New to UPDI
6 posts / 0 new
Hi!
I'm new to using UDPI. Just want to check if I got the schematic right.
The pin UPDI (41) I use for the UPDI. The question is what do I do with the RESET pin? Do I set it up default (resistor pullup and cap to gnd)?
I was thinking of buying a xmini and use the programmer of it (after modfying it, link:https://www.jsykora.info/2019/04/avr-updi-programmer-from-attiny817-xplained-mini/  )
Is that a good option to consider?
The controller I'm using is the ATMEGA1609.
Code is everything, code is life :D
Can be connected to a signal from a USB UART such that mega1609 can be reset via an operating system (some OS can control UART handshake signals)
edit2 : UPDI : pull-up yes, cap no
Another debugger option may be the nEDBG on a mega4809 Curiosity Nano (open some of the jumper pads, has level translators)
Programmers can be via a USB UART or a megaAVR UART.
ATMEGA1609 - 8-bit Microcontrollers
ATmega4809_Curiosity_Nano
[page 2, B7, nEDBG jumpers]
[page 3, D3, RESET]
via ATmega4809 Curiosity Nano
edit :
Atmel-ICE | TinyX-OCD (UPDI) Special Considerations
When designing a target application PCB where UPDI interface will be used, the following considerations must be made for correct operation:
  • Pull-up resistors on the UPDI line must not be smaller (stronger) than 10kΩ. A pull-down resistor should not be used, or it should be removed when using UPDI. The UPDI physical is push-pull capable, so only a weak pull-up resistor is required to prevent false start bit triggering when the line is idle.
edit3 :
https://www.avrfreaks.net/forum/megaavr-0-series?page=4#comment-2758641
edit4 : typo
Great! I just realized I didn't have a 10K pullup will add that.
So the option is (and the cheapest) is to get a curiosity Nano and just shave off those pins and use it a programmer. Is atmel studio compatible with it?
I don't know (haven't tried that as I have Atmel-ICE)
IIRC, mEDBG is at least somewhat target MCU tolerant; don't know about nEDBG.
nEDBG works in Studio - just uncheck the "hide unsupported devices" checkbox from the options when using another device than the one mounted on the CNANO.
UPDI only requires three pins: UPDI, GND and V+. there is no need whatsoever for a pull up resistor. we have discussed this many times.
your other question about using mEDBG: you have to use a common ground then its theoritically possible. please check the website for related issues. the forum is fulll of similar questions to yours.
BR,
Moe
