CCL, LUTS and Encoders
17 posts / 0 new
Hi Guys,
I'm trying to figure out if I can drive more than one encoder (plan on using ATmega4809)
I've had a look at app note  AN2434 but I'm not up to speed enough as to how I might have multiple encoders going via the LUT or even if that make sense at all
Currently I use an ATmega324PB with PCINTS and it works well, but this seems a more efficient way of doing this. (plus there are more I/O pins on the 4809)
regard
** Title should have been CCL not CPL but I can't change it
Changed!! No Charge - JGM
Each encoder needs 2 LUTs, each LUT detects one direction.
Since the mega4809 has 4 LUTs, it can decode the signals from 2 encoders.
Thanks, I knew it was too good to be true
regards
Answer:
Meaning you can drive more than one encoder...
So why the long face:
regards
Because I need more than 2, ie 16.  My bad for not making it clear.blush
regards
Ahhhhhhhhhhh!
What about using some sort of external encoder interface?  There are a lot of them out there from what I saw in a google search.
seems like there are some software PCINT projects out there that you could look at as well.
16 encoders?  What is that for if I may ask?
JIm
I have 16 encoders working with PCINT using an ATmega324PB built with the arduino IDE.  Problem is I don't have enough spare pins if I want to convert using Studio7 and JTAG.  Hence me looking at the 4809.
I haven't  found out what's the equivalent of PCINT in the 4809 as yet though.
The card is an input card for an application where the user can configure the ports to be simple interrupt driven inputs or assign pairs as encoders.  That's why external encoders won't do I'm afraid
My fallback is using MCP23S17's but I'd rather not.
regards
Then jump UP to a Mega 2560.  Or in the case of the 324PB disable the JTAG and program the device through ISP.
JIm
Sadly the 2560 only has 24 PCINTS, but I think if I go with an external oscillator on the 324PB I'll get back a pin and should be ok.
regards
What type of encoder are we talking about here?
Mechanical concentric ones, such as Elma E37 as well as regular quad ones.  Movement is human generated, not some other mechanical device.  Are you thinking polling will suffice?  My experiments suggest some movements will be missed if turned fast
regards
For cheap encoders, you need two I/O pins for each encoder.  One pin per encoder needs to be connected to a PCINT pin.  When the PCINT goes low, check the other pin.  If low, then encoder was turned one way and if high it was turned the other way.   For eight encoders you need 16 pins with eight being PCINT.
You mean, because the Arduino IDE uploads code using the bootloader? AS7 can do that too, if you configure it to use avrdude as an external tool. Granted, it requires some work.
Do you believe that is the case for all 2 pin encoders? It's been a while since I looked at the code, but some encoders send multiple pulses per detent (4) and others 2
regards
I dare say you could multiplex and poll a number of them via a timer interrupt. What is the maximum pulses per second you expect?
Using multiplexing, you could read 16 encoders using 12 pins.
The speed won't be that fast.  5 detents/second, so 20?
regards
I think multiplexing will work for you then.
