How to clock/not to clock...XMEGA/ARM
18 posts / 0 new
I have been 'experimenting' with XMEGA and SAMD21 chips off and on recently in anticipation for some possible future projects coming up.  The learning curve is pretty steep, but I am plucking away at it with pretty good success.
Heres the rub....I have been looking at the clocks for both chips and they share a lot of similarities.  Being COMPLICATED in my opinion is one of them, but more importantly their accuracy over temperature/voltage.  The voltage is not so important to me as the supplies are well regulated 3v3, but the temperature is another thing as these devices are going to be in very wide temperature environments.
I was wondering if anyone is using JUST the internal oscillator for their designs with USART comms, or do you stick with the tried, and proven Crystal oscillator?
I m not concerned about the cost of a $0.10 crystal.  I am more interested in user experience/feedback.
JIm
I put a crystal on most of my xmega projects because I want them to have a pretty accurate sense of time. I like that the clock is selected by code, not fuses, so getting something wrong just stops the processor till you load a correct program. I haven't used a uart since CP/M or early DOS days.
NONE of your AVR projects have ever communicated over a USART Tom?
Is an order of magnitude greater price acceptable?
Reason : 32KHz MEMS oscillators, max current half that of XMEGA128A1U internal 32KHz RC oscillator
22ppm max over -40C..85C (105C abs max) :
ASTMTXK via Abracon Products (MEMS, KHz, SMD)
Questions?
Typical bauds?
Reasons :
  • USART FBRG (16b precision)
  • XMEGA baud error less than 1% (given calibrated 32MHz RC oscillator)
Maximum current consumption?
Reasons :
  • MEMS MHz oscillators
  • Calibrated XMEGA 32MHz internal RC oscillator is relatively efficient, precise (dF steps), and accurate
Is another frequency reference available?
Reasons :
  • USB SOF
  • UART SOF
  • UART BREAK and SYNC
Microchip is in MEMS oscillators at approx 1mA though with a standby mode :
DSC6000B - Clock and Timing - Oscillators
DSC6083CI2A-032K768 Microchip Technology | Mouser
ATxmega128A1U - 8-bit AVR Microcontrollers
AN_2563 AVR054: Run-time calibration of the internal RC oscillator via the UART via ATmega324PB - 8-bit PIC Microcontrollers
note : FBRG is also in megaAVR 0-series with the addition of auto-baud (BREAK, SYNC, data)
Yes.
Efficient yes, stable and accurate?  Not sure, hence why I am asking if there are Freaks out there using Both XMEGA and SAM with USARTS and what clocking method they use.
No.  Micro is its own source of clock.
JIm
I'm using XMega32E5 on a few projects that use UART and I've always used the internal clocks. I've never had any issues thus far knock on wood. I've used it to communicate messages with the Nordic NRF83252 and Cypress CYBLE202007(deciding on BLE module), and I'm working on a project currently with single wire UART to a TMC5130. There are some good ASF example projects for xmega as well to help you sort through the weeds if you get stuck. Hope this helps.
Cheers,
Jesse_G an EE writing firmware...what could go wrong...
What are your baud rates may I ask?  And what is the temperature average where the parts are?
The project with the BLE was 2400(another story as to why it was so low...Zilog sucks) and they were up in commercial light fixtures, so anywhere from 0C to 85C. A few of them were stuck in 300W LED outdoor fixtures in Texas specifically for temperature throttling the current  at 70C, but I know in test they saw 85C without any issues. These parts are on average operating at 45C-50C as LED fixtures are hot pretty much anytime they are on.  The single wire UART I'm currently working on is 115200 and the temps are mundane @ 20C to 65C. This project revolves around a hydraulic lift valve so hydraulic oil gets to runny past 65C but the average temp is 32C-37C.
Cheers,
Jesse_G_EE wrote:
NRF83252
nRF52832 - Bluetooth low energy System-on-Chip - nordicsemi.com
Apparently 16b for its baud rate register :
https://infocenter.nordicsemi.com/index.jsp?topic=%2Fstruct_nrf52%2Fstruct%2Fnrf52832.html&cp=3_1
https://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.nrf52832.ps.v1.1%2Fuarte.html&cp=3_1_0_34_9_10&anchor=register.BAUDRATE
Jesse_G_EE wrote:
... and I'm working on a project currently with single wire UART to a TMC5130.
SYNC, data
https://www.trinamic.com/_scripts/download.php?file=_articles%2Fproducts%2Fintegrated-circuits%2Ftmc5130%2F_datasheet%2FTMC5130_datasheet.pdf
TRINAMIC Motion Control GmbH & Co. KG
Hamburg, Germany
TMC5130A-TA DATASHEET
Universal high voltage controller/driver for two-phase bipolar stepper motor. stealthChop™ for quiet movement. Integrated MOSFETs for up to 2 A motor current per coil. With Step/Dir Interface and SPI.
[page 7]
1.2.2 UART Interface
The single wire interface allows differential operation similar to RS485 (using SWIOP and SWION) or single wire interfacing (leaving open SWION). It can be driven by any standard UART. No baud rate configuration is required.
edit : strikethru
Good information, thanks all!!!
JIm
Nope!
Picked my first AVR chip to play with because it had a uart, but never used it!
I have used it in arduino projects, but that does not quite count as I only used it to communicate to the terminal built into the arduino ide.
Jesse_G_EE wrote:
Hmm. That's impressive.
My impression is that "lots of people" run normal AVRs off their internal oscillator and still do serial coms "just fine", and that accuracy of the new ARM/XMega oscillators is better than those...
Indeed, I think that is the case (that "plenty" of folks use the internal oscillator for async serial communication). However, that does not change the fact that they are rolling the dice every time. I wonder what percentage of their thingies are non-functional?
Using the worst case specs gives the answer. Clearly the 10% spec for the old AVRs rule them out.
If the worst case specs show the solution as borderline, then add a crystal or mitigate the problem. LIN protocol is one solution. It addresses cost, size, vibration and temperature range.
Unless physical dimensions are an issue why would you gamble for the sake of a $0.10 crystal?
(well, OK, if you are building 2,000,000 I guess it starts to be an issue ;-)
Just asking for my own curiosity Cliff. The potential punter is not concerned about cost at all.
https://www.electronicdesign.com/technologies/embedded-revolution/media-gallery/21131005/embedded-products-of-the-week-510-516/slideshow
Silent Stepper Motor Controller Manages Up to 35V Motors with 3A Phase Current
Trimanic [sic] Motion Control has launched its new TMC5160 SilentStepStick silent stepper motor controller and driver IC, ...
