Electronic Components--Resistor
10 posts / 0 new
For engineers in the electronics industry, electronic components are the basic element. There are several types of components, in this artical,I would like to share some basic knowledge about resistors.
Resistor is the most frequently used in all electronic circuits. Resistor is called a resistive material because it has a hindrance to the current. It can cause changes in electron flux. The smaller the resistor, the greater the flux of electrons and vice versa.
Most of the time, the resistors we used are with fixed values. For example,
Wire Wound Resistor can be made as a precision resistor with a tolerance of 0.005% and a very low temperature coefficient.The disadvantage is that the parasitic inductance of the wire wound resistor is relatively large and cannot be used for high frequencies. The volume of the wire wound resistor can be made very large, and then an external heat sink can be used as a high power resistor.
Carbon Composition Resistor is simple in process and easy to obtain raw materials, so the price is the cheapest. However, the performance of the carbon composite resistor is not so good, the tolerance is relatively large (that is, the precision resistor cannot be made), the temperature characteristics are not good, and the noise is usually large.
Carbon Film Resistor mainly forms a carbon mixture film on the ceramic rod, for example, directly coating a layer, the thickness of the carbon film and the carbon concentration thereof can control the size of the resistor.
I would appreciate it if you can complement more types.
An electronic engineer
Plagiarism ?....
Moe123 wrote:
Plagiarism ?....
Can you prove this?
JIm
Cop/paste in any plagiaism checker website, its already on the internet...atleast in two website
I'm not even sure what this post/thread is about anyway?
My very first thoughts were troll/spam but if it's some kind of spam it's very subtle as I'm not sure what he's selling.
I wonder if it's one of those where they post what appears to be possibly legitimate technical info and then later come back to edit the spam links into it?
So it seems.  But on two of the sites the avatar is the same as the one here....I wonder if it's the same person spamming?
I checked the OP's IP address but it's not what I'd call the most suspicious place on earth (I might describe it as the most laid back location on earth ;-)
That might leave us with very little options...I can see the sea and yellow sands out there ;)
Heres an idea.....
Lets stop contributing to the thread.  The longer we add to it, the more its read thereby giving the OP what they want.
I'm out.
Topic locked
