be sure I understand how the HW is connected.
The max7219/7221 are wired thus (daisy)  or rather serial cascading.  These work just fine, it's the interaction with the other slave that's the issue.  The load/data line is SS
regards
Don't YOU have control over when the various peripherals are accessed? It seems very unlikely that one would be accessed while the other is. Normally, you would wait for one to finish before starting the other.
That's the way the code is written yes.  However I've been reading up about SPI devices that don't release the bus.  While the MAX7221's look genuine, I'm not 100% sure they are.  I've ordered a set from  a reputable, if expensive supplier and I'll make a new board tomorrow.  It's very strange that the outputs from the logic analyser show that the SS pin for the MAX was low most of the time even though it wasn't processing data.
regards
nikm wrote:
regards
Do you have pullup resistor for the SS? Usually I have added one just in case.
No I don't and wish I had.  At the time I didn't think I needed to.  Could wire one on to test though.  10k?
regards
If that long chip select is on the daisy-chain set, you  need to be aware that the chip select needs to be continuously low during the entire transaction. Otherwise, the message will be broken up and devices will get the wrong data. The key event is when the chip select returns high.  THAT is the signal that tells each one to latch the data that it contains.
Agreed, but isn't this line going to block to prevent this?  Besides in testing I'm waiting 2 seconds between transmissions.
regards
That only waits for the first byte to complete, not the entire message!
0hhhhh!  Just to get my head around this, here's the sequence of events
TWI Stop/restart tells me I'm done receiving data and interrupt is triggered.
Run function that then sends formatted data to appropriate device.
stretch TWI clock if required until I'm done.
Surely this is all single threaded?  The SPI sending just loops through the data.
regards
But how does that other SPI process run while all this  is happening? Surely, its not in an interrupt, is it?
No, I'm not using the SPI interrupt.
Changing the MAX7221's for ones I know are 100% genuine made no difference, neither did adding a pull-up on the SS line.
The issue, which shows up in the logic trace is that I'm getting an overlap on the SS pins as I'm driving the MAX's as fast as I can.  If I introduce a 10ms delay between each SS transition the issue is resolved in that I'm not getting corruption of data.   However the performance hit is too much.
I'm replacing the chip with an Atmega328PB which has 2 x SPI.   One will be the high transaction one, and the other for lower levels.  I could mess with the code and put more logic in it to improve things but I need to be almost continuously send 32 bytes to get the performance I need.  Changing the chip type will resolve the collision/overlap.
Thanks for everyones help, much appreciated.
regards
YOur solution is not really a solution, more like an expensive band aid, but if your happy with it then great.
Thanks for letting us know you have solved the problem to your satisfaction.
JIm
I am confused because post #22 shows both SS's are low at the same time.  But both SS pins are output right?  Both are controlled by the AVR?  According to your code, one goes low, two bytes are sent, then it returns high, then the next SS line goes low, two bytes are sent, and it goes high.  I don't see why/how you would have both low at the same time?  It isn't like these have a pullup and the slave device can hold them low, right?  If they are output on the AVR, then the AVR dictates what they will be and the other side should be high impedance and accept what it is sent, low or high.
You're absolutely correct but testing says otherwise.  The time of the overlap is 40 micro seconds.  Is it possible that this is the time it takes a pin to change from low to high?  Either way I was getting both devices being talked to at the same time when running at high speed.  By that I mean data was being processed continuously.
regards
I take your point, and I would dearly have liked the time to figure it out software wise, but time was a constraint.  The purist in me wanted to keep going, sadly I ran out of time.
As far as cost goes, chips are similar in price with just a few tweaks to the board.
regards
I'm glad you have it working.  The pin change speed might be in the datasheet, but it is going to be very fast, likely in nanoseconds.  I would think the only way it could take 40 microseconds is if it was weak - you have that pin set to output right?  Not set to input and you are just enabling/disabling the pull-up resistor?
hmm, I thought I was toggling high low as below
Is there a better way?
regards
If the DDRC has that pin as output, then yes.  If the DDRC has it as input, then you are toggling the pull-up resistor.
You can do a quick test and modify your code to toggle it high/low/high/low immediately and see what happens.  Does it show a high/low/high/low transition that is very fast (say a couple clocks of the AVR)?
this is how it's setup
 I'll but some test code on the analyser tomorrow, but what's the alternative solution?
regards
I don't know that there is an alternative solution.  I think you need to to more testing to figure out what is really going on, but the short of this is that if you take a SS pin HIGH, it should occur very quickly.  Sometimes it takes a device a little time to disable its one output (MISO) if it is truly a SPI type device that will do that (some devices do NOT disable the output - I've dealt with displays that have a data out DO that is always enabled irregardless of the SS state).  When you run into an issue like this, you basically have to modify the code to try to expose what is going on.  Try changing it in different ways and evaluate what happens, hopefully this will yield an aha moment of what is going wrong.  Try toggling both SS pins, do they both exhibit the lazy state change?
regards
Thats low-high
